Old October 26th, 2013, 02:38 PM   #201
Boom King
So, where's the reverse?
Boom King's Avatar
I'm not sure if moving it around to prevent flat spots is necessary. I pump the tires close to max psi and roll them up onto pieces of wood or thick carpet. Never had flat spots in the spring.
Old October 26th, 2013, 02:39 PM   #202
conrya5
conrya5's Avatar
Motorcycle(s): 2010 Metalic Island Blue Ninja 250r
Everyone's method varies. Taking the time to store the bike properly is very rewarding in the spring when it starts up right away.
If your bike will be in the parking lot you should look into getting a cover for it.
conrya5 is offline   Reply With Quote
Old October 27th, 2013, 07:24 PM   #203
I would also check the coolant and change if more than a couple of years old. Make sure it's safe down to -20 or so - usually a 50%/50% mix of antifreeze and water is recommended. I've learned recently that regular bottled drinking water is better to use than distilled or de-ionized water.
I'd also drain the float bowls before storing.
As noted - once you change the oil, run it for a minute - then don't start it again until you are ready to ride. Running for short periods only contaminates the clean oil.
Current tire don't flat-spot, so don't worry about that.
Storing outside, even under a cover, is not a great idea. Find cheap inside storage if you can.
Old April 26th, 2014, 10:46 PM   #204
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
We are about to PCS from Hawaii to Kansas. Other than draining the gas should I follow these same rules? TIA
Kstorm21 is offline   Reply With Quote
Old April 27th, 2014, 05:06 AM   #205
allanoue
allanoue's Avatar
MOTM - Sep '14
How long will it be not running?
Old April 27th, 2014, 01:13 PM   #206
Kstorm21
Kstorm21's Avatar
Close to 8 weeks if not longer. Depends when we get housing.
Old April 27th, 2014, 06:55 PM   #207
allanoue
allanoue's Avatar
MOTM - Sep '14
Yep, all the steps the same as winterizing.
Winterizing for one day Ninja Rob General Motorcycling Discussion 50 January 10th, 2015 08:01 AM
Winterizing Question Apex123 2008 - 2012 Ninja 250R Tech Talk 2 November 12th, 2014 09:53 PM
winterizing 250's scorch General Motorcycling Discussion 10 May 13th, 2014 11:34 AM
Winterizing... emilyLOVESlime 1986 - 2007 Ninja 250R Tech Talk 18 November 2nd, 2009 10:57 PM
Winterizing your Ninjette Sailariel 2008 - 2012 Ninja 250R Tech Talk 37 December 20th, 2008 08:05 PM
