Old November 12th, 2014, 05:41 PM   #1
Apex123
Motorcycle(s): Green Ninja 250 2008
Winterizing Question
Hello, Just finished prepping the bike for winter for my first time. For the gas tank I decided it was best to fill it up to full and and marine Sta-Bill, my question is does the gas tank's setting need to be switch to Prime or On for the winter?
Apex123 is offline   Reply With Quote
Old November 12th, 2014, 06:23 PM   #2
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
I leave mine in the "on" position, then drain both carb bowls, come spring, I switch it to "prime" for a minute, back to "on" and she's always started right up.
kevheads is offline   Reply With Quote
Old November 12th, 2014, 09:53 PM   #3
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I always leave it on ON (unless I'm draining the tank completely dry). PRI means the petcock allows the gas to be gravity fed from tank into the carbs. ON means gas is allowed to be fed into the carbs via vacuum only.
Are you going to drain the carb bowls? Since my winter hibernation is only 100-120 days, I don't always drain the carbs every winter (when I'm lazy). If you're not going to drain, make sure you go for a quick ride with the Stabil in the tank so that the carbs get filled with treated gas.
Winterizing for 5 weeks? mrudich General Motorcycling Discussion 4 June 13th, 2014 05:13 AM
winterizing 250's scorch General Motorcycling Discussion 10 May 13th, 2014 11:34 AM
Winterizing... emilyLOVESlime 1986 - 2007 Ninja 250R Tech Talk 18 November 2nd, 2009 10:57 PM
Anyone Have Problems De-Winterizing? TrueFaith 2008 - 2012 Ninja 250R Tech Talk 17 April 13th, 2009 09:29 PM
Winterizing your Ninjette Sailariel 2008 - 2012 Ninja 250R Tech Talk 37 December 20th, 2008 08:05 PM
