Old August 22nd, 2013, 05:14 AM   #1
Jeffro2749
Motorcycle(s): 2006 Ninja 250
Bogs down when accelerating, max 5-7k RPM
Hey Guys,
Just found this site and loving it already. I have a 2006 250 and recently started having issues. It started bogging down on me last night when accelerating. Sitting in neutral and revving it up upon starting it and it wouldn't get over 6k RPM's. when I go to take off it bogs down around same RPM level then will die when I come to a stop. Then it becomes very difficult to start unless I let it sit a while. Then same problems when I try again. Any ideas or help would be appreciated.
Jeffro2749 is offline   Reply With Quote
Old August 22nd, 2013, 05:19 AM   #2
Welcome Jeff!
To help us figure out your issue can you answer the following please?
How many miles?
Last time the carb was cleaned?
Last time the valves were checked/adjusted?
Last oil change?
Any mods to exhaust/airbox/jetting?
Old August 22nd, 2013, 05:37 AM   #3
Jeffro2749
Welcome Jeff!
How many miles?
Last oil change?
17k
not sure on the rest except oil change has been a while. I just bought the bike in mid June.
Old August 22nd, 2013, 05:45 AM   #4
Hmmm... 17k huh.
Possibilities then;
Simple, quick and cheap fixes
Clogged fuel filter
Petcock issues
Air filter issues
Bad gas/water in gas? Flush and fill
Use some Seafoam or similar product
More involved fixes but still pretty cheap and easy
Gummed up/dirty carbs (Use the new howto vid!)
Valve check/adjustment
Old August 22nd, 2013, 06:07 AM   #5
Another thought, vacuum leak. A quick spray mist of carb cleaner around the vac lines will rev the engine if you have a leak.
Old August 22nd, 2013, 06:27 AM   #6
Welcome to our site, Jeff !!!
Enough gas is not reaching your carbs for some of the reasons explained above.
Read our Riding Skills section.
Old August 22nd, 2013, 07:03 AM   #7
/moved to pre-gen tech
Old August 22nd, 2013, 07:29 AM   #8
Hmmm... 17k huh.
Possibilities then;
Clogged fuel filter
Petcock issues
Air filter issues
^ This pretty much has it covered.
Most likely it's not getting enough gas or enough air. Bad gas will also give you unusual problems, as will an almost-dead battery.
I recall a similar problem that turned out to be something under the seat blocking the intake.
Old August 22nd, 2013, 07:36 AM   #9
Jeffro2749
Is there a way to drain the fuel tank without taking it off the bike itself?
Old August 22nd, 2013, 07:40 AM   #10
http://faq.ninja250.org/wiki/How_do_...e_fuel_tank%3F
http://faq.ninja250.org/wiki/Draining_the_carbs
http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap
http://faq.ninja250.org/wiki/How_doe...e_tank_work%3F
Old August 22nd, 2013, 07:59 AM   #11
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
sounds like the same problem i recently just overcame with my bike. My issue was water in the gas tank and carbs. Try draining the carb bowls. It's quick and easy to do and will tell you whether there's water in it or not. Use something clear to collect the gas.
az3200 is offline   Reply With Quote
Old August 22nd, 2013, 09:36 AM   #12
agentbad
agentbad's Avatar
Whens the last time you had your valves adjusted?
Old August 22nd, 2013, 09:55 AM   #13
Jeffro2749
I just bought the bike a couple months ago so there's no telling to be honest with you. This is my first bike so it's all new to me.
Old August 24th, 2013, 01:56 PM   #14
n4mwd
n4mwd's Avatar
Unless you got a copy of the maintenance records when you bought the bike, you have to assume there was no maintenance.
Bogging down past 5K rpm usually means the pilot jet in the carbs are clogged.
I would recommend doing a valve adjustment and a thorough carb cleaning and chaining the oil and filter all at the same time. Make sure you read my blog (link below) regarding overtorquing the rockers or else you could destroy the engine. That is just routine maintenance.
My Ninja Blog
Old August 24th, 2013, 02:48 PM   #15
Jeffro2749
Had it towed to a local shop and the owner said one valve was fine with the compression and the other was extremely tight. Said it would cost me about $150 in labor to try and fix the valve and only then would they be able to tell me if the engine is screwed or not. Sound probable guys? I know nothing about bikes.
Old August 24th, 2013, 03:02 PM   #16
.........I have a 2006 250 and recently started having issues. It started bogging down on me last night when accelerating........
Valves don't produce those from-night-to-day symptoms.
Knowing that one valve is tight takes much of the corrective work; hence, I wouldn't use the services of those mechanics.
Instead, I would follow the advices of posts #4 and #11 above.
Old August 24th, 2013, 04:26 PM   #17
n4mwd
n4mwd's Avatar
What did he do to come to that conclusion? Sounds fishy to me. Does this guy primarily work on Kawasaki Ninjas - or other bikes? If it runs at all, its probably not screwed.
When a Ninja has problems like that, the most common cause is fuel and not valves. But because you don't know when your valves were adjusted last, you need to do them even if they aren't the cause of your current problem.
Just saying, if you are going to ride a older model bike, then its really not practical to take it to a shop every time work needs to be done on it. You'll go broke really fast. You really need to learn how to fix and maintain it yourself.
But if you happen to be a mechanical zero, then I would recommend getting a new bike that comes with a warranty.
My Ninja Blog
Old August 25th, 2013, 09:03 AM   #18
az3200
az3200's Avatar
I doubt your engine is screwed. I suggest you take the advice that was given here, isn't that why you made an account on this website? You could probably have your bike running today if you take the time to look through the reasons that were listed here. I've had a couple handfuls of issues with my ninja. If I couldn't figure it out I would come on this website. Every single time i've gotten it worked out with the help of everyone here, and my bike has yet to see a mechanic. I've probably saved myself hundreds and hundreds of dollars by following the advice of this website. Did you miss the post i made in this thread that said I was having the same exact problem as you earlier last week? Sorry, not trying to be rude.
2009 Bogs Between 3500-4000 RPM Hatter 2008 - 2012 Ninja 250R Tech Talk 2 March 26th, 2015 09:39 AM
Clunking while accelerating MrAtom 1986 - 2007 Ninja 250R Tech Talk 40 March 10th, 2015 06:02 AM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Power hesitation when accelerating? mrb 2008 - 2012 Ninja 250R Tech Talk 17 December 5th, 2013 02:35 PM
School Me: accelerating corners, setting up Løckøut Riding Skills 20 October 2nd, 2013 12:38 PM
