Old August 18th, 2014, 12:31 PM   #1
darrell85
darrell85
darrell85's Avatar
Motorcycle(s): 2001 250 ninja
my 3 day cafe racer transformation
Looks like everyone with a pre gen is goin cafe, myself included. Only have about $30 into this build so far. I use this bike alot going to work, so i gotta have the bags, but getting more fitting cafe style bags and gauges soon.
Last futzed with by Alex; August 19th, 2014 at 08:30 PM. Reason: pic fixed
darrell85 is offline   Reply With Quote
Old August 18th, 2014, 01:54 PM   #2
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Let's try this
Old August 18th, 2014, 09:24 PM   #3
hawkxcore
Motorcycle(s): Ninja ZX750F
I love it!
hawkxcore is offline   Reply With Quote
Old August 18th, 2014, 09:55 PM   #4
psych0hans
psych0hans's Avatar
Not bad for a 30$ transformation... Good luck getting her all pretty!
Old August 19th, 2014, 06:00 AM   #5
Kruse08
Kruse08's Avatar
Motorcycle(s): 99 Ninja 250
Wow, you make me jealous, I have spent a lot more money and I am not anywhere close to this. Good job.
Everything you’ve ever wanted is on the other side of fear. –George Addair
Kruse08 is offline   Reply With Quote
Old August 19th, 2014, 06:01 AM   #6
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Looks good!!
Raven's Rejuvenation
Old August 19th, 2014, 06:01 AM   #7
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Nice
Old August 19th, 2014, 06:33 AM   #8
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Oooh! What's the seat/tail setup you have going on there? I think the tail of the ninja is probably the hardest part to prettify.
M42 is offline   Reply With Quote
Old August 19th, 2014, 03:10 PM   #9
darrell85
darrell85
darrell85's Avatar
Originally Posted by ninjamunky85 View Post
Let's try this
Thanx ninjamunky85!
Old August 19th, 2014, 03:43 PM   #10
darrell85
darrell85
darrell85's Avatar
The tail took a little imagination to make it look "cafe" and keep it cheap. I started by
Cutting the rear frame off at the tail light tabs, then i cut the top rear subframe bar off right behind the upward bend, then cut off the bend and welded the top bar back on straight. And trimmed up the excess of the lower bar. I then carefully stripped the seat pan and cut it right behind the seat latch brackets. The rear "bum stop" tail section is an old 3/4 helmet that i pulled the insides out of and cut a little off of the bottom and the front, then cut a hole in the rear and put a round parts store trailer light in it. I then used the threaded holes on the seat latch bracket to connect the front of the rear hump to the seat. I then trimmed the edges of the seat pan, cut the seat foam to length, put it back on, then used the longest wood sawzaw blade i had to trimm it up and sand paper to smooth it to give it that flat thin look and reused the seat cover. Turn signals are farm supply bullet trailer signals, headlight is a "7. Headlight and bucket out of a 70s ford truck modified woth a homemade bracket. Any other questions, just ask
Last futzed with by darrell85; August 19th, 2014 at 03:48 PM. Reason: add detail
Old August 19th, 2014, 04:12 PM   #11
she's a looker!
Old August 19th, 2014, 04:39 PM   #12
M42
Wrench wench
M42's Avatar
Okay, that helmet thing is really unique. Awesome bike dude!
Old August 19th, 2014, 05:10 PM   #13
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Nice work.
Cafe Racer PF1 New Members 10 August 22nd, 2014 09:44 AM
My new Cafe Racer *pics* mikdavi84 1986 - 2007 Ninja 250R Farkles 26 May 28th, 2014 06:58 PM
Ninja Cafe Racer! JGRIM New Members 52 September 6th, 2013 06:02 AM
[topix.net] - Goosing the Goose: Making a Cafe Racer out of the Guzzi V7 Cafe Ninjette Newsbot Motorcycling News 0 September 10th, 2011 01:00 AM
[motorcyclistonline] - Cafe Society - Cafe Racer Culture Ninjette Newsbot Motorcycling News 0 August 21st, 2009 10:00 PM
