Old June 5th, 2020, 03:44 PM   #1
Tsmith9233
Motorcycle(s): 03 ninja 250
Starting/idle issue
New poster here. I have an 03 bike with a 12 motor(allegedly). I have been waiting for the plate to come from my closed dmv, it came today and I suited up for a ride. Wouldn’t start, I put plugs in because I didn’t know their history. Now it will only start with choke off, throttle wide open and petcock to off. Won’t idle either. Everything is stock with carbs and airbox. And I seem to be getting a fair amount of gas from overflow hose onto ground. Help please. Thanks
Tsmith9233 is offline   Reply With Quote
Old June 5th, 2020, 04:00 PM   #2
ducatiman
ducatiman's Avatar
sure sounds like a runaway float valve, a carb pull in your future
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old June 5th, 2020, 05:04 PM   #3
Tsmith9233
Any chance that riding it might “loosen” things up? Bike has not been ridden in while, just started occasionally.
Old June 5th, 2020, 05:11 PM   #4
Not a chance. You have multiple issues. Such as dried rubber seals in petcock and carbs. With additional time, they will just dry up more and leak more. Usage won't matter. Same with clogged passageways in carbs. They will continue to accumulate more debris and dried petrol and get worse. Only fix is complete disassembly of carbs down to ever last individual components and thoroughly clean & scrub them to restore back to factory-fresh clean state.
Last futzed with by DannoXYZ; June 6th, 2020 at 04:16 AM.
Old June 5th, 2020, 05:13 PM   #5
Tsmith9233
Marvelous, I guess I know what tomorrow brings..
Old June 5th, 2020, 06:40 PM   #6
Here's latest illustrated guide to get you started:
https://www.ninjette.org/forums/show...87#post1267487
Old June 5th, 2020, 10:40 PM   #7
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Question - if someone is running their bike daily, using fuel stabilizer with their gas, how often do you recommend rebuilding/cleaning the 250 carbs? Not sure how often as there's no set maintanence schedule on em.
Old June 6th, 2020, 04:22 AM   #8
You'll want to plan ahead a bit. Get necessary equipment and supplies. Scrub brushes, ultrasonic cleaner, micro soda-blaster, etc.
Here's rebuild-kit for petcock: https://www.ebay.com/itm/312734032287
Rebuild-kit for carbs: https://www.ebay.com/itm/233439356307
Do search for "clean carbs ducatiman" here for tips.
Old June 6th, 2020, 06:32 AM   #9
ducatiman
ducatiman's Avatar
Specifically, in your set scenario above.....10 years is certainly reasonable, provided no running issues surface prior.
Generally speaking (many variables) any purchased used "new to you" bike, especially those gaining in years....again around 10 year a good general rule to service carbs....service including *full* seal/oring and float valve renewal. Contrary to popular belief they have a service life...never intended to last forever (exposed in a constant fuel environment) In addition, float valves are a moving service part, their viton tips DO wear.
Here's a pic of fuel rail seals from an original, untouched 25 year old set of Mikuni off a Ducati ....I'd submit these were done a little on the late side, the white corrosive drying and cracking the seals. Out and out dangerous in this instance, these leaking would be catastrophic.
So, I'll submit that 25 year interval is too long. I routinely encounter 10-12 year old 250 carb oring/seals that are compromised way beyond service life ...flattened, crystal hard, corroded, etc etc.
Custom Carb Service
Old June 6th, 2020, 07:19 AM   #10
Tsmith9233
So if I muddle through riding season, how much does it cost to have a pair of carbs professionally cleaned and rebuilt to stock specs? Thanks
Old June 6th, 2020, 07:52 AM   #11
ducatiman
ducatiman's Avatar
I'll contact via PM
For discussion purposes, I'm doing today a 19 year old set of SV650 Suzuki carbs....a float valve went runaway....filling the combustion chamber and crankcase with fuel. I'll submit this example of denying a refurb for 19 years also too long.
I'm thinking the 10 year threshold is safe and reasonable, again though...subject to variables.
Custom Carb Service
Old June 13th, 2020, 12:33 PM   #12
Tsmith9233
So, with the help of the folks in here, I swapped out the 03 carbs for 12’s... starts right up, no fuel pouring out of overflow, it idles and everything. Thanks to all who offered advice and assistance!!
Old June 13th, 2020, 02:48 PM   #13
Tsmith9233
I now have 2012 carbs on 2012 engine in 2003 chassis. Apparently everything is different. Thanks
Old June 13th, 2020, 03:12 PM   #14
Exterior parts are slightly different along with jet-sizes inside. I've used them back & forth without any issues. As long as you match jet-sizes to engine it's going on.
Good job getting that fixed!!
Last futzed with by DannoXYZ; June 13th, 2020 at 08:16 PM.
Idle mixture screws are at different heights? (Idling/Starting Problem) MegaEgg 1986 - 2007 Ninja 250R Tech Talk 30 March 6th, 2016 10:37 AM
Idle issue djjontran 1986 - 2007 Ninja 250R Tech Talk 27 August 18th, 2013 09:00 AM
idle issue PEN25 1986 - 2007 Ninja 250R Tech Talk 10 June 30th, 2013 02:14 PM
Weird Cold Starting Idle ajcadoo 2008 - 2012 Ninja 250R Tech Talk 9 March 6th, 2012 08:54 AM
Really low idle speed when starting??? HELP!! Ktaylor07 2008 - 2012 Ninja 250R Tech Talk 3 October 17th, 2011 09:57 PM
