Old June 5th, 2016, 06:43 PM   #1
lizardywizard
green stig
lizardywizard's Avatar
Motorcycle(s): '15 Ninja 300 ABS (Hurricane)
MOTM - May '16
Chain lube fling or something more sinister?
So since I got my bike back from the 600 mile service, I've been noticing this black stuff on the exhaust after every ride. (Imgur link because I'm on mobile and can't shrink the image down.)
At first I thought it was just road grime, but it keeps turning up. I wondered if maybe they just used different chain lube and this is the "fling-off" people talk about (I never had it before). But I couldn't find pictures of what fling-off should look like, so I thought I'd better double check.
Edit: ...wait, it can't be chain lube, the chain isn't even on the same freaking side. What the heck.
You treat her like a lady. And she'll always bring you home. --Admiral Leonard H. "Bones" McCoy
lizardywizard is offline   Reply With Quote
Old June 5th, 2016, 07:16 PM   #2
Just kidding
Is there any of the open-end hoses ending by that area?
Old June 5th, 2016, 07:41 PM   #3
lizardywizard
green stig
MOTM - May '16
Originally Posted by Motofool View Post
Just kidding
Not sure, but I just took a look around with a flashlight and couldn't see any. Lots of hoses, but they all seem to feed into something and none of them look like they're leaking anything.
Of course they are all black...
Also, if it aids in diagnosis, it didn't reappear after the short ride (~2 miles) from my previous stop to home. It's appeared after the last couple of long rides.
Old June 5th, 2016, 08:15 PM   #4
Overfilled rear brake reservoir?
Old June 5th, 2016, 08:56 PM   #5
lizardywizard
green stig
MOTM - May '16
Doesn't look like it. It's got one of those brake reservoir wristbands on it and I didn't see any staining or smell anything odd when I took it off, and the fluid level in there looks good. Oil level is likewise good.
Did another examination of the area and I'm really not sure what it could be. I don't see anything that looks like it could be leaking, except for this one part that has a rusty-smelling line of... something down it.
But it's pretty uniform so maybe that's supposed to be there. And it's also definitely brown, not black.
Old June 5th, 2016, 09:32 PM   #6
Your chain is on the other side, it is highly unlikely chain lube has made it to that location in that pattern. Check the heel area of your boot.
The other pics are from the air filter area. Perhaps they re lubed your filter and your getting some blowback.
Old June 5th, 2016, 09:33 PM   #7
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
That brown may very well be battery acid from a hot/overheating battery. I'd be pulling your seat and have a look. If it is, sprinkle it with baking soda and then hose it off.
After you clean it, start it up and check the charging voltage with a volt meter. It may be over charging the battery OR it may have just been a little hot.
Goin' fast on slow bikes!
Old June 5th, 2016, 10:01 PM   #8
lizardywizard
green stig
MOTM - May '16
Ohhh ouch. D:
It has been really hot here lately... and I've been riding in the heat... if that is the case, any tips to help prevent it in future? I live in SoCal, so not riding in the heat is kind of not an option...
Old June 5th, 2016, 10:04 PM   #9
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Originally Posted by lizardywizard View Post
Ohhh ouch. D:
Have a look first. If the battery is a wet cell type, there should be an overflow hose on it. Check to be sure the hose is hooked to the vent properly and routed out of the frame.
Old June 5th, 2016, 10:14 PM   #10
If it is acid, you will need a new battery. 300s come with stock with an YTX9 SEALED battery. There should be NO hoses. If it's leaking, it's garbage.
Old June 5th, 2016, 10:18 PM   #11
lizardywizard
green stig
MOTM - May '16
Okay, got the seat off. Seeing as I've never moved the battery before and the only time I've messed with it was under the supervision of someone who was extremely paranoid about me shocking myself, I'm wary of going further.
This is what I'm seeing so far:
http://m.imgur.com/FEOf3fm
http://m.imgur.com/G05pZPT
If the hose is the part in a sort of mesh-y sheath under that black and yellow wire it looks fine to me... looks all sealed and not seeing anything brown.
Old June 5th, 2016, 10:22 PM   #12
Go buy a lotto ticket, because you have a better chance of winning the lotto than getting shocked. Take off the top screws and have a peek under it. If it's leaking, it's going to go down. Just don't hook it up backward. RED goes to +, Black goes to -. Or simply follow the pics you just took.
Old June 5th, 2016, 10:27 PM   #13
Did you check the heel of your boot? 0 tools required mate.
Old June 5th, 2016, 10:29 PM   #14
lizardywizard
green stig
MOTM - May '16
Okay, took a look at battery - it looks fine. No leaks.
Got another one of the side panels off and I'm seeing this.
http://m.imgur.com/3b9GluS
Looks like the brown stuff's not dripping from anywhere, it's just all the way around. It looks like it might actually be some kind of sealant on that part, not a leak.
Nothing on my heel, just a few rocks.
Old June 5th, 2016, 10:32 PM   #15
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
HA! That's silicone on the airbox.
You're good. It was worth a look though and you learned something!
Old June 5th, 2016, 10:34 PM   #16
Cool! Oh, that brown stuff they put around joints and such. On a brand spanking new bike, some of that coming off is normal when it's really hot.
That don't look like the same stuff that is on your heat shield though. Some other thoughts;
Lube from swingarm pivot
Lube from shock linkages (I see you have aftermarket bones to lower or raise the bike)
Crush washer leaking (the 600 mile service should include an oil change, check for leaks by putting a piece of paper under the drain bolt overnight)
Oil fill cap not on tightly (again, part of 600 mile service)
Maybe you're simply stepping in something, where do you park your bike? Have you been riding the same route when the stuff appears? It doesn't appear on your short rides...
Ride through a construction zone? Perhaps it's some of that crap they spray down (sealant of some sort)
Old June 5th, 2016, 10:58 PM   #17
lizardywizard
green stig
MOTM - May '16
Sure did! Did a few things all on my own I've never done before (I've been under the seat, but only with someone else guiding me).
I'll do the paper trick, thanks. Then again, she's parked on a mat so I'd think the stain would be noticeable, but you never know. I did get an oil change, yeah.
Not the same route at all - I even specifically turned left instead of right out of my street yesterday because there were steel plates out there and a huge construction mess, but it's mostly died down today so I went right. So hardly anything on the route is the same, unless it's on my driveway.
I'll check out all the other stuff, see if anything looks particularly... lubey.
Old June 6th, 2016, 11:27 AM   #18
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
Dang, I found this thread way too late to be useful. But having read it, I wonder: do you have a copy of the service manual? Certainly makes identifying all these bits easier.
I'm serious about your moto maintenance erotic fiction career. Can't wait for the bike wash write up
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old June 6th, 2016, 11:55 AM   #19
lizardywizard
green stig
MOTM - May '16
Sadly not, just the owner's manual. I searched for service manuals online and it looks like they're crazy expensive... but also commonly available as free printable PDFs
Still haven't discovered the source of the original grime, alas.
Y'all don't know about my other career as a fanfiction author... if you did, you wouldn't be tempting that fate.
Old June 6th, 2016, 12:08 PM   #20
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
There is only one wash video worth watching and it's ninjette.org and work safe. Well; don't make it your screen saver!
http://www.youtube.com/watch?v=g0kiPBXe7O8&sns=em
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old June 6th, 2016, 12:48 PM   #21
lizardywizard
green stig
MOTM - May '16
Too much overdramatically posing woman, not enough Ninjette.
Old June 6th, 2016, 01:53 PM   #22
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Yup, that brown stuff is normal. My bike has that as well. That particular part (that the brown stuff is on) is called the snorkel. When people do a snorkel delete mod, that's the part they yank out. Your air filter looks really new as well.
Riding it like I financed it.
Chain Lube seth hall General Motorcycling Discussion 15 August 23rd, 2014 01:07 PM
Chain Lube OzzyDevil General Motorcycling Discussion 3 April 21st, 2012 07:41 AM
Chain Lube!? Trainsk8 2008 - 2012 Ninja 250R Tech Talk 16 August 3rd, 2011 12:43 AM
Chain Lube BobsPT 1986 - 2007 Ninja 250R Tech Talk 28 October 17th, 2010 08:49 AM
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review Ninjette Newsbot Motorcycling News 0 May 18th, 2009 09:50 PM
