Old December 30th, 2016, 01:20 PM   #1
ARD7.62
Motorcycle(s): 2005 Kawasaki Ninja 250r, 2005 Kawasaki ZX10R, 2005 Buell XB9SX
Howdy
I figured since I'm doing some work on my bike I might as well go ahead and say hi.
I bought an 05 with 1300 miles on it for $1100 and then proceeded to rack it up to 3900 in a few months.
Some problems started coming up like the stock tires balding, fork seals leaking to the point of the forks cluncking when i braked, no/bad idling, and petcock flowing when the motor is off.
This is my first (running) motorcycle and I'm hooked. I was planning on flipping the 250 in the spring, but damn it's a lot of fun.
I've sent my carbs off to ducatiman and they're probably the cleanest he's seen so far, but i want to start fresh.
So here is a pic of close to when i first got it and a pic of how it sits now.
2005 Kawasaki ZX10R
2005 Buell XB9SX
ARD7.62 is offline   Reply With Quote
Old December 30th, 2016, 01:35 PM   #2
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
ARD7.62! Glad you found us...
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old December 30th, 2016, 01:37 PM   #3
Welcome!
Sounds like your talking yourself in to keepin' it.
Old December 30th, 2016, 01:40 PM   #4
ARD7.62
Thanks!
And I'll add, for Ghostt, that I have an Arai Signet Q helmet, Joe Rocket jacket and pants, and Sidi boots. I also got my BRC and M endorsement.
Welcome!
Yeah I want to get a 600+cc this spring and make this 250 a track bike hopefully. That wont happen until I get a house. My wife will kill me if I spend anymore money until we have the down payment
2005 Kawasaki ZX10R
2005 Buell XB9SX
Old December 30th, 2016, 01:58 PM   #5
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Old December 30th, 2016, 02:11 PM   #6
Originally Posted by ARD7.62 View Post
...fork seals leaking to the point of the forks cluncking when i braked, no/bad idling, and petcock flowing when the motor is off. .
Hi Andrew, good to meet you.
Obviously leaking seals need to be addressed, but a clunk on braking is likely to be caused by loose head bearings. A simple adjustment may cure the clunk.
That's not a lot of miles, but difficulty idling could be caused by out of adjustment valves. That's what caused my 2005 to have difficulty idling, especially when cold. After I adjusted the valves it was like a different engine, starting easily, and with an idle that behaves after just a few seconds of warmup.
Old December 30th, 2016, 03:28 PM   #7
taz
taz's Avatar
MOTM - May '17
WELCOME
Old December 30th, 2016, 03:31 PM   #8
Oh, and I was able to fix my petcock's leak by replacing the size 007 Viton O-ring on the main plunger that's attached to the diaphragm.
Old December 30th, 2016, 03:45 PM   #9
ARD7.62
thanks everyone and thanks for the advice triple jim.
I'm going to check valves since I've already got it apart enough. It would also die if i stayed at 75+mph for too long.
I wasn't sure if i should get the gasket set or just get a new petcock assembly. Since it looks like its been sitting a while I think I'll just get a new one and be done with it. I know ethanol is not kind to anything. Also reserve does not work. I run out of gas, but it still has some in the tank.
I have the Haynes manual and have been looking for a decently priced FSM.
2005 Kawasaki ZX10R
2005 Buell XB9SX
Old December 30th, 2016, 04:09 PM   #10
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome! Looks like you're getting well-acquainted with your bike!
Old December 30th, 2016, 05:01 PM   #11
FSM?
Old December 30th, 2016, 05:37 PM   #12
ARD7.62
Originally Posted by Triple Jim View Post
FSM?
Factory Service Manual
It's what the dealership mechanics used.
I know that the haynes manual on my cx500 has incorrect torque values that if used will snap bolts
2005 Kawasaki ZX10R
2005 Buell XB9SX
Old December 30th, 2016, 06:34 PM   #13
Ah, not Female Seeking Male. There are probably a lot of guys looking for one of those at a reasonable price.
You should be able to find PDF files of the manuals. I got a CD from eBay. Note that you need two manuals for coverage, the base manual and the supplement that covers the later Pregen models. Both were on my CD, but some sellers offer just the supplement. When I went to remove my starter to clean and lubricate it, I found that information was in the base manual.
Old December 30th, 2016, 09:25 PM   #14
ARD7.62
haha no i don't think my wife would like that. I'll check that pdf out though.
2005 Kawasaki ZX10R
2005 Buell XB9SX
Old January 3rd, 2017, 10:49 AM   #15
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
hello.
TEAM ALFALFA
www.apexassassins.com
Old January 3rd, 2017, 10:52 AM   #16
VaFish
VaFish's Avatar
MOTM - Jan '16
Welcome
Old January 3rd, 2017, 02:05 PM   #17
ARD7.62
Thanks
2005 Kawasaki ZX10R
2005 Buell XB9SX
Old January 29th, 2017, 07:58 AM   #18
Snake
Snake's Avatar
Hello and welcome!
Howdy Alchemist New Members 8 May 27th, 2013 09:55 PM
My name is now, uh, my name. Howdy. CZroe New Members 4 April 19th, 2012 11:07 PM
Howdy Trash Can Man New Members 10 April 10th, 2012 04:48 PM
Howdy! nutless_neo New Members 18 September 11th, 2010 10:49 AM
Howdy! Alex New Members 11 December 9th, 2008 07:27 PM
