Old September 4th, 2017, 09:48 AM   #121
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Guess we will never know just how it went
Good show though
Old September 4th, 2017, 11:13 AM   #122
Ram Jet
Ram Jet's Avatar
Good show though
You should hit "quote" when posting because I don't know what show.
Just sayin'.
Bill
Old September 6th, 2017, 09:01 AM   #123
JohnnyBravo
Just sayin'.
Bill
I would have bought new parts far sooner, but seeing a person go through testing a wiring harness virtually was a bit amusing
Old September 6th, 2017, 02:16 PM   #124
gitter
Motorcycle(s): 20' Speed Triple RS - 95 ex250
Testing was a better option than blindly throwing parts at a problem.
Plus I went into it as a learning experience. Electrical work is definitely my automotive Achilles heel
gitter is offline   Reply With Quote
Old September 6th, 2017, 02:28 PM   #125
Yeah, you have to test to determine what's an effect and what's cause. Given the symptoms, he could have immediately replaced:
- tach
- fuel-gauge
- fuel-level sender
- left-coil
- IC-ignitor
Aside from ignitor, which we've tested to be bad, he would've replaced perfectly-working parts with brand-new perfectly-working parts. Which is still only dealing with symptoms/effects of problem. Wouldn't have fixed issues and most likely will have fried new IC-ignitor as well. Cause is shorts in wiring, which he found one and fixed; but there appears to be more.
And even then, shorts may be additional symptoms as well. Actual cause and problem may very well be sharp edge of metal somewhere on frame or tank that's scratching wires and creating shorts. He'll then have to replace harness with new one every 6-months as new shorts are created until real problem is found and addressed.
Old September 6th, 2017, 04:23 PM   #126
gitter
A bit of a side note, as far as the old cdi box that's bad, even though it looks like a sealed unit, is there any way to dissect / possibly repair it?
Old September 6th, 2017, 04:38 PM   #127
Ram Jet
Ram Jet's Avatar
I believe that's an impossibility unless the problem is in the wiring harness or connector.
Bill
Old September 6th, 2017, 05:42 PM   #128
Sure! There's a seam that can be gently split with razor/Xacto knife.
Trace from the black-wire terminal onto circuit board and you'll find driver-transistor. Get part# off it if not fried. Otherwise, should be same part# as one on green-wire side.
Desolder driver transistor and replace with new one.
That's how I'ved fixed many automotive ECUs. Mainly Bosch Motronic boxes from Porsches that get fried when people install low-impedance injectors without appropriate ballast resistors.
Old September 8th, 2017, 12:14 PM   #129
JohnnyBravo
- tach
- fuel-gauge
- fuel-level sender
- left-coil
- IC-ignitor
Haha not all of those parts... A new harness; bikes are way more complicated than the boats I used to rewire on a table before I jerked the harness out. Those and old stuff are the only electrical work I like; all this new rat best stuff makes my head spin
Old September 8th, 2017, 11:56 PM   #130
Flying
Motorcycle(s): 2010 Ninja 250
The CDI for the newgen is potted with polyurethane, its better to just replace it if you've figured its gone.
Old September 13th, 2017, 11:30 PM   #131
gitter
ebay wiring harness and cdi finally showed up. should hopefully have time to tackle some of it Friday.
Old September 15th, 2017, 06:55 PM   #132
gitter
Got the new wiring harness and cdi box in and hooked up today. Tested with noid' light and its getting signal to both coils. Fired up and sounds like its running on both cylinders.
Idle sticks and sits between 3000-5000rpm and it dies if you give it throttle. So carbs are my next adventure.
In any case, thank you everyone for all your help, its much appreciated
Old September 15th, 2017, 07:53 PM   #133
Ram Jet
Ram Jet's Avatar
These carbs are fussy. You need more than a tooth brush, piece of wire and some carb cleaner if they are really screwed-up. If they don't get sorted out the on the first attempt consider letting Ducatiman work them over. There are guys that have their carbs off and on three or four times and still don't get it right. Just sayin'.
Bill
Old September 15th, 2017, 08:24 PM   #134
gitter
Are they more finicky than pregen carbs?
Old September 15th, 2017, 08:45 PM   #135
About the same, I'd guess.
Old September 15th, 2017, 09:54 PM   #136
Ram Jet
Ram Jet's Avatar
I have a 2007 but the 2008 and later appear to be nearly the same looking at the parts diagram.
Bill
Old September 16th, 2017, 07:34 AM   #137
ducatiman
ducatiman's Avatar
needles, main jets, emulsion tubes , idle cabling, venting differ slightly
otherwise carb size, function same
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old September 16th, 2017, 05:21 PM   #138
Good job on repair!!! Did new harness fix tach and fuel-gauge too?
Old September 17th, 2017, 04:44 PM   #139
gitter
yup tach works, I cant remember off the top of my head if the fuel gauge moved, but the bike is currently on a rear stand so i dunno if that makes a difference in the gauge reading
09' Ninja 250 Running On One Cylinder jnr1114 2008 - 2012 Ninja 250R Tech Talk 24 February 26th, 2016 07:51 AM
'07 250 running one cylinder regelbrecha 1986 - 2007 Ninja 250R Tech Talk 5 March 7th, 2013 02:11 PM
Running on one cylinder. Not electrical? Kygirl 2008 - 2012 Ninja 250R Tech Talk 6 May 16th, 2012 12:50 PM
my 2010 ninja is running sluggish (HELP) venmichaels 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2012 07:13 AM
2006 Ninja 125... Only running on one cylinder? SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 8 February 7th, 2011 10:31 AM
