Old March 15th, 2024, 12:18 PM   #1
lilmusey
Motorcycle(s): 2005 Ninja ex250
Fuel not reaching carburetor.
Recently bought a new carb and cleaned it to the best of my ability, put it in the bike and the carburetor isn't receiving gas when I attempt to start it up. Any advice on what to do? (Pet-cock is set to on position and is above the carburetor so gravity can do its thing.)
lilmusey is offline   Reply With Quote
Old March 15th, 2024, 12:34 PM   #2
ducatiman
ducatiman's Avatar
petcock is vacuum type or gravity fed type? You've confirmed flow from the petcock? How? Remove hose from carb....use a cup to catch flow... provided it exists.
If flow exists, your float valves/fuel level settings may need testing.
As carbs are "new", I'll assume you've checked them?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 15th, 2024, 12:41 PM   #3
lilmusey
I have indeed checked the carb and cleaned them profusely. The petcock is a vacuum type, I checked for flow and I am not seeing any., After attempting to start it a few more times I pulled the gas hose off and saw 3 drops come out of it. Any possible solutions?
Old March 15th, 2024, 01:02 PM   #4
ducatiman
ducatiman's Avatar
you should have a hose from the LH carb brass "vac fitting" running to the petcock small vac fitting. Is it present?
Otherwise I'd surmise your petcock is clogged up. It DOES happen.
Custom Carb Service
Old March 15th, 2024, 01:02 PM   #5
There is a small fuel filter where the hose enters the carb. Sometimes it gets very clogged, and is jammed up the hose so you don't immediately see it. Even if this isn't the problem it's something to check.
Old March 15th, 2024, 02:34 PM   #6
lilmusey
I checked my petcock for debris and it was sparkling clean, I then attached the gas hose (that connects to the carb) to a plastic bottle with gas inside and it fired right up but died with throttle and when the choke was turned off. The pet-cock is clean but there could be something maybe obstructing the fuel from coming out. Will keep you guys updated so if someone else has an issue like this there will be a multiple solutions.
Old March 15th, 2024, 02:41 PM   #7
If you suck on the petcock's vacuum hose, does fuel then flow? It doesn't take much vacuum for it to open if it's working properly.
Old March 15th, 2024, 10:55 PM   #8
lilmusey
Found the issue, I basically didn't have enough gas in my tank. The petcock was fine and so was the carb, I just had to turned the setting to the "Res" so that the rest of the gas would flow into the carbs. Thank you to everyone who helped me out. Hopes this helps someone who might be having a similar issue.
Old March 16th, 2024, 05:52 AM   #9
Thanks for letting us know you found the "problem".
Old March 16th, 2024, 12:13 PM   #10
lilmusey
No problem 😂😂😂
Old March 18th, 2024, 09:52 PM   #11
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Glad you found the problem! (now remember to turn the petcock back to regular, so you don't get a nasty surprise by trying to turn it to res and it's already there)
Fuel pours out of carburetor overflow andthennugs 2008 - 2012 Ninja 250R Tech Talk 11 November 5th, 2017 05:51 PM
Carburetor vs Fuel Injection A.J. General Motorcycling Discussion 53 July 13th, 2017 10:30 AM
Carburetor Fuel Overflow Tube Replacement Jim Moore 1986 - 2007 Ninja 250R Tech Talk 6 June 18th, 2012 05:07 AM
Fuel Injector/Carburetor Cleaner paterick4o8 2008 - 2012 Ninja 250R Tech Talk 7 May 9th, 2010 05:16 PM
