June 12th, 2010, 12:06 AM | #1 |
Join Date: Mar 2010 Motorcycle(s): 2010 Ninja 250R (sold), 2012 Tuono V4R Posts: 512
So, I just picked up a GoPro Hero HD....
....so what else would I do but go record videos of the roads that I ride on?
So, I finally was able to get video that didn't look like it was shaking all over the place or sound like coins in a metal can.... so I did a quick and dirty job of editing and putting in some music.
2010 Kawasaki Ninja 250R - "Aria" (sold) 2012 Aprilia Tuono V4R - "Perrine" Proof that Harleys and Ninjettes are friendly with each other |
June 12th, 2010, 01:46 AM | #2 |
Join Date: Aug 2009 Motorcycle(s): 2014 Ninja 300, 2008 ZX6, 2011 Ninja 1000 Posts: 622
Crossing the double yellows in the dark, on a turn? Tsk tsk... The video looks good. Very clear and stable.
June 12th, 2010, 06:22 AM | #3 |
Yup, that was a major up. At least it's better than the first time I took this road and dropped it right on the 10mph right turn into the 7% grade. (Engine stalled out because I was taking the hill at a too high of a gear.)
June 15th, 2010, 10:59 AM | #4 |
noob motovlogger
Join Date: Dec 2009 Motorcycle(s): Black 2009 250r Posts: 328
that camera picks up the light really oddly. is this early morning or evening? also what's that light on the right side of your dash where the turn signal light usually is?
My Motovlog "Damn, either shimming the needles fixes 90% of any problems with the 250Rs, or kkim owns stock in a washer manufacturer." -DmbShn41 |
June 15th, 2010, 03:10 PM | #5 | |
This camera doesn't do too well at night, but that's okay.... it's to be expected. If you're talking that bluish light, that's my radar detector.
June 15th, 2010, 03:15 PM | #6 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
That's about the time it starts to cool off - I hate riding in the heat of the day with gear on. Radar detector could be useful at night.
June 15th, 2010, 10:59 PM | #7 |
The obligatory Lime Creek Road video. I've got the footage for the 620 to Volente stretch, I just didn't include that here.
June 16th, 2010, 12:00 AM | #8 |
Join Date: May 2010 Motorcycle(s): 2005 Ninja EX250, 2005 SV650S Posts: 34
Some pretty nice videos about what speed were they at? Just curious if the camera becomes less stable at speed.
and i was wondering what kind of radar detector do you have? |
June 16th, 2010, 08:28 AM | #9 | |
is 40 if I recall correctly. I was pretty much going around 40 except the parts where I was passing the Harleys. For that video, there are two problems with going faster: 1. Going 50-60mph on that road is inviting yourself to be removed from the gene pool 2. The camera was mounted on my helmet. I've tested the camera on the highway at 65mph and I tend to get a little bit of "head whiplash" depending on the direction of the wind. I'll probably use this camera mostly for twisties recording. The radar detector is a Escort Passport 9500xi. I did have to buy the direct-wire cord separately, but this will direct-wire fairly easily to the battery with some post connectors and solder. (Stupid 18 gauge wire.) I didn't use a relay because I'm taking this with me when I'm away from Aria....
September 2nd, 2010, 10:42 PM | #10 |
The New Big Guy
How good is the Escort Passport 9500xi? has it saved you from those cagers with colorful bright lights on top?
<--- The effect of seeing others ride the bike you REALLY REALLY want. |
December 1st, 2010, 04:54 PM | #11 |
sleeper
Join Date: Nov 2010 Motorcycle(s): '10 250r, '10 690 duke Posts: 558
put the go pro on setting 3 for video then go to spot..it will have better forward vision and it's more light sensitive..setting 3 is 720p but 60fps..super crisp and good res and lighting/color.
placement is also key. do you have the different housings as well? closed/watertight housing is best for speeds of 25+ mph great videos!! what are you using to edit? |
December 2nd, 2010, 12:17 PM | #12 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
Looks good
I have to get mine out and start using it. |
March 19th, 2011, 09:48 PM | #13 | |
I was using iMovie on my Mac to edit this, because I didn't feel like trying to set up AviSynth on my PC to do it. Yup. Unfortunately, around this area, it's starting to lose its effectiveness as the cops are starting to use laser instead.
March 26th, 2011, 01:31 PM | #14 |
Join Date: Oct 2010 Motorcycle(s): 93 ninja 250 Posts: 111
those things have some pretty sick video quality
GoPro Hero | modded | General Motorcycling Discussion | 13 | July 12th, 2013 03:02 PM |
GoPro Hero 3 deals? | Reyno2ac | Off-Topic | 4 | March 9th, 2013 08:19 PM |
GoPro Hero 1 Motorsport - Used | EMSRacer07 | Miscellaneous | 6 | November 17th, 2012 01:29 AM |
GoPro Hero 2 Warning | Scattcatt | Off-Topic | 4 | November 6th, 2012 08:02 PM |
GoPro Hero 3... | Byakkotai | General Motorcycling Discussion | 35 | October 25th, 2012 09:15 AM |
