Old June 7th, 2016, 03:45 PM   #7361
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Originally Posted by ZeroGravity360 View Post
It is only in the last couple weeks since ive been working on my bike (thank you youtube) that I have gained the confidence to learn my car.
Good for you! I think information is a very good thing, and knowing what things are supposed to look like...
Old June 7th, 2016, 04:23 PM   #7362
Ghostt
Ghostt's Avatar
Just be careful of some of those YOUTUBE videos, some are made by clown shoes, and not worth the time to even watch, and some are just BS.
My personal favorite
violente et ignorantia
ZX-2R BLOG
Old June 7th, 2016, 07:48 PM   #7363
Brother Michigan
Motorcycle(s): 2013 Ninja 300
FINALLY cleaned and lubed the chain and gave the trim pieces and shiny metal bits a good coat of silicone spray. I've been seriously commuting on it for the past month and it definitely needed it.
DISCLAIMER: I generally have no idea what I'm talking about.
Old June 9th, 2016, 07:01 PM   #7364
wendyjboss
wendyjboss
wendyjboss's Avatar
Motorcycle(s): 2015 Honda CBR 500RF (On its way), 2004 Kawasaki Ninja 250 (sold)
New tires and new brakes. Dunlop 630's.
wendyjboss is offline   Reply With Quote
Old June 9th, 2016, 09:27 PM   #7365
lizardywizard
green stig
lizardywizard's Avatar
Motorcycle(s): '15 Ninja 300 ABS (Hurricane)
MOTM - May '16
Hit 1000 miles on the odometer!
You treat her like a lady. And she'll always bring you home. --Admiral Leonard H. "Bones" McCoy
lizardywizard is offline   Reply With Quote
Old June 9th, 2016, 09:32 PM   #7366
CaliGrrl
CaliGrrl's Avatar
Nice milestone!
Old June 9th, 2016, 09:38 PM   #7367
lizardywizard
green stig
MOTM - May '16
Originally Posted by CaliGrrl View Post
Nice milestone!
Thank you!
Old June 10th, 2016, 05:27 AM   #7368
ZeroGravity360
Just sittin on my stool..
Motorcycle(s): 2012 Ninja 250
I just found out this is how you say diary in japanese:
Kanji : 日記
Meanings : diary
Kana reading: にっき
Romaji reading (pronunciation): nikki
My bikes name means diary in Japanese. So appropriate.
ZeroGravity360 is offline   Reply With Quote
Old June 10th, 2016, 09:17 AM   #7369
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Originally Posted by wendyjboss View Post
the neutral light does work, and usually if I have the Ninja in gear when the side stand is down, any forward motion will cause it to stall. I did not realize that it's not supposed to start at all in first.
The CDI igniter can use any of the three safety switches (sidestand, neutral, clutch) to provide ground for the bike to run. The starter relay grounds directly through the clutch switch, which also passes through to the neutral switch (separate from the igniter's connection to the neutral switch). The starter button should be dead unless you either have it in neutral or pull the clutch in.
The NewGen grounds the clutch switch through the sidestand switch. So holding the clutch to start it only works if you also have the sidestand up (as would be the case if you stalled at a stop sign or something). If it's parked in gear, just holding the clutch in won't allow it to start. This is probably a good little bit of extra protection, as it would probably lurch a bit before stalling when you released the clutch with it in gear (which sounds like what happened to you).
Old June 10th, 2016, 11:51 AM   #7370
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Ordered a new set of tires (going back to the IRC Road Winner).
Hopefully they last longer than 6k.
<-- Linky
Old June 10th, 2016, 11:53 AM   #7371
allanoue
allanoue's Avatar
MOTM - Sep '14
What is on it now?
Old June 10th, 2016, 11:58 AM   #7372
NevadaWolf
NevadaWolf's Avatar
Pilot Streets that are level with the wear bar. Probably got about 1000 left on them, but I'd rathr not encounter another completely worn down tire like I did week before last on the Honda. So, replacing now (well, next week when they come in).
<-- Linky
Old June 10th, 2016, 09:30 PM   #7373
lizardywizard
green stig
MOTM - May '16
Put some clear coat on some of her shallower scratches with a clear coat pen. We'll see tomorrow if it buffs out looking anything like good.
Also, took her to the dealership to get her dented tank replaced (it was dented when I bought her, the dealership owed me a new one). Unfortunately they'd ordered in the wrong colour by accident... grey instead of green... I didn't even know Ninjettes came in grey! So all my waiting was for naught.
I did draw this on the magnetic doodle board, though.
And got greeted with "hey Kawi" by the one guy at the dealership who I chatted with about bikes the last time I was there. Nickname accepted.
Old June 11th, 2016, 10:11 PM   #7374
lizardywizard
green stig
MOTM - May '16
...and today I rode her next to an honest to god one-percenter MC for the first time Not intentionally, we were just on the same road for a bit and wound up at the same red light, and one of them looked at me and I nodded and hoped that was okay.
I kind of took off like a shot at the light change and was terrified they'd think I was trying to race them but they didn't seem to care. Even used their turn signals
I'd been wondering why there was an entire platoon of motorcycle cops coming off a side road a few miles back. Sure enough, on the ride home a couple of them had been pulled over and were being talked to.
Old June 11th, 2016, 10:36 PM   #7375
NevadaWolf
NevadaWolf's Avatar
Added another 500 miles to the odo. Trying to relearn how to ride the Ninjette, man this bike is tiny after riding the Honda. But all day back in the saddle and crossing over two Sierra passes really helped get the muscle memory back.
Here's hoping I do get my vacation this month.
<-- Linky
Old June 12th, 2016, 07:03 AM   #7376
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Took her to the gap for a few days
Old June 12th, 2016, 01:12 PM   #7377
Twisthem488
Twisthem488's Avatar
Motorcycle(s): 2009 Ninjette
Changing my oil, and cleaning the chain I stumbled upon this:
Its been about 300 miles since I've checked it. I've been told to not trust clip style master links. Looks like I'm gonna try the rivet style this time. Sadly the motorsports store is closed Sundays. Might as well change the front brake lines while I'm stranded!
Twisthem488 is offline   Reply With Quote
Old June 12th, 2016, 01:52 PM   #7378
Ghostt
Ghostt's Avatar
Not for nothing, but maybe I'm just lucky but I've never had that happen to my clip style chains
ZX-2R BLOG
Old June 13th, 2016, 07:23 AM   #7379
allanoue
allanoue's Avatar
MOTM - Sep '14
Failed to remove the front sprocket. I hope it does not cost to much to get it done after my SNAFU
Old June 13th, 2016, 07:43 AM   #7380
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
You are fortunate. I had it happen on my SV650 racebike more than once. And that was [I]after[I]I did the little safety wire loop and a dab of silicone. Now I don't mess with a clip style master link and just go straight for the rivet style.
tgold is offline   Reply With Quote
Old June 13th, 2016, 10:04 AM   #7381
Ghostt
Ghostt's Avatar
Doing some testing on 30s Vs 32s carburetors
https://www.ninjette.org/forums/show...wpost&t=269055
32s were OEM carburetors for 86 & 87 Ninjette, 30s for 88~07 Ninjette.
Thanks to Ducatiman for trusting me enough to test these for him, and to see if there's issues with installing them on a 88~07, as this was his idea, and I'm more than happy help.
The 32s are a direct bolt on swap, with no changes needed.
ZX-2R BLOG
Last futzed with by Ghostt; June 17th, 2016 at 03:36 AM.
Old June 17th, 2016, 05:47 AM   #7382
ZeroGravity360
Officially signed up and paid for a MSF course wooh $$$$ Got someone to take my shift at word :-p soooooooo i can now take it -____- bye bye money... I REALLY hope its worth it, im going to be broke the next week...
Old June 17th, 2016, 06:37 AM   #7383
mgentz
Board Member
Any thoughts?
Old June 17th, 2016, 06:41 AM   #7384
Good to hear. Because you have been riding, you will know some of what they will be teaching you about handling the cycle but there may also be bad habits that you've picked-up that need to be changed.
Work on learning to really apply the brakes hard. It's something that many new riders are hesitant to do, but is a very important skill to learn.
My youngest son (16) is taking his second day of the MSF course today. He has been riding dirt bikes since he was 4, and needs to change some of his dirt-riding habits that he has developed. A lot of what they teach is very basic, and designed for the student that has never ridden before - so you will need to be patient.
Come back and let us know what you think of the course when you are done.
Good luck and have fun!
Old June 17th, 2016, 08:29 AM   #7385
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Yes. Every cent.
Good luck!
Raven's Rejuvenation
Old June 17th, 2016, 09:01 AM   #7386
Ghostt
Ghostt's Avatar
Originally Posted by mgentz View Post
Any thoughts?
Yes, See the thread for information.
ZX-2R BLOG
Old June 17th, 2016, 10:12 AM   #7387
ZeroGravity360
Will do! it is july 1,2 and 3 so REALLY soon! only two week!!! omg, finally! $$$ has been the biggest obstacle for me, mainly because I spend my money I stuff I shouldnt? lol, so I finally saved enough for the local course! I should have signed up back in march, but all the classes were filled until September. I was lucky that a new course popped up the last couple days!
Old June 17th, 2016, 10:41 AM   #7388
Not sure what they get for it in your area, but the total cost in the Madison WI area was $277.00. Not cheap, but if you are under 18 I believe it's required in order to get a cycle license in WI.
Go into it open-minded and relaxed. Have fun, and know that you are doing the right thing to get started for a lifetime of riding.
Old June 17th, 2016, 12:21 PM   #7389
Ghostt
Ghostt's Avatar
@ZeroGravity360 it will also save you $$$ on insurance, don't forget to report it to your insurance company ASAP.
I understand insurance rates are higher for younger riders, fortunately I don't have to worry about that at my age.
ZX-2R BLOG
Old June 17th, 2016, 01:59 PM   #7390
CaliGrrl
CaliGrrl's Avatar
Excellent! I gained a lot from the course I took. And yeah, it was more than a few bucks, but worth it. I'm kind of a broken record when I talk to people, because especially if someone is nervous about wanting to learn to ride, I always recommend the class.
Old June 18th, 2016, 01:00 PM   #7391
ZeroGravity360
Nikki, you are a goddess.
Cleaned her disgusting chain, put the decals on her, rim tape and gave her a washing <3
Old June 18th, 2016, 02:22 PM   #7392
LittleRedNinjette
Newgen master cylinder installed. New brake pads too. Valve adjustment done.
Old June 18th, 2016, 04:02 PM   #7393
Ghostt
Ghostt's Avatar
Did you service the calipers?
ZX-2R BLOG
Old June 18th, 2016, 04:43 PM   #7394
ZeroGravity360
This is sort of related to this thread, when I was cleaning my chain today I put in in gear while on my stand and it seems that there is a little snag in it. I kind of flings the top of the chain once a turn. like i said it was DISGUSTING! The previous owner was horrible. I used and entire can of cleaner and my hands still were dirty after i touched it. when is a good time to just replace it? or is there something I can do to repair it
Old June 18th, 2016, 05:53 PM   #7395
LittleRedNinjette
No... just flushed out some yucky fluid.
Old June 18th, 2016, 06:16 PM   #7396
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Finally got the ninja back from the shop yesterday so I got to ride it for the first time in over a year. Holy crap I forgot how gutless the ninjette is lol
My Ninja 300
Old June 18th, 2016, 07:47 PM   #7397
Ghostt
Ghostt's Avatar
Seriously calipers need to be serviced with every pad change, thus assures the braking system is working perfectly, anything less is irresponsible IMHO.
Write-up available upon request, it's quick and easy enough to do,
what's your personal safety worth?
ZX-2R BLOG
Old June 18th, 2016, 07:58 PM   #7398
Ghostt
Ghostt's Avatar
Did you mean a tight spot when rotating the chain. If that's the case, you could try lubing the hell out it, but most likely a new chain is in your future, and sprockets too.
ZX-2R BLOG
Old June 18th, 2016, 08:48 PM   #7399
algs26
Motorcycle(s): ex300, gave up looking for a 250
Nice. Is this the new iPad Pro with the Apple pencil?
algs26 is offline   Reply With Quote
Old June 18th, 2016, 08:58 PM   #7400
algs26
Says the person with the wheelie bike.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
