Old February 2nd, 2014, 11:22 AM   #1
chillbr0412
Motorcycle(s): 2010 Ninja 250 2005 ZX10R
Plastic Rivet
Hey everyone. Looking for some help. Can anyone tell me the sizes of the plastic push in rivets for the bottom part of the fairings? Thanks!
chillbr0412 is offline   Reply With Quote
Old February 2nd, 2014, 11:31 AM   #2
corksil
Motorcycle(s): A lot.
If this isn't in a sticky/faq somewhere I'd be surprised.
I'm going to look up the sizes/etc right now and try and find some part numbers because all my plastic connectors are broken/lost/non-existent from PO.
edit....
So the well nuts are #92210-0498 (5mm, qty listed = ten, but from the looks of it you might need a few more.)
The smaller push-type rivets that hold the (colored) fairings to the front upper/under/black cowling are #92039-0060 and qty listed = 6, which is indeed correct.
And the three push-type rivets you need to hold the two (colored) fairings together along the bottom are #92039-0014. Qty listed = 3.
Then there are the silver socket head screws/washers that hold everything together but you can look those up for yourself because there are different lengths.
It's all in the sticky at the top of this tech-talk section. Go to part diagrams and it will link you to kawasaki part schematics.
Old February 2nd, 2014, 12:14 PM   #3
corksil
Does anyone know where to get these oem parts for cheap?
I just totalled up 68 dollars for a few tiny screws and push fit connectors... Outrageous.
4 dollars for a single well-nut? There must be a better way. Unfortunately no junkyards around...
Old February 2nd, 2014, 01:49 PM   #4
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Nuts and bolts, Ace, Home depot, Lowes, or other such home place.
Well nuts, check a bike store for windshield bolt kit. That's where I got my replacements.
<-- Linky
Old February 2nd, 2014, 03:17 PM   #5
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
OEM part wise, partzilla.com is pretty good. Their shipping used to be better for under $10 orders, but now not so much, so you would want to order as much as you could in one order so you don't spend so much on shipping.
linkinpark9812 is offline   Reply With Quote
Old February 2nd, 2014, 09:56 PM   #6
corksil
You can generally call a company and explain how you don't need the parts right away and they can be shipped via USPS for much cheaper than the pre-calculated UPS/fedex rates posted up based on the shipping algorithym.
I'll look into the part numbers when I have them in front of me. Thanks. 68 bucks for 9 rivets, two screws, four washers, and two clips wasn't looking very agreeable on my budget.
Thanks dude.
Old February 3rd, 2014, 06:30 AM   #7
mgentz
Board Member
I do not know the sizes off the top of my head, but http://www.clipsandfasteners.com/ is a great site to go to for cheap fasteners.
Old February 3rd, 2014, 02:37 PM   #8
corksil
Thanks guys, partzilla ended up being HALF of what all the other OEM part places wanted to charge.
Good tip.
Old February 4th, 2014, 12:25 AM   #9
linkinpark9812
Good tip.
Curious, did you try calling to see if they would do a cheaper USPS shipping? I may have to try that the next time I order from them.
Old February 4th, 2014, 02:04 AM   #10
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
For future reference, you really don't need to get OEM for things like nylon rivets and well nuts. They're just standard parts and they're not super special. Figure out the size of the thing you need an buy a cheaper large pack of them rather than getting ripped off by an OEM parts dealer or a dealership. Getting the larger pack also gives you the benefit of having extra parts lying around if you need them later.
Old February 4th, 2014, 12:03 PM   #11
corksil
Havent ordered yet.
Old February 4th, 2014, 12:49 PM   #12
DaBlue1
DaBlue1's Avatar
Havent ordered yet.
Give Bolt Motorcycle Hardware a look.
http://www.boltmotorcyclehardware.com/products/sport-bike/windscreen-fasteners.html
http://www.boltmotorcyclehardware.com/products/sport-bike/sport-bike-rivets.html
I got these two kits and everything fits fine.
Old February 4th, 2014, 01:36 PM   #13
rasta
Your face
rasta's Avatar
**** those rivets, I use small zip ties lol
Old February 4th, 2014, 01:39 PM   #14
tfkrocks
tfkrocks's Avatar
Cycle gear sells 10-packs of the rivets
Old February 4th, 2014, 01:56 PM   #15
rasta
Your face
rasta's Avatar
Actually, the rivets that connect the two side fairings at the bottom are in use. It's those smaller rivets that connect the fairings to the black plastic trim that are annoying. I use zip ties there
Old February 4th, 2014, 01:57 PM   #16
tfkrocks
tfkrocks's Avatar
Doesn't cutting them off and replacing them in order to take apart the bike get old?
Old February 4th, 2014, 02:29 PM   #17
rasta
Your face
rasta's Avatar
Absolutely...but I found removing the rivets much more annoying. They would never come off as easily as their big brothers at the bottom of the bike.
Old February 4th, 2014, 03:02 PM   #18
tfkrocks
tfkrocks's Avatar
Maybe you just need to work on your technique
Old February 4th, 2014, 03:08 PM   #19
NevadaWolf
NevadaWolf's Avatar
@rasta are you talking about the small rivets that attach the radiator cowl to the lower fairings? Look like this...
All you need to do is use the small hex key you used on the little bolts to push in on the center of the rivet. It pops in once and the whole thing comes out easily. To reinsert, you just pushthe center part back out (to resemble the above pic), put it back in the holes of the cowling, and push the center into its locked position flush with the rest.
<-- Linky
Old February 4th, 2014, 03:11 PM   #20
rasta
Your face
rasta's Avatar
Hmm.....I do admit I hadn't thought about using a hex key to push it out. I tried using my finger, which was not effective . Maybe I'll get some more of those rivets....after I run out of the zip ties
Old February 4th, 2014, 03:13 PM   #21
tfkrocks
tfkrocks's Avatar
Well there's your problem. Using a hex key to push in the center really makes it easy.
Old February 4th, 2014, 03:16 PM   #22
NevadaWolf
NevadaWolf's Avatar
In. Push it in.
Have to admit I actually read that trick from the removing the fairings diy here. Before that I was using a small screw driver to pry the stupid things off. Still hate the lower larger rivets with a passion. One day I am just going to Velcro the crap out of the bottom and leave the rivets out.
<-- Linky
Old February 4th, 2014, 03:17 PM   #23
tfkrocks
tfkrocks's Avatar
It also helps if your nails aren't too short.
Old February 4th, 2014, 03:26 PM   #24
NevadaWolf
NevadaWolf's Avatar
So, like, what? A common nail over a roofing nail?
<-- Linky
Old February 4th, 2014, 03:47 PM   #25
tfkrocks
tfkrocks's Avatar
Fingernails
Old February 4th, 2014, 04:10 PM   #26
rasta
Your face
rasta's Avatar
So...I'm supposed to push this way..?
Old February 4th, 2014, 05:02 PM   #27
tfkrocks
tfkrocks's Avatar
Yessir
Old February 4th, 2014, 05:06 PM   #28
NevadaWolf
NevadaWolf's Avatar
Yeah, it'll push it into the outer sleeve, somehow releasing the tension holding it in place, then you can simply pull it out.
<-- Linky
Old February 4th, 2014, 06:58 PM   #29
mania
mania's Avatar
Motorcycle(s): 2013 250
A bag of 7 goes for $1 here in Asia at the Kawasaki Dealer
(The common push pins that are used all around the inner fairings Like Nevada Wolf posted)
mania is offline   Reply With Quote
Old February 4th, 2014, 09:24 PM   #30
rasta
Your face
rasta's Avatar
Push it in to pull it out, that's intuitive
Old February 4th, 2014, 09:39 PM   #31
NevadaWolf
NevadaWolf's Avatar
Bout as intuitive as clicking Start to shut down the computer.
<-- Linky
Old February 5th, 2014, 07:40 AM   #32
Should I? Scroll down to find out.
YES I should! That's what she said. hahahahaha
Old February 6th, 2014, 08:28 AM   #33
chillbr0412
Originally Posted by DaBlue1 View Post
Thank you!
Old January 9th, 2019, 11:46 AM   #34
timinmaine
Motorcycle(s): ninja 250, katana 600, 150 project
Partzilla for the plastic fairing rivets
Just ordered from Partzilla - very quick and easy. Recommend/+1 on whoever mentioned them.
timinmaine is offline   Reply With Quote
Old January 9th, 2019, 06:53 PM   #35
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
yup lowes has a ton of them. i use them on the side cowls too.
"trying not to get old"
Old January 10th, 2019, 07:02 AM   #36
Another source of odd OEM replacement fasteners is your local NAPA store.
Mine has a display with about a hundred different styles of reusable plastic rivets and other OEM style fasteners.
There's no system to match them by number, so you need to bring in what you have and do your best to find the match.
Old January 10th, 2019, 11:12 AM   #37
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
There's nothing motorcycle-specific or brand-specific about any of this stuff.
The well nuts are M5. Google that and you'll find dozens of sources, from Amazon to ebay.
Plastic rivets exist to hold two panels together. That's it. All that matters is the diameter of the hole. It doesn't have to match the OEM piece. It doesn't even have to be a plastic push rivet at all. Use your imagination and think of what you're trying to accomplish.
Auto parts stores are a good source for the plastic bits.
Old January 10th, 2019, 07:22 PM   #38
Bah!!! Just use pop-rivets!!!
Old January 11th, 2019, 08:17 AM   #39
adouglas
adouglas's Avatar
That's WAY too fancy.
Zip ties are where it's at, man.
Old January 11th, 2019, 09:52 AM   #40
Don't forget the classic hack - duct tape!
How to install a rivet style chain Alex General Motorcycling Discussion 4 June 25th, 2014 02:34 PM
RK 520XSO Chain Clip vs Rivet Master Link agentbad 1986 - 2007 Ninja 250R Tech Talk 5 May 15th, 2014 07:35 PM
Rivet instead of screw on fairing? tsdexter 2008 - 2012 Ninja 250R Tech Talk 26 June 21st, 2013 12:11 PM
Adding a rivet master link to the stock chain ??? Tiane 2008 - 2012 Ninja 250R Tech Talk 1 June 13th, 2012 12:58 AM
Rivet Replacements Ash 2008 - 2012 Ninja 250R Tech Talk 5 September 20th, 2009 03:29 PM
