Old June 19th, 2015, 02:12 PM   #1
Gears and Gasoline
Motorcycle(s): 09 Ninja 250R
lowering the 250r
I've got a newb question.
I've been looking to lower my 09 250R for a few reasons,
-I don't like the obvious skinny rear tire, and lowering helps
-I have a fender eliminator and i think there's a huge gap (i want a tire hugger too)
-I'd like to lower the seat height even more (i'm a short guy).
However, everything i've read about lowering it says to not do it because it messes up the balance. I love how nimble the 250 is and i don't want to mess that up. Are there any good options out there for lowering it without messing things up? lowering the front and the back i guess?
Gears and Gasoline is offline   Reply With Quote
Old June 19th, 2015, 02:16 PM   #2
liberpolly
Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold.
Nope.
Screw the inscrutable, eff the ineffable.
liberpolly is offline   Reply With Quote
Old June 19th, 2015, 03:01 PM   #3
johncrist1988
johncrist1988's Avatar
Motorcycle(s): 2006 EX250-F "Sheldon" (Sold), 2010 Ninja 250R "Zeke"
Originally Posted by Gears and Gasoline View Post
...everything i've read about lowering it says to not do it...
That's basically it. Can you physically do it? Yes. You'll have to completely retune your suspension, it'll still handle differently, but you can do it.
For reference, I'm 5' 4", 180lbs dry on a good day. I have to stand on my toes, but it's not that uncomfortable with the riding shoes I wear. I don't even notice.
johncrist1988 is offline   Reply With Quote
Old June 19th, 2015, 06:53 PM   #4
Oh goodness, misdirection in this thread.
If you lower (or raise) the front and rear the same amount, the geometry will not change, only the height. Within reason (about an inch, I'd guess) you will be alright with suspension travel and not contacting body work if you bottom out. More than that, and I'd bet you'll touch the front fender on the nose, and we've seen people rub the rear tire on the undertail. As long as you don't get crazy on how far you lower it, you will not have to worry about the suspension at all, or changing the dynamics of the bike through changing the head angle.
for the rear: lowering links. some are adjustable, some are set.
for the front: lowering blocks. These go between the risers and the triple. I think an inch is it here. Go much further and you'll need longer cables and brake hose. You also could get 36mm clip ons and lower the forks in the triples.
Now, why exaclty are you lowering this? I see that you want smaller gaps, lower tail, and fatter tire. ummmmmm... well... okay. FWIW: it's a sport bike, general motto is face down, ass up, that's the way we like to... you get the idea. Most people seem to raise the tail, myself included. and lowering for smaller gaps; this isn't a ricer, dooood. It just isn't.
Anyhow, being short I can understand. I don't agree with it, but I can see a legitimate reason there. Think an inch will help? More than that and it can potentially get more expensive.
Old June 19th, 2015, 07:52 PM   #5
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Don't you have to get a lower kick stand too?
Be careful. Remember you are
invisible
Old June 19th, 2015, 07:54 PM   #6
snot
sammich maker
snot's Avatar
MOTM - Apr '15
try adding a gel heal only insole to your boots. it will help, I doubled up a heal and full insole.
I
Old June 19th, 2015, 10:15 PM   #7
Flying
Motorcycle(s): 2010 Ninja 250
Kickstand mount allows a bit of flexion, a few inches shouldn't significantly matter. Not to mention that the bike is quite tilted to left side anyway when parked.
Old June 19th, 2015, 10:20 PM   #8
verboten1
verboten1's Avatar
MOTM - June '15
The front end of my bike was LOW. Quicker steering, but didn't change much else.
Ride more, worry less.
Old June 19th, 2015, 10:28 PM   #9
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
Did you measure how much of the fork was exposed from the triple?
Floki is offline   Reply With Quote
Old June 19th, 2015, 10:31 PM   #10
verboten1
verboten1's Avatar
MOTM - June '15
Those woodcraft clipons were mounted on top of the triple. And it was about flush to the top of the clamps.
Last futzed with by verboten1; June 20th, 2015 at 08:54 AM.
Old June 20th, 2015, 09:45 AM   #11
Gears and Gasoline
Okay, so these two items?
http://www.amazon.com/New-Kawasaki-N.../dp/B006M5KVEW
http://www.amazon.com/Kawasaki-Ninja...xgy_263_text_y
wont that raise my handlebars too? so I'd have to get something else to lower the handlebars back down.. I don't think I'll need to lower the bike more than an inch really.. I think taller shoes are just a workaround and doesn't make it much easier anyway. It's like walking on stilts, it's not as easy as walking barefoot. and don't flame me for this, but i'm not going to wear boots all the time, it's a commuter bike so i'm often in dress shoes (still wear a jacket, gloves, and helmet obviously).
Old June 20th, 2015, 01:20 PM   #12
verboten1
verboten1's Avatar
MOTM - June '15
Thinking about the lowering thing, if you slide the triple down the forks, and use a riser to offset that, the bars will actually be in the same place they were.
Wear boots. My wife probably would have lost most of her foot had she been in shoes.
https://www.ninjette.org/forums/showthread.php?t=233444
Old June 22nd, 2015, 07:16 AM   #13
Gears and Gasoline
I'm going to get the riser blocks to lower the front one inch, and the link to lower the rear one inch. that should keep the ride the same, but the height one inch lower..
Old June 22nd, 2015, 03:15 PM   #14
johncrist1988
I see I've been understanding lowering dynamics completely wrong then. I thought it would significantly alter the bike's handling.
I might just have to give this a go as well
Old June 23rd, 2015, 11:38 AM   #15
Gears and Gasoline
Yeah I think 1 inch is fine, 2 inches is probably not good..
https://www.youtube.com/watch?v=emFS2RnVDRM
Old June 23rd, 2015, 11:44 AM   #16
He is saying that stuff because he blindly lowered the bike without addressing the rest of the suspension settings, like preload and compression. And common... potholes are just that. Unpredictable at best.
Basically at a high level, if you lower the bike... your gunna have to account for suspension travel in BOTH directions. Otherwise, stuff like that happens.
FS: 08-12 250R Roaring Toyz Lowering Blocks/Handlebar Risers DJK Motorcycle-related 7 July 8th, 2014 06:25 PM
Roaring Toyz Lowering Kit 250R TedBull Motorcycle-related 3 April 21st, 2013 09:11 PM
Looking for a lowering kit for 1G 250R (2007) chkaotic Items Wanted 0 October 6th, 2010 11:17 AM
DIY: Lowering the back with Roaring Toyz lowering links noche_caliente 2008 - 2012 Ninja 250R Tech Talk 49 July 26th, 2010 12:22 PM
