Old May 5th, 2014, 08:58 AM   #1
LoMBoY_21
Motorcycle(s): ninja 250r
tires upgrade.?
hi, good eve fellow ninja.
i just want to ask, what size are the maximum we can put for our rear tire?
160/60, 150/60, 140/70?
i'm not into top speed concern, i'm more on looks.
btw, i'm using our stock rims.
TIA.
LoMBoY_21 is offline   Reply With Quote
Old May 5th, 2014, 09:09 AM   #2
150 and depending on brand/model it will pinch or have clearance issues with the chain guard. A 107 link chain, will solve the clearance issue but not the pinch. Search around the forums here, I believe the 150 michelins were a direct mount with the stock bits and little to no pinching.
Old May 6th, 2014, 06:04 AM   #3
LoMBoY_21
Thanks sir, do you have pics? Can i see your 150 rear?
TIA again sir.
Old May 6th, 2014, 06:13 AM   #4
Sorry, I don't run a 150 rear but you can see some pics in this thread as well as others.
Old May 6th, 2014, 06:46 AM   #5
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@LoMBoY_21 - for info, the 150/60 Pirelli is no problem - I got it with a 4 inch rim.
But when you look for the widest one then go with the Battlax 140/70, since I've seen here that even the 130/70 Battlax looks as wide as my 150/60 Pirelli. With the 140 maybe there could be a clearance issue already (this idk)?
And with the 160/60, like @csmith12 already said, you'll have a clearance issue with the chain (maybe not with the Pirelli since this is the smallest of all makes).
Old May 6th, 2014, 08:20 AM   #6
sonny4472
sonny4472's Avatar
Motorcycle(s): 09 250r, 09 1125r, 95 Virago
Tires aren't farkles!
I went with a BT003 140 on the rear and it's damn near perfect. Smooth transition and plenty of grip at lean.
sonny4472 is offline   Reply With Quote
Old May 14th, 2014, 03:56 PM   #7
Pretty sure you mean 108 links, since the links alternate and aren't identical. I have seen some chains with plates that weren't flat so that all links fit into each other and were identical, but I doubt there are any motorcycle chains like that.
Tires tires tires '90 250 mr2peak General Motorcycling Discussion 4 April 4th, 2014 08:53 AM
To upgrade or not to upgrade... neldy General Motorcycling Discussion 19 August 29th, 2011 10:21 PM
Tires Tires Tires (ZZR) mohns6062 1986 - 2007 Ninja 250R Tech Talk 20 June 15th, 2011 11:57 AM
What tires to upgrade to? jon148 2008 - 2012 Ninja 250R Tech Talk 1 November 27th, 2009 12:15 AM
