Old February 14th, 2016, 07:14 PM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
2009 250 Track bike build thread
I bought a 2009 250, totally stock with 3400 miles on the clock back in November
This will be a dedicated track bike. Not doing any racing yet, maybe after I get comfortable doing track days.
I acquired some Shark Skinz bodywork that had been crashed but repaired, I am currently painting them black. Paid $400 for them
Got some WoodCraft Rearsets and clipons
Full M4 exhaust
K&N pod filter
Factory Pro Jet kit
Racetech .90 springs, with 20wt oil (I am 215lb)
GSXR rear shock, with GSXR 1000 spring. New dogbones to restore ride height.
Slingshot racing pre-load adjusters
Woodcraft ignition delete
Galfer SS front brake line
Rear brake res delete
Dunlop Alpha 13's
will add pics of progress.
daverdfw is offline   Reply With Quote
Old February 14th, 2016, 07:31 PM   #2
daverdfw
Just wanted to say thanks to all the nice folks here that have helped with advice! Thanks!
Old February 15th, 2016, 09:48 AM   #3
Yamahawk
Chaplain
Yamahawk's Avatar
Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1
Sounds like a nice build Dave, will be looking forward to seeing some pictures!
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something
Yamahawk is offline   Reply With Quote
Old February 15th, 2016, 08:15 PM   #4
daverdfw
here are some pics with the fairings test fitted.
Old March 7th, 2016, 12:17 PM   #5
daverdfw
First track day in the books! NO major issues. Lost one DZUS fastener. And have a slight oil leak on right side of engine. Not enough to drop into the belly pan. I think I might have slightly overfilled the oil, so It could be that or a valve cover gasket, or the crush washers on the oil line banjo bolt. Will have to inspect.
Here are the before pics, Will have some track shots later in the week. Huge thanks to everyone on this forum for answering my many questions over the past few months!
Old March 7th, 2016, 01:57 PM   #6
daverdfw
and some video
https://www.youtube.com/watch?v=ZkCTyUC0woA
Old March 7th, 2016, 02:06 PM   #7
daverdfw
I also think my jetting need to be tweaked, running a 112 Factory Pro, When I would get to around 8kRPM WOT it wouldn't pull to redline very hard
Old March 7th, 2016, 02:10 PM   #8
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Since you don't have the factory airbox, where does your crank breather go? The oil may be coming from that....
Goin' fast on slow bikes!
Old March 7th, 2016, 02:12 PM   #9
daverdfw
I have a small pod filter on it. The oil is splashed from near the banjo, to up and back toward the rear of the engine. So from the airflow it obviously makes it harder to pinpoint where the leak is. ON my test rides, where I didnt get it to redline. There were no signs of a leak. Only after this track day did this show up. My oil is definitely too full. I am going to drain and refill but not sure that is the cause for this.
Old March 7th, 2016, 02:17 PM   #10
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I would say it's from your crank breather. This is pretty normal on a small Ninja for a track day, where the engine spends a lot of it's time near red line and the oil gets hot.
When I bought my track bike, there was oil in the belly pan. I traced this to the airbox where the factory breather goes. In our club, we have to block the airbox drain. However, this owner had not drained the oil out of the airbox for quite some time and it was starting to leak from the air box seam.
I wouldn't worry about this too much, especially since you have over filled it.
Old March 7th, 2016, 02:21 PM   #11
daverdfw
Just curious how it got from the breather forward to the front right side of the engine. I would think the airflow would blow it backward.
Old March 7th, 2016, 02:32 PM   #12
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Are you talking about the oil line banjo from the crankcase to the cylinder head where the pressure sensor is?
I've heard people call the spring style hose clips banjos before and thought you were talking about that.....
Old March 7th, 2016, 02:33 PM   #13
daverdfw
Yeah on the cylinder head, right side of the motor up at the top, there is oil there, and then splashed down that right side. Nothing on the left side at all.
Old March 7th, 2016, 02:38 PM   #14
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Ahhhh.....gotcha! That makes a lot more sense now.
It would be worth a torque check on those bolts and possibly replacing the crush washers there.
Check the valve cover bolts too, one might have vibrated loose.
Old March 7th, 2016, 02:39 PM   #15
daverdfw
Yeah, I think when I drain the oil. I will replace those washers, and recheck the torque on the valve cover, It clearly wasn't a lot of oil or it would have dripped into the belly pan, but enough to notice.
Old March 12th, 2016, 09:28 PM   #16
daverdfw
here is a pic from the weekend
Old March 16th, 2016, 09:28 AM   #17
Nice David!
Ninja 250 racer build thread bitaria Ninjettes At Speed 81 December 8th, 2015 08:19 AM
Spooph's 250 build thread spooph 2008 - 2012 Ninja 250R Tech Talk 63 November 24th, 2015 07:56 AM
My 250 Track/Race bike build SLOWn60 2008 - 2012 Ninja 250R Farkles 7 November 19th, 2015 09:21 PM
2009 Build Thread Bloody wheels 2008 - 2012 Ninja 250R Farkles 1 October 1st, 2015 05:50 AM
99 Ex 250 project Cafe/streetfighter, The build thread. cerberusrex25 1986 - 2007 Ninja 250R Tech Talk 260 June 14th, 2014 04:27 PM
