Old March 17th, 2014, 09:10 AM   #1
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK
Exhaust header stud broke
Ok, so you may have seen my post in the for sale section regarding my exhaust. I was removing it a couple weeks ago, and then my wife and kids and I all got sick (yuk) and now I am back into repair mode.
Anyways, as I was taking off the nuts on the header, both of the inner studs broke off. I am freaking out pretty bad, and I am hoping that someone can help me out with a fix to this. The rust is major on the bolt stud and nut, but the header is only slightly rusted. This seems to me to be an issue the previous owner did not address when they changed the exhaust. All help is appreciated.
jcgss77 is offline   Reply With Quote
Old March 17th, 2014, 09:32 AM   #2
Steel that bolts into aluminum always cause a corrosion that tends to weld both metals.
The above could be the reason for the need to apply extra torque on those nuts that sheared the bolts.
The studs need to be removed from the cylinder, but first, you need to soak those for some good time with some penetrating oil; my favorite is a mix of acetone and marvel oil.
Finally, if you have nothing to grab them with, you will need a stud's extractor or taking the bike to a machine shop for them to use theirs.
Old March 17th, 2014, 12:34 PM   #3
jcgss77
jcgss77's Avatar
That does explain it. I will begin the bathing process immediately. Which leads me to some more questions:
Do you have a preferred mix of the acetone/marvel oil, 50/50?
And will vicegrips work to take those out, after a good soak?
Last futzed with by jcgss77; March 17th, 2014 at 12:36 PM. Reason: lmgtfy
Old March 17th, 2014, 12:47 PM   #4
Do you have a preferred mix of the acetone/marvel oil, 50/50, and what is marvel oil?
Yes, 50/50 is what I have used.
You can replace the Marvel Oil with ATF or Air Tool Oil.
http://www.marvelmysteryoil.com/
If it is really bad, vice-grips may not be able to hold the stud strongly enough, but I would try that first.
Avoid drilling the things out, as precise centering is difficult and it is easy to destroy the aluminum threads.
http://advrider.com/forums/showthrea...ighlight=studs
Old March 23rd, 2014, 11:15 AM   #5
baz666
baz666's Avatar
Motorcycle(s): 2000 EX250 Ninja
I've been there and I sympathize. It's true, drilling can make things even worse. Hopefully soaking and vice grip method will work.
If not, there's Spark Erosion. An electrical current is attached to the offending stud and the metal is eroded and broken up.
A high school shop teacher did it for me on my old Suzuki and it worked great. If all else fails, call around to some electrical shops or machine shops and ask if they do it. It's not a difficult process and they shouldn't charge much.
Good luck.
baz666 is offline   Reply With Quote
Old March 23rd, 2014, 11:49 AM   #6
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
All true!
Automatic transmission fluid and acetone (50/50 mix) is my favorite.
Old March 23rd, 2014, 01:02 PM   #7
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
i've removed them by welding a nut to the broken stud. The heat from welding seems to break them loose.
accumack is offline   Reply With Quote
Old March 25th, 2014, 05:12 AM   #8
Ginganinja
pregens for the win!
Motorcycle(s): 07 ninja 250, 07 yamaha r6
^^^this. if you have a butane torch try heating up the stud for a couple minutes. It's the preferred solution for removing o2 sensors that are stuck without damaging them. I don't see why it wouldn't work here as well.
"liquid wrench" is another good penatrating oil, always worked for me.
Ginganinja is offline   Reply With Quote
Old March 25th, 2014, 08:49 AM   #9
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Exclamation
If it breaks flush, pull the head and take it to a machine shop. (Call around to find one that does this) It is correctly called E.D.M. (Electrical Discharge Machining). Correctly done, they can remove the broken stud completely without damaging the threaded hole.
I said pull the head because most shops will not attempt it with the head in place due to access difficulty.
Hopefully you can get it out. The welded nut/solvent soak is a very good and usually productive idea.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old March 27th, 2014, 05:17 PM   #10
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
And in a test with PB Blaster, Liquid Wrench, and some others I can't recall at the moment, was found to be more effective.
flitecontrol is offline   Reply With Quote
Old March 27th, 2014, 05:32 PM   #11
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
To fix this really takes skill time and a little luck.
PB blaster is extremely effective. Heating the broken stump just a little with a propain torch then spray PB Blaster on it. Let it sit for a couple days or over night. Then go after it with a very small drill. Drill a tiny little hole straight through the broken stud. Then heat it up just a little and soak it with PB Blaster again let it soak over night.
Next step is a reverse drill. This will follow the little hole and if you are lucky it will pull the broken stud. This all seems like a boat load of trouble. But that is what it takes.
If you drill through the stud with a backward drillbit then it can be completed with my favorite thread repair kit. WWW.Timesert.com
Or pull the head and give it to a machine shop. Like I said this is either a skill fix or luck fix. But it can all go wrong instantly. Like if the drill brakes off in the stud. Remember the stud is harder on the outside. So if you drill crooked you are headed for disaster.
Worlds fastest 250 ninja
Old March 30th, 2014, 07:30 AM   #12
thumper64
I had one break and I put two nuts on the stud so i could use a wrench. I heated the aluminum with a torch a little bit. Not enough to get it too hot, but I let it heat for a minute or two to expand it.
Motorcycle noob, feel free to ignore me.
thumper64 is offline   Reply With Quote
Old March 31st, 2014, 04:09 AM   #13
Ginganinja
Any updates? Did you get the stud out of the head?
Old March 31st, 2014, 07:11 PM   #14
jcgss77
jcgss77's Avatar
Still soaking it. I am ordering a stud extractor, so it will give it a good amount of time to break loose so I can hit it with that.
So, thinking forward, I really don't think I will be installing new studs there, is there any problem with using just bolts to mount the exhaust headers? I will be going to stock headers, and was considering using stainless steel bolts. Anyone else replace the studs with bolts?
Old March 31st, 2014, 07:29 PM   #15
........is there any problem with using just bolts to mount the exhaust headers?.......
Wear of the aluminum threads and length of bolt needing to be less than the threaded depths (but no much shorter or aluminum threads will be overloaded).
Old February 3rd, 2020, 08:03 AM   #16
justanotherone1
justanotherone1's Avatar
Motorcycle(s): Ninja 250 EX x2, 07" CBR600RR, 09"SFV 650 Gladius
Sorry for revving thread, but does anyone know the size and diameter for replacement Exhaust Studs? I can't seem to find them at all...
justanotherone1 is offline   Reply With Quote
Old February 3rd, 2020, 08:55 AM   #17
ducatiman
ducatiman's Avatar
6mm x 27mm kaw part# 92004-066
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old February 3rd, 2020, 08:58 AM   #18
justanotherone1
Thank you so much! I will my first born after you mister Ducatisto.
Header Stud Came Out of the Block?? Dsheumaker 2008 - 2012 Ninja 250R Tech Talk 4 March 30th, 2015 08:58 PM
Single Exhaust Header Shintoxica 1986 - 2007 Ninja 250R Farkles 5 September 12th, 2013 05:56 AM
Area P Exhaust Broke, Bummer!!! Manimal 2008 - 2012 Ninja 250R Tech Talk 11 July 16th, 2011 07:16 PM
FS: NEW Area-P exhaust header Momaru Motorcycle-related 6 June 8th, 2011 03:02 PM
Header exhaust gasket B2FiNiTY 2008 - 2012 Ninja 250R Tech Talk 5 May 8th, 2009 08:03 PM
