Old May 16th, 2016, 05:40 AM   #1
Foxrider64
Hello Moto
Foxrider64's Avatar
Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F
Surging at Full Throttle
I performed a search and came up empty handed
More often than not, the surging issue is at lower RPMS. Yesterday at Palm Beach International Raceway I was having surging issues at full throttle in 6th gear running about 90mph.
It didn't feel like the gear was jumping and my first thought was the clutch plates slipping. After pitting back in and getting past my frustration of having two mechanical failures in one day I remembered that I had put gas in the tank before that last session.
This is the first time this bike has ever experienced this in 4 years of racing/track days. It has 4300 miles, K&N air filter, stock air box w/ snorkel, full Leo Vince exhaust, block off plate, stock jets with no shims.
What are your opinions of it being the clutch vs. bad gas vs. something else?
Foxrider64 is offline   Reply With Quote
Old May 16th, 2016, 06:19 AM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Stock jets, no shims with full exhaust and and air filter???
I'm surprised you didn't have issues before this!! I would bet you're a little lean up top and have been for a while. This could have affected the valves....might be worth checking them to see if they need adjusting.
Of course, start with the easy thing: gas. Drain it and try another batch.
Goin' fast on slow bikes!
Old May 16th, 2016, 06:24 AM   #3
Foxrider64
Hello Moto
Foxrider64's Avatar
Every time I have checked the plugs they looked fine, a little lean, but not terrible. I have been trying to find a shop that will actually dyno tune my bike but if it doesn't have a power commander my local shops won't touch it.
Good points though.
Old May 16th, 2016, 06:26 AM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Good points though.
There is a jetting database here with TONS of entries. It's a good place to start and should get you in the ball park, or at least a little richer.
Also, for what it's worth, reading plugs in the age of non-leaded fuels is a bit pointless. After reading plugs and reading plugs, then going to the dyno, we were always about 3-4 jet sizes too large to get the plug the color we thought was good. The dyno told the whole story and it's a shame yours won't do carbed bikes!
Old May 16th, 2016, 07:40 AM   #5
Clutch is slipping.
Old May 16th, 2016, 08:56 AM   #6
ULW
ULW's Avatar
Motorcycle(s): 2015 Ninja 300 X 2
Clutch behavior is different than fueling issues behavior...
With the clutch you will see the engine revs go up without much change in speed... let's say 8,000RPM at WOT and then it surges up to 9,500 and back down to 8,000 without the accompanying rise in motorcycle acceleration performance... that's a slipping clutch under a high load, and it's fairly smooth. A certain RPM in a certain gear equals a certain speed EXCEPT if the clutch is slipping, then the engine speed will rise without the MPH, and it's not a subtle steady situation but a dynamic depending on how the clucth disks are generating heat and friction, etc.
With a fueling issue, AFR is either borderline (jetting or FI mapping) or intermittently changing (fuel filter, fuel pump, fuel quantity, fuel quality)... in this case a lean issue will cause it, and the bike performance follows the surging, it's not as smooth.
So please tell us in more detail what you're experiencing based on that?
ULW is offline   Reply With Quote
Old May 16th, 2016, 12:37 PM   #7
Foxrider64
Hello Moto
Foxrider64's Avatar
Agreed- and it doesn't feel like a slipping clutch to me based on previous experiences with it.
At full throttle in a full tuck I am not watching my tach at all. When it first happened I pitted in and came to a full stop and then ran through every gear under acceleration (practice start). The surging did not happen again until I hit a long straight where I was in 6th at full throttle again.
As mentioned, I had recently fueled up- the fuel had been purchased that day and is just pump fuel. I ran the same fuel in my truck which actually was performing like a turd on the drive home. The bike gave no indication in the 4 previous sessions of running excessively lean and nothing was changed besides the fuel.
If my kids allow it, I will drain the tank this evening but I have no where I can test a race bike at full throttle in my area.
Old May 16th, 2016, 12:44 PM   #8
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
While you're in there, check the fuel filter if you have one and be sure there are no kinks in your fuel line.
For grins and giggles you can also check the vent in your fuel cap. Is it aftermarket by chance?
Old May 16th, 2016, 12:54 PM   #9
Foxrider64
Hello Moto
Foxrider64's Avatar
No filter beyond the screen on the petcock, stock fuel cap, and good ideas. Thanks
Old May 16th, 2016, 12:59 PM   #10
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Welcome!
Old May 16th, 2016, 03:34 PM   #11
That would suggest a fuel flow or vent issue to me.
Old June 6th, 2016, 10:10 AM   #12
Foxrider64
Hello Moto
Foxrider64's Avatar
Was able to make it back out to the track for some testing-
It was bad gas.
The fuel I had the issue with came from a Sunoco station. Even though it was probably a fluke- I will not be buying from a Sunoco station again.
Old June 6th, 2016, 10:56 AM   #13
It was bad gas.
The one near Jennings? NEVER buy your gas from there again. It's not the first time bas gas has been purchased there. Left @Sirref out on the track on the exit of turn 1 on my bike. :\
Old June 6th, 2016, 11:01 AM   #14
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
^ that was from the marathon, I wasn't the only one who had that issue that day as well
Old June 6th, 2016, 11:06 AM   #15
Oh snap, sorry then... my bad. Carry on.
Glad you got it figgered out Alex and it was a simple problem.
Old June 6th, 2016, 11:10 AM   #16
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
It's not a good sign that there's been more than one place selling bad gas near Jennings. I've got to remember in the future to pick up all I need on the way
Old June 7th, 2016, 06:43 AM   #17
Foxrider64
Hello Moto
Foxrider64's Avatar
It was actually in Okeechobee in South/central Florida by Palm Beach International.
Old July 1st, 2016, 08:45 PM   #18
What do we think the bad gas really means? Water in the tank? Other impurities? Mis-rated octane? (selling regular as premium)
Full throttle kills bike, throttle lag response. Diegone 2008 - 2012 Ninja 250R Tech Talk 10 April 30th, 2014 03:25 AM
Losing power at full throttle trugracie 2008 - 2012 Ninja 250R Tech Talk 27 April 12th, 2014 06:43 PM
[tilted horizons] - TT: Full Throttle Ninjette Newsbot Motorcycling News 0 January 23rd, 2014 02:30 PM
Full throttle without regripping, technique seems to work... dimeified 2008 - 2012 Ninja 250R Tech Talk 4 August 14th, 2009 06:59 AM
[usridernews.com] - ORIGINAL PRODUCTIONS GOES FULL THROTTLE, HOLLYWOOD-STYLE Ninjette Newsbot Motorcycling News 0 July 23rd, 2008 11:01 AM
