Old May 16th, 2015, 01:58 PM   #1
Paulgello
Only runs on reserve
I recently purchased a 2007 ninja 250 about a month ago and I'm currently loving it. However there are a couple small issues the bike has, one of which is that it only runs with the petcock switch turned to reserve. It runs completely fine with no issues when it's on reserve however if I switch to the "On" position within a minute or so the bike bogs down and dies out. I'm hoping you guys can help me out in fixing this somewhat issue because it forces me to reset my trip calculator and get gas every 80 miles or so because I'm afraid I'll run out of gas far from home
Paulgello is offline   Reply With Quote
Old May 16th, 2015, 02:16 PM   #2
Welcome Paul!
Sounds like you need to rebuild or buy a new petcock.
Old May 16th, 2015, 02:33 PM   #3
Paulgello
Welcome Paul!
Thanks for the welcoming! Is a rebuild particularly hard to do for someone who's never worked on one before (this is my first bike) or should I just get a new one?
Old May 16th, 2015, 02:40 PM   #4
It's a piece of cake, but... a new/used one is cheap enough.
Have a peek here to see the steps and decide if you wanna have a go at it.
Here is a cheaper option that might work for you as well. Not 250 specific, but should work fine just the same.
Old May 16th, 2015, 04:16 PM   #5
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Sounds like a vacuum issue? Somehow, the gas may not be flowing to the carbs. When it's on reserve, gas is gravity fed to the carbs. When it's in the normal position, it's vacuum fed.
The rebuild should do the trick.
Riding it like I financed it.
Old May 16th, 2015, 05:20 PM   #6
Welcome, Paul !!!
The 2007 is a great bike; congratulations
You cloud try the simple trick of counter-blowing the petcock when in the ON position.
There is an internal mesh filter that may have become clogged if gasoline was left inside the tank to slowly evaporate during several weeks or months.
Old May 16th, 2015, 07:56 PM   #7
Ghostt
Ghostt's Avatar
Your petcock is shot, save your time, and money and get a new one, the cost of rebuilding it isn't much cheaper, due to you need two separate kits, as they for some reason don't make just one.
New one cost about $65.00
http://www.partzilla.com/parts/detai...1023-1139.html
Also be sure to order the orings(92022-183 WASHER,6.2X11X1.5)and new bolts(92001-1091BOLT,6X20),trust me you'll be better off in the long run.
Rebuilding kits are about $60 total.
K&L Supply Diaphragm Only for Fuel Petcock Repair Kit 18-6638 https://www.amazon.com/dp/B0055DWO60..._s1CGub1W9N3PH
K&L Supply Fuel Petcock Repair Kit 18-2723 https://www.amazon.com/dp/B001KO2JRW..._U1CGub05DT5NT
IMHO not worth it rebuilding, also be sure to check vacuum and fuel lines for wear, holes, and cracks, if in doubt replace them.
violente et ignorantia
ZX-2R BLOG
Old May 18th, 2015, 08:13 AM   #8
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Whether you choose to replace to rebuild, you're going to have to remove the tank and remove the petcock from the tank.
You might as well disassemble the petcock - go slow, take picture, take notes as to how it all goes together so you can put it back together if needed, so you can figure out what's wrong with it. Is the blockage on the primary fuel filter, or inside the petcock primary fuel circuit? Is it the rubber seal inside the vacuum switch that has degraded?
Might be a proper cleaning is all you need and that's even cheaper than a new petcock... Plus, you start learning about your bike...
Old May 18th, 2015, 11:14 AM   #9
agentbad
agentbad's Avatar
You can reuse the bolts and the nylon washers can be found at Lowes.
Old May 18th, 2015, 04:15 PM   #10
Ghostt
Ghostt's Avatar
Sometimes the bolts strip the heads, due th awesome Japanese metal, and if you do get washers from another source, make sure they are approved for gasoline use.
ZX-2R BLOG
Old May 22nd, 2015, 09:14 PM   #11
Any updates ???
Using the Reserve tank (?) AmyF General Motorcycling Discussion 20 July 8th, 2014 02:23 PM
Runs better on reserve??? JLinde1339 1986 - 2007 Ninja 250R Tech Talk 8 April 19th, 2012 06:11 AM
Is there a reserve? Jay72 2008 - 2012 Ninja 250R Tech Talk 22 October 28th, 2011 05:48 PM
How many miles, on reserve? BobsPT 1986 - 2007 Ninja 250R Tech Talk 11 August 30th, 2011 08:11 PM
