Old May 31st, 2015, 11:50 AM   #1
stewzzz
Motorcycle(s): none yet
IS IT WORTH IT?! project bike
so im trying to get rid of my 87 honda accord and trade it for this 06 ninja 250.
im new with bikes and need a few opinions by what they see in the ad if its worth it to buy or trade to get as a project bike to restore.
http://vancouver.craigslist.ca/rds/mcy/5031471051.html
thats the craigslist ad
im trying to get into bikes and thought this would be a nice way to start er goin. lemme know thoughts and opinions please.
thanks
stewzzz is offline   Reply With Quote
Old June 1st, 2015, 10:17 AM   #2
Ghostt
Ghostt's Avatar
Looks like a project for sure, but seems a little high priced considering what needs to be done, and also a lot of unknowns.
I don't know prices for the great white north, but down here I personally wouldn't give more than a few hundred, of that.
If this is your first bike, I wouldn't buy a project, I'm guessing you want ride, not waste your time and money fixing up something that might not be ready til next season, unless you have cash just laying around.
violente et ignorantia
ZX-2R BLOG
Old June 1st, 2015, 10:23 AM   #3
Welcome Mitch!
Please pass on this one, too many customizations. If you must get a project bike as a first bike, at least try to find one as close to stock as possible. That way when you go to the manual to fix things, the bike matches what your reading.
Good luck and many wrench turners here to get solutions from.
Old June 1st, 2015, 10:24 AM   #4
Ghostt
Ghostt's Avatar
I myself love projects, but I've been riding for many years, my Ninjette was just that, but I'm experienced in motorcycles, here's the quick write-up about it,
Back in May 2014, I picked up a 98 with 27k miles on it for a great price. The P.O. did nothing except put gas in it, and changed the oil, I think, he did this for about 20k of the total miles.
Needless to say it needed a lot of TLC. I am no stranger to rebuilding bikes, I did my 91 EX500 which was a basket case for sure to say the least, here is the link to see that build:
https://picasaweb.google.com/1006527...JCB6ffS-973wgE
With that said I went through the bike, repairing, replacing, & modifying as I went, with the exception of the engine/transmission that seems solid no noises or smoke.
Here is a link to the evolution as told by pictures.
https://picasaweb.google.com/1006527...IDXyZXyoe2m0QE
Work performed :
Cut and set sag front fork springs(springs from a Ninja 500 1st generation, rate is .85kg/mm )
Replace fork oil 15wt synthetic
Install new fork seals and dust caps
Replace rear shock(zx600c)
Replace shock oil 15wt synthetic
Change gears +1/-2
Rebuild/tune carbs, adjust idle mixture
K&N air filter
New brake pads F&R EBC extreme HH
New Wave front rotor
Used OEM rear rotor
Modified OEM seat(gel/foam insert, Custom Seat Creation cover solo line cf silver/cf metal, heated kit)
Extra heavy bar ends(3"/23oz)
Heated grips w/ foam covers
Touring windscreen(7 JuRock 18" 73%tint flip)
Shorter bar risers(ZX600c lower bars about 1 1/2")
Removed paint from rims, bare aluminum
Bridgestone BT-45s w/ Dynabeads
Stainless steel allen head fasteners
Stainless steel braided brake lines
Shorty adjustable levers
HD clutch springs
Charge/voltage LED indicator
LED clock
HID headlight(55w 6k)
Replaced all other bulbs with CREE LEDs
DIY integrated tail light kit w/clear lens
DIY rear fender elimination
DIY licence plate mount(LEDs to illuminate the plate/red LEDs tied into brake light)
Brake light modulator
Maintenance free gel battery
Compact air horn
2007 Complete OEM fairing set silver
Genuine imitation carbon fiber wrap misc parts
Reflective custom graphics ZX-2R silver
Reflective custom graphic NINJA red(taillight lens)
Reflective rim tape silver
Electronic turn indicator relay
Replace front side reflectors with flush mount turn indicators LEDs
Installed rearview camera system
Installed oil cooler
Strip paint off grab handle, bare aluminum alloy.*
Custom reflective graphic "SERENITY" for windscreen silver
Aluminum chain guard from Suzuki Bandit 1200
Swing arm plugs from 08 Ninja 250
Mad Hornets Turn Signal Indicators w/duel color Cree LEDs(amber/white)
FH010 R/R modification
Digital gear indicator
Carbon Fiber wrap miscellaneous parts
Installed Universal Rear View Side Mirror Rain Board Sun Visor Shade Shield, genuine imitation carbon fiber wrap with non- visible clear coat applied.
All this and full maintenance and rebuild everything else except the motor. I'm sure I'm forget some stuff, but you get the idea.
ZX-2R BLOG
Old June 1st, 2015, 10:27 AM   #5
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Welcome!!!
Your first bike huh, I would look for something a little more suitable. Electrical issues are a bigger issue then you think.
Spoiler for topic:
It might just be the [you] tag
Project Ninja Worth? lowdown112 General Motorcycling Discussion 11 May 17th, 2013 12:48 PM
Is this bike worth the chance? SabreValkyrn General Motorcycling Discussion 14 April 19th, 2013 05:35 PM
How much is my bike worth KidA001 General Motorcycling Discussion 20 August 2nd, 2012 11:12 AM
WTB: 2008+ 250R salvage bike for track bike project htdub Items Wanted 0 April 25th, 2012 11:12 AM
Is a modded bike worth less than a stock bike? n4v1n 2008 - 2012 Ninja 250R Farkles 22 September 30th, 2009 02:41 PM
