Old June 9th, 2015, 08:11 AM   #1
gogiburn
Motorcycle(s): have 24
self cancelling turn signals
any aftermarket self cancellingt turn signals available?
gogiburn is offline   Reply With Quote
Old June 9th, 2015, 08:23 AM   #2
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Haven't gotten the hang of turning them off yourself? (Just asking, not being a dick about it)
Spoiler for topic:
It might just be the [you] tag
Old June 9th, 2015, 08:33 AM   #3
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Will not work. Will it based on time? Or steering angle?
A lane change at 60mph will have a different steering angle compared to a right turn in Manhattan.
Riding it like I financed it.
Old June 9th, 2015, 08:34 AM   #4
allanoue
allanoue's Avatar
MOTM - Sep '14
I need!
I have no inkling how to turn them off, and I am sure it is going to kill me someday.
Old June 9th, 2015, 08:37 AM   #5
Ghostt
Ghostt's Avatar
I know Kisan Tech makes some, but I have no other info, other than a link
http://kisantech.com/mag/index.php/signalminder.html
SM-2
SM-2
Sign up for price alert
Availability: In stock
$109.95
Add to Cart
Details
Details
SM-2
Click to see a larger SM-2 image
SM-2 unit is designed as a plug-in replacement for many Japanese and some early European bikes. Extra ground wire of the unit must be attached to a good chassis location.
signalMinder uses a computer chip to cancel the turn signals. There are three selectable timeouts; 10, 20, 30 seconds.
RUNNING LIGHT OPTION:
By attaching two quick-connect wires included, you can convert ALL FOUR turn signals to running lights and establish a dual-channel system on your bike.
Using the DIP Switch #1, you can keep them off and still have the dual-channel system.
With the dual-channel system, when you activate the RIGHT turn signal three times in succession, you get 4-way hazard flash function.
NEW FEATURE (d17EBxx code)
Built-in RUN-TURN-BRAKE functions
No need to buy other turn signal conversion product. You get all the features of RUN-TURN-BRAKE and automatic signal canelling!
If you hook-up the 12 volt supply from the brakes to the signalMinder brake input:
BRAKE FLASH OPTION will flash the turn signal lamps every time you apply brakes. A short 2 second flash pattern begins with quick flashes then slows down to stay on solid.
BRAKE OVERRIDE OPTION suspends the time-out feature until the brakes are released. This allows continued flashing for those times when you are waiting at the signals to make a turn and do not want the time-out to cancel the flashing.
MORE FEATURES
HANDLE BAR RETURN SPRINGS:
If above options are hooked-up, these tiny return springs can be inserted in the handlebar switch to force it back to neutral automatically. You don't have use the Push-to-cancel of the handlebar switch.
Above options are not required to be installed, but utilizing them allows fully automatic turn signal cancellation. We highly recommend hooking them up.
Please Note! NONE of the wires on the bike have to be cut. The kit includes Scotchlok brand of Insulation Displacement Connectors (IDC) to tap into existing wires.
The last thing you need is to worry about canceling the turn signals! Use all of the built-in options of thesignalMinder and enjoy the ride.
signalMinder has an add-on product known as vectraLIGHT. These LED arrays simply plug into the signalMinderand inherit all of it's features. They are designed to mount under the turn signal mirrors.
Click here for Installation Manual
Share
Be the first to review this product
You May Also Like
SM-3SV
SM-3SV
$109.95
20W-D
20W-D
$69.95
P115W
P115W
$109.95
Customer ServiceKnowledge BaseSubmit a HELP ticketPrivacyRegulationsOrder StatusContact Us
Selected Store: Kisan Electronics
2015 Kisan Electronics. All Rights Reserved.
Good hunting
violente et ignorantia
ZX-2R BLOG
Old June 9th, 2015, 08:44 AM   #6
allanoue
allanoue's Avatar
MOTM - Sep '14
Cars it turns off but does not work just by changing lanes but I am not as concerned about forgetting to turn them off on superslabs.
On surface streets and cross traffic....
Old June 9th, 2015, 08:46 AM   #7
Panda
not an actual panda
Old June 9th, 2015, 08:47 AM   #8
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
My Ninjette had a Kisan flasher unit (was installed by the PO). The timeout feature was controlled by number of flashes. If you had a brake applied, it would keep flashing until you released the brake(s) (good for when you were at a stoplight). One could also invoke emergency flasher mode or "wigwag" flash mode.
I left the Kisan unit on the bike but wasn't extremely happy with it: it would occasionally go into a weird mode that required a power-off cycle to reset it.
Old June 9th, 2015, 08:48 AM   #9
allanoue
allanoue's Avatar
MOTM - Sep '14
Originally Posted by Panda View Post
wrong thumb
Old June 9th, 2015, 09:14 AM   #10
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
I'm old so I file it under "acting my age."
My last track day I reflexively signalled at pit in. No kidding.
Old June 9th, 2015, 09:16 AM   #11
Ghostt
Ghostt's Avatar
Of you are truly old, then it would have been on the whole time, left turn preferred
ZX-2R BLOG
Old June 9th, 2015, 09:27 AM   #12
Maybe someone is smart enough to make a circuit that can click off after a timed delay. Is there already such a thing that is applicable here?
Old June 9th, 2015, 09:28 AM   #13
Ummm...
Now that is funny.
Old June 9th, 2015, 09:28 AM   #14
Ghostt
Ghostt's Avatar
See my post above about the Kisan unit
ZX-2R BLOG
Old June 9th, 2015, 09:33 AM   #15
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
All you would need here is a simple 555 timer. The thing here is then you would have to route another power wire since you would no longer be going of the basic turn signal power. Tune the 555 timer to allow for a specific length you feel comfortable, resistor values are the key (might want to use pots), and there you go. Might also need a dc-to-dc converter.
Spoiler for topic:
Old June 9th, 2015, 02:56 PM   #16
verboten1
verboten1's Avatar
MOTM - June '15
My 1982 Virago has self canceling signals, not sure how it does it, but came from the factory that way.
Ride more, worry less.
Old June 10th, 2015, 11:29 AM   #17
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
My '85 VN700 had them stock too. Honestly, I spent more time turning them back on because they shut off early, or waiting to make sure they'd turn off after I completed the turn, than I spend thinking about clicking them off on the EX500.
In theory I like them. In reality, I think they're an overly complicated solution to a very minor problem. Just install a diode kit and get a really bright LED bulb to use for the dash indicator, so you CAN'T ignore it.
Old June 10th, 2015, 03:25 PM   #18
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Originally Posted by allanoue View Post
I need!
Push in on the switch when it's in the center position to cancel. Push left or right to activate.
Old June 10th, 2015, 04:15 PM   #19
allanoue
allanoue's Avatar
MOTM - Sep '14
thx
Old June 12th, 2015, 07:06 AM   #20
vbrad511
Motorcycle(s): 1983 CB100F
You can wire in a "beeper" to remind you they're on.
vbrad511 is offline   Reply With Quote
Old June 12th, 2015, 11:26 AM   #21
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
Old school hand signals! On the highway I usually use hand signals local roads both and I try to train myself to keep hitting the cancel button 4 to 5 times after a turn.
accumack is offline   Reply With Quote
[webbikeworld.com] - Bose QuietComfort 20 Noise Cancelling Headphones Review Ninjette Newsbot Motorcycling News 0 September 7th, 2013 07:20 PM
LED's! (footpeg turn signals, brake light strips, front signals oh my!) VeX 2008 - 2012 Ninja 250R Farkles 16 June 29th, 2012 12:03 AM
[topix.net] - Effenbert Liberty Racing Team Says Cancelling World Superbike Race... Ninjette Newsbot Motorcycling News 0 May 10th, 2012 06:40 PM
[roadracingworld.com] - Effenbert Liberty Racing Team Says Cancelling World Superbike Ninjette Newsbot Motorcycling News 0 May 10th, 2012 02:50 PM
Rear turn signals don't blink, front turn signals don't turn on andyuc88 2008 - 2012 Ninja 250R Tech Talk 3 March 23rd, 2012 02:47 PM
