Old September 27th, 2014, 01:33 PM   #1
rmorse
Motorcycle(s): 2008 Kawi Ninja 250R, 2013 Honda CRF450R, 2008 Honda CRF250R, 2001 Honda XR400
Copper shavings in my oil screen
Hey guys, I just checked my oil screen and found a bunch of metal shavings in it. The majority are copper. My buddy said it sounds like bearings.... what do you guys think? If it is bearings, what needs to be replaced? Is there a walk through? Bike has 18k miles on it, and I did lose oil about two years ago on the Chesapeake Bay Bridge. Pretty much the worst spot to have a breakdown. I had to ride it a bit with the oil light on until I could shut it off and coast the rest of the way.
I'll attach pictures
rmorse is offline   Reply With Quote
Old September 27th, 2014, 01:40 PM   #2
Brother Michigan
Motorcycle(s): 2013 Ninja 300
How big are the shavings and when is the last time you checked the screen? Is the bike making any unsettling noises? Copper could be from a bearing race, but I imagine there are a few other sources it could come from as well.
DISCLAIMER: I generally have no idea what I'm talking about.
Old September 27th, 2014, 01:42 PM   #3
rmorse
The big piece is a piece of foil from a sloppy oil change.
Old September 27th, 2014, 01:43 PM   #4
rmorse
I've never checked the screen. I'm not aware if the previous owner has checked it. I've had the bike since probably around 10k miles, and it has 18k on it now.
Old September 27th, 2014, 07:58 PM   #5
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
May have hurt the big end bearings.
but
Could be disintegrating cheap filter.
Run a few oil changes through the engine with new filter everytime.
Massive chunks
foil
ninja250r81 is offline   Reply With Quote
Old September 28th, 2014, 08:50 AM   #6
micoulisninja
modaholic junkie
I think I can see a piece of what looks like piston skirt or sth on that screen....
Old September 28th, 2014, 09:15 AM   #7
you screwed up the bearings by running it with no oil.
it could still be okay. but it could also be completely ruined and just a few miles away from no longer running..
you should be able to tell how bad it was by how it sounded... did it sound like "SMACKSMACKSMACKSMACKSMACK"? or did it sound normal
Old September 28th, 2014, 10:12 AM   #8
oh dear
I am with alex.s here.
Old September 28th, 2014, 06:01 PM   #9
rmorse
It sounded normal, and still sounds normal. I've put on probably 5k or more miles since then.
When you say bearings, what bearings? What do I need to replace?
Old September 28th, 2014, 06:14 PM   #10
Flying
Motorcycle(s): 2010 Ninja 250
Rods or mains or both. Can't really say what to replace without taking a look inside.
You could be spending money anywhere from 2 sets of bearings + connecting rod bolts + some lube to a used engine from ebay.
Old September 28th, 2014, 06:18 PM   #11
rmorse
Weak. So sounds like I need to take it in to a shop to diagnose.
Thanks everyone
Old September 28th, 2014, 06:18 PM   #12
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Have you checked it since you put the additional 5K on it?
Old September 28th, 2014, 06:23 PM   #13
rmorse
What? This is the first time I checked the screen ever. The oil incident happened 5k miles ago.
Old September 28th, 2014, 06:28 PM   #14
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Sorry, I thought you rode 5k more since you found the shavings.
Carry on...
Old September 28th, 2014, 06:32 PM   #15
Thanks everyone
No, not yet. If everything is good then send a sample of the oil to be examined. They know things....
Old September 28th, 2014, 11:40 PM   #16
an oil sample will tell you which bearing it is. the little ends dont use copper iirc. but it could be from other places. if its been 5000 miles it might be fine. but it might blow up tomorrow also.
Old September 29th, 2014, 01:54 AM   #17
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
bearing material normally comes off as a paste
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old September 29th, 2014, 04:03 AM   #18
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Crankshaft Bearings. It's the only copper in the engine.
Worlds fastest 250 ninja
Old September 29th, 2014, 07:53 AM   #19
Ninjinsky
Ninjinsky's Avatar
The only other copper I can think of in there is the alternator. I don't know if it can shed a coil without failing completely ( ie if the windings are serial or parrallel.)
Once any bits of wire have been between gears on their journey to the mesh they will look like flakes not wire
Old September 29th, 2014, 09:45 AM   #20
bruce71198
bruce71198's Avatar
If it still runs after 5000 miles I would recomend cleaning out the screen and keep running it. Check the screen after the next oil change to see if its still self destructing. The damage is already done. The repair shop will need to split the cases to see whats worn out. My guess is you sheered some material off the main crankshaft bearings when you ran it out of oil,
does the 300 have a oil screen? felo 2013 - 2017 Ninja 300 Tech Talk 4 August 7th, 2023 08:00 AM
Where is the Oil Screen? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 14 August 1st, 2023 10:12 AM
Mystery o-ring on oil screen? chadh92 1986 - 2007 Ninja 250R Tech Talk 12 May 17th, 2013 04:16 PM
Riddle me this: oil screen cuong-nutz General Motorcycling Discussion 4 February 23rd, 2013 11:03 AM
Metal Shavings in Oil, Bad Cam Chain Tensioner? manorat 1986 - 2007 Ninja 250R Tech Talk 1 August 7th, 2010 12:21 AM
