Old May 21st, 2016, 05:09 PM   #121
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Guess I gotsta git t'werk on dem talkin skeels den
Old May 23rd, 2016, 06:45 AM   #122
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
So.........I finally got the 748 all back together and took a Test ride down the street. She started right up and was ideling nicely as I started off. I could feel a nice strong pull from the motor and the exhaust sounded plenty deep even through stock cans. I brought the revs up to about 7000 and started to hear a noise. I pulled in the clutch and headed back home. I found the belt for the front cam was not as tight as it should be. I believe I might have set the exhaust cam a tooth off from where it should be. I need to get time to pull the tank and airbox so I can recheck the timing on both heads. I hope I did not damage the exhaust valves with this stupid mistake! I will take Thursday and Friday off to assure this bike is ready for its trial at Palmer. I want to use the Palmer track, which I am familiar with, to set the bike up for Ohio. Worst case I will just have to run the 999 at Ohio!
Ducati999 is offline   Reply With Quote
Old May 24th, 2016, 03:55 AM   #123
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
So.... I pulled the R6 out into the driveway, wiped the dirt from my last track day off of it so it looks all purdy, switched it on to make sure the battery is alive and wheeled it back into the garage. I'm ready for Palmer....
Old May 24th, 2016, 06:42 AM   #124
Bigballsofpaint
Im pulling the usual last minute deal. Ive been sanding and priming my bodywork, hopefully have it painted by the weekend and I need to do my oil change and swap the bodywork over this weekend. Nothing too crazy.
Current - 2015 30th Anniversary Ninja 636 ABS - 1969 Honda 305 Scrambler
Previously - 2011 Ninja 1000, 2008 Ducati 848, 2011 Ninja 250 SE
Old May 24th, 2016, 07:17 AM   #125
adouglas
adouglas's Avatar
When I was talking to Todd on Sunday I said
"If you're going with Jay, a heads-up... you'll be arriving at the last minute. No biggie. That's just Jay...."
PS: He's got a fresh oil change so I gave him a hose clamp and advised him to just secure his existing filter that way. No point in wasting oil and filter just to get the K&N on there.
Old May 24th, 2016, 07:44 AM   #126
Bigballsofpaint
Ya he text me on the oil change, if he didn't safety wire the clamp then we will on Sunday. Hes staying over sun night, my PLAN is to wake up at 530, leave at 6, but we shall see . We will need to safety wire his cam if he got it in as well.
Old May 24th, 2016, 08:46 AM   #127
adouglas
adouglas's Avatar
You're an hour and a half away....
FYI, from the TTD website
7:00 AM Arrive at track- unpack bike, gear, etc. (or arrive night before)
7 - 8:15 AM TECH INSPECTION - MAIN GARAGE
8:15 AM RIDERS MEETING
Old May 24th, 2016, 08:49 AM   #128
Bigballsofpaint
Meh, ive never been late enough to miss the riders meeting. Don't you worry! PS This is the wrong thread for Palmer, this is for our Ohio trip!
Old May 24th, 2016, 08:53 AM   #129
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I've missed so many riders meetings it's becoming a noticed trend hahaha (there's one other who's notorious for it as well and we basically have the same mentality towards it...we are not morning people)
depending on the track, they don't care as much since I can recite everything they say. There are benefits to riding as much as the coaches
Old May 24th, 2016, 11:10 AM   #130
adouglas
adouglas's Avatar
There's going to be a new guy accompanying Jay.... Another doomed soul. Eeexxxxcelennnntttt.
Old May 25th, 2016, 12:30 PM   #131
Wise move sir! You can count on having an extra bike for you guys to ride, but it's really long haul to have a mechanical issue. Vetting your stuff before making the trip will serve you well. Looking forward!!!!!
Old May 25th, 2016, 12:42 PM   #132
Update! Gentlemen... Here is the deal thus far;
Jay, you should be forced to sign up for Novice. That is ok, take a few sessions to learn the track layout and then... if you see fit, we will bump you to I as it works out for your best day possible.
Everyone (including Jay)... Put yourself in my group. Novice coaching has changed from a "classroom" setting to a per coach group setting. So I can directly address any questions you guys have or work on any skills you guys want. Ie... the day will go as "you" want it to go vs a predetermined content structure. Just like Jay, if you need to be bumped to the I group, we should be able to make that happen. However, if I get assigned to the N group, then I will have to stay there the entire day but can double up on sessions to ride with you guys. Which, you know will be happening. Just so you know, we can run "I" group pace in "N" as long as our passes are super clean. I will lead the way and make a clear path as best I can within the rules of the track.
And.... We are set for garage 12, look for "Reserved for Smith" on the yellow sign posted at the garage, Kevin and myself should already be setup there upon your arrival. Cost.... $0 doll hairs and no need to thank me either.
Ya'lls have a great time at palmer!
Old May 25th, 2016, 12:50 PM   #133
Bigballsofpaint
Ya I signed up for Novice, im sure you wont steer me wrong! I got my confirmation email last week. Man I cant wait for the next 3 weeks! Palmer track this Monday, then a trip to the dragon next thurs-sun, then work a week and off to ohio!!
Old May 26th, 2016, 05:17 AM   #134
adouglas
adouglas's Avatar
Awesome.
Is there room in your garage for all of us?
How do we ask to be in your group?
Old May 26th, 2016, 05:34 AM   #135
4 bikes fit super easy in the garages, but we have done up to 6 before. I will be parking my bike under the ezup just outside the garage to give you guys more room. I will only need a little bench space for my helmet fan, phone and laptop. We will move the chairs about as the shade moves, you will understand when you get there.
As far as getting to be in my group. You guys don't need to do anything special. Just stand together during the novice portion of the morning riders meeting and I will handle the rest.
Old May 26th, 2016, 06:43 AM   #136
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I assume the garage has power for tire warmers?
If ya'll come down to NJMP for a TPM day I'll get garage space for all of us, normally it's just me and it's not worth it for one person
Old May 26th, 2016, 06:51 AM   #137
Yep, power and air included at no extra charge!
Old May 26th, 2016, 06:18 PM   #138
adouglas
adouglas's Avatar
That's great! Because, you know, this whole breathing thing is greatly under-appreciated.
Old May 26th, 2016, 06:32 PM   #139
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Chris will you be at vintage days?
Old May 26th, 2016, 07:31 PM   #140
What's the dates? I'm underemployed, so I'll probably be free, but I've yet to bring the girl out from storage and won't for at least another week... Might be able to come say hi and be pit buddy though.
Old May 26th, 2016, 07:48 PM   #141
I don't think so unless something changes. I love bikes, mid-o and all, but I kinda need time to do the work on my own for the 13-14 when they guys make the long haul down. Not to mention balance things out with some family time. Gunna try to go camping or maybe down to Mammoth Cave or something like that.
Old May 26th, 2016, 07:49 PM   #142
July 8-10
Old May 26th, 2016, 08:25 PM   #143
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Would my old 250 be good for vintage days?
I was trained in the art of stealing air, to have it freely given is an odd feeling
Old May 27th, 2016, 06:21 AM   #144
I am thinking not Ben, at least anything that the bike could be competitive in. WERA has some lightweight racing later in the year though.
Old May 31st, 2016, 02:19 PM   #145
Ducati999
Here is a question I would guess many have asked: What is wrong with me? I just finally registered for Mid Ohio! Nothing like waiting till the last minute! I ordered the parts for my bike today also, they should be here by Thursday. That should leave plenty of time to install and begin the baseline setup--or prove out the track worthiness of the bike. Well since we are all taking my truck and trailer from Ct to Ohio I thought you would all feel better to know I am paid in full finally! Now I have a couple of day of reading from all of the private messages I got after Palmer.
Old June 6th, 2016, 10:23 AM   #146
OMG... Soooooo sorry Chris, I told you the wrong dates. This event with everyone is going down in 6 days. June 13/14th. You are more than welcome to come and ride or just hang out. In fact, please do. I will have extra food and drink for you just in case. Your girl & dad are more than welcome as well. It would be my pleasure to have a seat with them and catch up.
@everyone - Garage 12 is NOW full (5 bikes). AND the paddock spot behind the garage is now full but we still have in front of the garage to use as we need. Kevin and I will park our bikes under the ezup just outside the garage, so you long haulers will have the space you need.
Here is the current list right now;
me
Kevin
Ant
Andrew
Jay
Drew
Bing
Randl
Adam
Possibles
Chone
Chone's girl
Chone's dad
Expect a couple of days of chaos with me but after 5pm, things should be calm and right. I have to work tech in the mornings. DO NOT go to tech, I will tech your bikes right in the garage.
Kevin and I will have the garage and paddock all set up around 7pm on Sunday night, be grilling up some grub and putting the track fairings on #511.
Old June 6th, 2016, 10:30 AM   #147
Also, I have alerted track control and the mid-o staff. Since you ALL are paying clients coming to have a good time. I am your personal concierge for the day. So your free to use and abuse me as you see fit. lol
Old June 6th, 2016, 10:32 AM   #148
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
put me under possibles
whether or not I make it depends entirely on whether or not I am able to get my motor in good shape by thursday night (I believe it to be possible). I'll be a walk in signup (I'm assuming a tues will have room) post to follow on thurs/fri confirming or denying my participation. I'm doing everything possible to be ready on time, and it's definitely possible
Old June 6th, 2016, 10:39 AM   #149
Your on my list Ben. Good luck and hope to see ya there.
Old June 6th, 2016, 11:02 AM   #150
adouglas
adouglas's Avatar
Achievement unlocked:
Platinum service level
Old June 6th, 2016, 11:09 AM   #151
@Sirref, Let me offer you this. If I can figger out a way to get the 4th bike in the trailer, I will bring one for you. Just show up. How does that sound? The 4th bike will be my blue r6 that you have ridden before.
EDIT: nm... I have a truck, I can load it in the back. Duh...
You in or out?
Old June 6th, 2016, 11:14 AM   #152
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I'm in no matter what for good times on tuesday the 14th!
Old June 6th, 2016, 11:18 AM   #153
So that means I need to bring the bike or nah?
Old June 6th, 2016, 11:47 AM   #154
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
It means bring it just in case, I'll be in either on my bike or yours
Old June 6th, 2016, 11:48 AM   #155
Deal! See ya there and safe travels my good man.
Old June 8th, 2016, 08:13 AM   #156
I know my fiance can't get the days off this short notice, but I think my father might be able to! I am really feeling a visit/social time. I miss the track and I wanna meet the east coast crew.
Old June 8th, 2016, 10:10 AM   #157
Koala
Koala's Avatar
Motorcycle(s): 2017 Ninja 300 Winter Test Edition
MOTM - May '18
Does it cost anything to just come to hang out and watch? Need to get out of the house and get my mind off a few things and that would be a way to do it.
Koala is offline   Reply With Quote
Old June 8th, 2016, 10:15 AM   #158
Nope, it's always free of charge to come watch and have a good time.
ps.. bring a camera!
Old June 8th, 2016, 10:18 AM   #159
Koala
Koala's Avatar
MOTM - May '18
Sweet....I'll most likely be by on the 14 then.
Old June 8th, 2016, 10:24 AM   #160
Cool!
Between all the riders in our little group, there should be someone hanging out in garage 12. If you don't see anyone just look for my red/black #511 near a white enclosed trailer. Don't be shy come over and introduce yourself, shake hands and have a drink. You're free to hang out after hours too. Once the gate opens at 7pm on Sunday, they remain open until Tues. 6:30pm
I am trying to put together a track walk Mon. night, even if we do it by riding around in the vans. Who is interested?
Mid-Ohio V4 csmith12 Ninjettes At Speed 78 July 3rd, 2015 12:44 PM
The Mid-Ohio School csmith12 Track Organizations 6 January 27th, 2015 12:37 AM
Mid-Ohio v3 csmith12 Ninjettes At Speed 579 October 13th, 2014 04:50 PM
at Mid Ohio... iZapp Pictures 3 March 2nd, 2013 11:38 AM
[motorcyclistonline] - KTM Partners With Mid-Ohio Sports Car Course And The Mid-Ohio Ninjette Newsbot Motorcycling News 0 July 26th, 2008 01:07 AM
