Old August 16th, 2013, 07:28 PM   #1
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Steering Damper Bracket
Does anyone know where I can just buy a bracket to mount a steering damper? I can find some dampers online for ~ $50 but it looks like they don't include or offer the bracket for the individual bike....
http://www.ebay.com/itm/UNIVERSAL-MO...61087260379%26
http://www.ebay.com/itm/UNIVERSAL-MO...8c86db&vxp=mtr
Mods: Offset clutch pressure plate
Old August 16th, 2013, 07:35 PM   #2
Your looking for a 37mm fork clamp. The are everywhere for cheap.
Old August 16th, 2013, 07:53 PM   #3
FvnnyL3tt3r1ng
Did you mean 36mm? Those are my clip on sizes..... I found the fork clamp but don't I need another bracket to secure the other end of the stabilizer?
Old August 17th, 2013, 06:30 AM   #4
brenthedtke83
brenthedtke83's Avatar
Motorcycle(s): 07 ninja 250r
This might sound really dumb, but what does the steering damper actually do?
brenthedtke83 is offline   Reply With Quote
Old August 17th, 2013, 08:25 AM   #5
Yes, sorry 36mm for pregens. Us race guys just mount it to the front stay as seen in Rexbo's build thread. I don't think the front stay on the pregens will lend itself to such an easy install. So another bracket may have to be fabbed or you can get more creative. Top mount with an anchor stem is another option but may require some drilling into your top triple.
Maybe someone with a damper prepped pregen can comment more. Also, if you come up with a mounting solution, post it up!
Old August 17th, 2013, 08:27 AM   #6
http://en.wikipedia.org/wiki/Steering_damper
Most riders deem it as unnecessary for a 250, although some race org require it to pass their tech inspection.
Old August 17th, 2013, 10:23 AM   #7
FvnnyL3tt3r1ng
Well I'm mounting one to correct my steering wobble. I don't race at all I ride freestyle and it's really killing some of my progress atm.
Old August 17th, 2013, 10:27 AM   #8
FvnnyL3tt3r1ng
The way he mounted it in the build thread looked pretty good to me. I'm gonna order the damper and play around with measurements around the forks and see what I come up with. It'll be easier once it's in my hands. I'm also installing a handbrake on my left bar and relocating my ignition switch so I've got a lot of fabbing to do. Oh and possibly a foot-hole in my passenger seat. Can you say re-sale value?? lol
Old August 17th, 2013, 11:28 AM   #9
FvnnyL3tt3r1ng
Just ordered this fork clamp. Now on to find a nice cheap damper.
Old August 17th, 2013, 12:43 PM   #10
Where's the damper itself mount to? That part goes on the fork tube. I get that. But the other part? Confused
Edit: just read the link. Shoulda done that the first time.
Old August 17th, 2013, 01:13 PM   #11
FvnnyL3tt3r1ng
Tisk Tisk chone. Do I see a damper install in your near future?
Old August 17th, 2013, 01:54 PM   #12
Nope. I don't think it needs it. I get headshake every once in a while, but only when I've got too muh pressure on the bars over bumps. It's all just feedback telling me that I'm doing it wrong.
On a dedicated track bike that gets ridden 110% every time I'm on it, I'd likely feel differently.
Old August 17th, 2013, 04:09 PM   #13
FvnnyL3tt3r1ng
Does anyone know if this damper is non-adjustable? There are plenty of really cheap dampers out there but they seem to be non adjustable and I'd hate to install one that didn't have enough or too much preload on it....
I do see a torx screw on it....
Tried googling it but got nada
http://www.ebay.com/itm/00-03-SUZUKI...5226f7&vxp=mtr
Old August 17th, 2013, 06:53 PM   #14
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
stroke matters too, not just size
The stroke of a steering damper has to be enough to allow lock-to-lock handlebar motion.
GeorgeRYoung is offline   Reply With Quote
Old August 18th, 2013, 06:17 AM   #15
FvnnyL3tt3r1ng
Thanks for pointing that out. I just haven't gotten around to measuring it yet.
Old August 19th, 2013, 05:29 PM   #16
FvnnyL3tt3r1ng
It was a little cumbersome to measure but I got around 5in of travel which equates to ~127mm..... Does this sound right?
I can basically buy any damper as long as it has at least that much stroke correct??
Old August 20th, 2013, 11:32 AM   #17
GeorgeRYoung
sounds in the right ballpark
The Concours requires about 142mm and I used a Sprint (138mm travel, 420mm overall length) and shimmed the fork stops.
Old August 20th, 2013, 12:42 PM   #18
FvnnyL3tt3r1ng
Ok so if you had used 142mm+ stroke damper you wouldn't need to shim the forks correct?
Oh and how do you set the damping on yours? I'm looking at it on your webpage but I don't see any adjusting knob? Are all dampers adjustable??
Old August 20th, 2013, 01:23 PM   #19
GeorgeRYoung
more damper stuff
Yes, if there was one with exactly 142 mm of stroke. The next size Sprint is 160mm stroke, 460mm overall length, and wouldn't fit under the fairing.
The damping is adjustable, you can see the knob on the shaft end in the pic beside the measuring stick. If I left the knob in place, it would bash the inside of the fairing, so I adjusted it and then took off the knob.
For the record, it's adjusted to the minimum setting, completely cleans up the wobble.
Old August 20th, 2013, 01:35 PM   #20
FvnnyL3tt3r1ng
Well it looks like I might have to go with a Chinese maker since everything is either non adjustable (which I'm worried might be too soft) or wayyy too much money..... Oh well no need to dump a lot of $$ just to get rid of some wobble.
Old September 5th, 2013, 02:50 PM   #21
FvnnyL3tt3r1ng
Got my chinese steering damper in the mail today. I'm actually surprised of the quality but the true test is on the bike. It has 10 positions to adjust it to but I think the lowest setting is stiff enough. I'm not sure I could even turn the bars in time with the highest setting. I'll be figuring out how to attach it in the next few days. Stay posted!
I asked for a silver one but gold is fine. I hope this one has enough travel on it I measured the stroke at 2 7/8" but it does pivot in the center....
Old September 5th, 2013, 02:53 PM   #22
GeorgeRYoung
And the stroke is??
Old September 5th, 2013, 02:55 PM   #23
FvnnyL3tt3r1ng
And the stroke is??
Seems it would be 73mm???? Not sure that's correct I measured the exposed rod's travel...
Old September 5th, 2013, 04:36 PM   #24
FvnnyL3tt3r1ng
Just looked at the bike and saw something pretty cool... There are threads on either side of the steering tube they look around 6 or 8mm thick and could potentially be where I mount this beast! Go check your bike out...
Does anyone know what they are for??? I don't remember unbolting anything from there....
http://www.motosport.com/motorcycle/...-_-EX250/FRAME
Old September 6th, 2013, 07:13 AM   #25
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
i have damper and clamp dirt cheap for sale...
pm me if anyone wants it
The King
rabies is offline   Reply With Quote
Old September 6th, 2013, 07:27 AM   #26
cuong-nutz
cuong-nutz's Avatar
click me
closest thing I could find
Been trying to talk to the guys over in Thailand. One of the guys started making these not too long ago....
Yes, I know it's a for the new gen and you may not be able to get it and it's probably out of your price range.
HalfFast Racing Team
Old September 6th, 2013, 06:05 PM   #27
FvnnyL3tt3r1ng
Didn't know they made those brackets for the 250. Interesting
[motorcycle-usa.com] - Ohlins Recalls Steering Damper Bracket Ninjette Newsbot Motorcycling News 0 August 16th, 2013 09:20 AM
