Old September 23rd, 2013, 03:13 PM   #1
ChrisJuliano
Motorcycle(s): Ninja 250R
What RPM on highways for extended period of time?
I was riding with a group of people, who traveled at 80-90mph on average for close to an hour. I figured after that ride it was prob best to ask whats the rpm limit to which things arnt very good on your bike.
ChrisJuliano is offline   Reply With Quote
Old September 23rd, 2013, 03:36 PM   #2
Only way that it causes any damage is if you run low on oil, or extend the oil change interval way past recommended. Otherwise, the bike can run at high revs pretty much continuously.
Old September 23rd, 2013, 03:37 PM   #3
ChrisJuliano
I dont even know what the oil change suggestion is, but I plan on doing it every 1000-2000 miles.
So riding at 9k-10k for 1 hour straight isnt a issue?
Old September 23rd, 2013, 03:38 PM   #4
No. Maintenance schedule can be found in the sticky threads in the tech area.
Old September 23rd, 2013, 03:59 PM   #5
ChrisJuliano
Old September 23rd, 2013, 04:16 PM   #6
You can hold like 10k like forever as long as there are fluids to support it.
And my normal race practice session is 1 hour. So no, 10k for an hour straight isn't gunna hurt a thing considering us racers will be 10k - redline for an hour straight and then race it later in the day even harder for another 45 or so minutes.
Ride on!
Old September 23rd, 2013, 04:18 PM   #7
ChrisJuliano
Great!!! I was always so nervous riding at 90mph for a while but I guess I have nothing to worry about!
Thanks
Old September 23rd, 2013, 04:33 PM   #8
Old September 23rd, 2013, 04:59 PM   #9
Lychee
sail away
Lychee's Avatar
Just check your oil in the morning... The bike burns a little oil through normal operation, especially at high rpm (10k+). As long as you don't run out of oil you should be fine.
Old September 23rd, 2013, 05:27 PM   #10
ChrisJuliano
I changed my oil today so we got a fresh start
Old September 23rd, 2013, 07:32 PM   #11
IF13
WOT WOT WOT
Motorcycle(s): '12 Ninja 250R
Are we supposed to expect it to burn a lot of oil? I'm always on the highway. 1000 miles since last oil change and I've yet to see the oil level go down significantly.
May your roads stay clear....
IF13 is offline   Reply With Quote
Old September 23rd, 2013, 10:08 PM   #12
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
redline all day. My last oil changed that my friend helped me with was 5000 mile old oil and when we started draining he looked at me and was like, you sure this is old oil? it looks almost new.
Old Lemon is offline   Reply With Quote
Old September 24th, 2013, 05:39 AM   #13
parox91
Name: Not Applicable
Motorcycle(s): 2007 Blue Ninja 250
I have a 15tooth and my bike spends the majority of its time doing 85-95 mph
Occasionally if I want to get a taste of some speed wobbles, I'll hit 100+.
I have 12k miles on the bike and it still runs like a champ
parox91 is offline   Reply With Quote
Old September 24th, 2013, 08:47 AM   #14
IF13
WOT WOT WOT
Jealous. Mine's black in two days after an oil change. Then again, it's only my second oil change after having bought this bike brand spanking new.
Old September 24th, 2013, 08:53 AM   #15
Try a different brand oil.
Old September 24th, 2013, 09:47 AM   #16
IF13
WOT WOT WOT
That could seriously be the cause?
I think my last two oil changes have been non-synthetic Castrol oil with a 'motorcycle' written on it. I know I can take regular car oil with the proper certs, labels but it's been a pain to find one that isn't synthetic.
Old September 24th, 2013, 10:15 AM   #17
Sure, different oils have different additive packages. @iZapp could explain better than I but each oil can begin and end it's life cycle with different properties, such as color. Many things change their properties as they relate to heat and friction.
Old September 24th, 2013, 01:46 PM   #18
IF13
WOT WOT WOT
I'd assume constant highway usage and super aggressive local road use would be significant factors then.
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Highways CA 243 and 74 to Idyllwild TheTraveler Ride Reports 2 April 2nd, 2013 03:04 PM
more comfortable on the highways after... subxero Ride Reports 3 October 17th, 2012 10:06 AM
[kropotkin thinks...] - Doctors Expect Extended Recovery Period For Pedrosa's Shoulde Ninjette Newsbot Motorcycling News 0 March 29th, 2011 06:40 AM
Break-in and Highways? Tim250 2008 - 2012 Ninja 250R Tech Talk 9 June 8th, 2010 12:33 AM
