Old August 30th, 2020, 01:09 PM   #1
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
Angry Coasting Enricher
Howdy y'all.
I'm rebuilding my carb and I came across the coasting enricher which i opened and found the diaphragm needs to be replaced. In addition i found the spring changed to something different and the cap had some sort of puddy plug in the middle of it. I removed the puddy and have a coasting enricher cap with a hole right in the center of this. What do you all suggest I do? I haven't ordered my carburetor rebuild kit nor the diaphragm for the coasting enricher. I've looked all over the interent but havent found a photo of a coasting enricher with a hole right in the center or it.
JayVapes is offline   Reply With Quote
Old August 30th, 2020, 01:38 PM   #2
ducatiman
ducatiman's Avatar
just a guess from a distance....a PO drilled the cover in search of some sort of governing speed adjustment screw. Ooops. Then attempted to cover his tracks.
I run into errant drillings "in search of...." from time to time. Sometimes harmless and repairable, sometimes destructive and not.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 31st, 2020, 08:12 AM   #3
I’d say that coast-enricher is toast. Outside cap has vacuum nipple that goes to tiny 0.2mm hole to feed diaphragm. I suppose they drilled out that port for whatever reason. Then tried to fix it with putty. Don’t think you’re gonna be able to repair that for less than picking up new one.
surging when coasting, pod filter pb3 2008 - 2012 Ninja 250R Tech Talk 4 May 3rd, 2018 07:04 AM
Possible coast enricher failure?? gantt 2008 - 2012 Ninja 250R Tech Talk 11 November 21st, 2017 04:04 AM
Coasting enricher, what pipe goes where? RBN 1986 - 2007 Ninja 250R Tech Talk 2 July 9th, 2013 02:45 AM
Have a lean issue with my bike, issue with coasting enricher. twiggy2cents 1986 - 2007 Ninja 250R Tech Talk 7 February 24th, 2010 06:54 PM
