Old June 9th, 2014, 01:08 PM   #1
rasta
Your face
rasta's Avatar
Motorcycle(s): 2014 Honda CBR650f
Bike dies w/o choke
I was trying out my uncles Vulcan 500 yesterday. After riding around a bit with the choke on, I figured the bike was warm enough, so I shut the choke off. Whenever I came to a stop, the engine would shut off and wouldn't run again w/o choke.
What's the reason for that? I know he hasn't ridden the bike for a while, exactly how long I'm not sure right now. Is this an effect of old gas?
"even a proper fitting helmet can 'get loose'" -csmith
rasta is offline   Reply With Quote
Old June 9th, 2014, 01:09 PM   #2
Old gas or time to clean the carbs. Just because it's an older cruiser, don't mean much different between that and the ninja. Idle circuit mang.
Old June 9th, 2014, 01:16 PM   #3
clogged pilot jet
Old June 10th, 2014, 09:01 AM   #4
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
definitely clogged pilot jet
wardie
wardie is offline   Reply With Quote
Old June 10th, 2014, 01:54 PM   #5
cbinker
cbinker's Avatar
bad gas and/or dirty filter. I cleaned my filter on the 250 this weekend and it fires up like a champ now.
TEAM ALFALFA
www.apexassassins.com
Old June 11th, 2014, 10:28 PM   #6
rasta
Your face
rasta's Avatar
Hmm seems as if i must clean the carbs eh? Would running some seafoam through it do the trick? Or am I about to have my head chopped off for even suggesting the idea...
Old June 11th, 2014, 10:30 PM   #7
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
Depends on how bad the carbs are. Ran a tank of seafoam through my ninja and it did the trick for me
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Old June 11th, 2014, 11:10 PM   #8
corksil
Motorcycle(s): A lot.
Seafoam is the armchair psychologist diagnosis of depression... "just get out more"
I recommend the carbs get a good cleaning. Seafoam is the bandaid on the broken leg. Don't waste the bandaid until after you set the bone, put a screw through the fracture, and stitch up the wound.
cliffnotes
-seafoam after you clean the carbs
-i agree, idle circuit, pilot jet, mixture screws, water in the fuel, run ethanol free if the bike plans to sit for any period of time (unridden)
Old June 12th, 2014, 03:57 PM   #9
CycleCam303
King Hamfist
CycleCam303's Avatar
My dirt bike runs like garbage since I use it so infrequently. Really after 10 minutes of slapping the rev limiter it'll run fine. And I'm talking after not starting for 3 or 4 months.
Old June 12th, 2014, 04:11 PM   #10
Ninjinsky
Ninjinsky's Avatar
It's always the idle circuit and if cleaning that doesn't stop it you will have to clean it again until it does.
Seafoam does not dissolve rust particles, grit or any of the microscopic stuff you find on careful dismantling.
The future is fuel injection thank God. In 20 years we will wonder why we put up with carbs, just like we did with contact breakers.
Old June 12th, 2014, 07:14 PM   #11
DaBlue1
Long Time Rider
DaBlue1's Avatar
Originally Posted by rasta View Post
..... I know he hasn't ridden the bike for a while, exactly how long I'm not sure right now. Is this an effect of old gas?
Old gas, dirty air filter, low idle speed adjustment, dirty carbs, old spark plugs or all of the above. Take your pick. Start with the easy stuff first. Try Star Tron Fuel Treatment before you rip into the carbs.
Old June 13th, 2014, 03:43 AM   #12
reroka
Biker Noob
reroka's Avatar
Motorcycle(s): 2004 Honda Shadow 750 Aero
Could be your idle cable. I had this issue. When the idle cable came loose I could only run with choke on.
Riding as I stole it.
reroka is offline   Reply With Quote
Bike starts without choke rasta General Motorcycling Discussion 9 July 22nd, 2013 08:00 PM
Bike dies with choke after not storing properly... seamuswh 2008 - 2012 Ninja 250R Tech Talk 2 May 15th, 2012 10:47 PM
Help!! Bike not running without choke gaby 2008 - 2012 Ninja 250R Tech Talk 11 October 12th, 2011 07:15 PM
bike wont run without choke on? ReDnEcK 1986 - 2007 Ninja 250R Tech Talk 4 September 15th, 2010 08:50 PM
Bike keeps stalling when I closed the choke calpoly07 2008 - 2012 Ninja 250R Tech Talk 4 October 19th, 2009 05:17 PM
