Old April 23rd, 2020, 05:06 PM   #1
ssrsupermoto
Motorcycle(s): 2004 Ninja 250
Wet float height question
Ok I have a question about setting wet float height. Where on the carb should the level be set at. I will post two pictures, the first is measure the wet float height at the center of the float bowl and it’s dead on the money with the base of the carb body. The second picture it the float level at the front of the carb body (closet to the air box on the bike) and it shows low. Now this is with the carbs on the bike and they are at an upward angle. Where should the wet float height be measured front or center of the float bowl? When I set the wet float height I had the carbs off on a level surface. The red lines show the fuel level in the bowl, the fuel in the clear tubes was hard to see in the picture.
File Type: jpg F11CCFCA-F9B4-438B-AFBE-FF8CC6AAD06A.jpg (63.6 KB, 3 views)
File Type: jpg 1F021A4D-C94E-4218-AE2A-4AC57438ED87.jpg (67.4 KB, 2 views)
ssrsupermoto is offline   Reply With Quote
Old April 24th, 2020, 06:59 AM   #2
ducatiman
ducatiman's Avatar
"When I set the wet float height I had the carbs off on a level surface."
using level surface, a little below the bowl seam should be correct
though you've shown 2 clearly different levels on the bike....why the difference?
Explain, did you change levels to achieve? Why?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old April 24th, 2020, 07:07 AM   #3
ssrsupermoto
In both photo’s, I did not change the float height. When the carbs are mounted on the bike there at an upward angle. If you have the clear line placed in the center of the float bowl the level is right at the carb body. Move the clear line to the front of the float bowl it’s reads low. I assume this is because the carb are at an angle on the bike.
Old April 24th, 2020, 09:47 AM   #4
ducatiman
ducatiman's Avatar
what is your fuel source used in the photo's?
Custom Carb Service
Old April 24th, 2020, 11:58 AM   #5
ssrsupermoto
I use this auxiliary fuel source.
[motorcyclistonline] - Inside A Motorcycle Carburetor - Float Bowl Height Ninjette Newsbot Motorcycling News 0 March 26th, 2019 10:40 AM
Need help asap with float needle height M42 1986 - 2007 Ninja 250R Tech Talk 2 September 24th, 2014 01:14 PM
Should float height stay stock after rejetting? agentbad 1986 - 2007 Ninja 250R Tech Talk 3 July 6th, 2014 10:44 AM
Woodcraft clipon height question Colezombie 2008 - 2012 Ninja 250R Tech Talk 2 July 12th, 2011 01:45 AM
Carb tuning take 2 - AEM wideband info & has ANYONE adjusted float height? rwheelz 2008 - 2012 Ninja 250R Tech Talk 6 March 30th, 2011 06:43 AM
