Old May 5th, 2020, 09:12 AM   #1
NativeZombie
Motorcycle(s): 2002 Kawasaki Ninja 250
Smile Pilot Jet Screw Help
I dissassembled my carbs over the winter for some maintenance, and now that I'm putting them back together with my new parts, I can't seem to remember the default position for the pilot jet screw inside the float bowl. I already have my idle/mixture screw backed put a hair over 2.5 turns and for the life of me, I cannot remember whether the pilot jet screw goes all the way in lightly sealed or a number of turns back out. Any advice or recommendations would be awesome! Thanks!!
NativeZombie is offline   Reply With Quote
Old May 5th, 2020, 09:27 AM   #2
ducatiman
ducatiman's Avatar
confusing semantics.....the pilot jet screw and idle/mix screw are 1 and the same. Note NO bleed holes, pointy tip, spring, washer and o-ring. Yes, 2.5 out from lightly seated is the accepted starting position. Though note they are NOT located *inside* the float bowl.
The actual pilot jet (which IS located inside the bowl) gets reasonably tightened. Don't go all gorilla, you'll regret it later. Note YES bleed holes and non-pointy tip, no orings, springs.
Don't forget to check for presence of the needle jets, the silver things that so often "go missing". They get inserted under the emulsion tubes, the open end inserted downwards.
Yep, pilot adjust SCREW and pilot JET, differing locations and settings.
Good luck with it.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old May 5th, 2020, 11:31 AM   #3
NativeZombie
Thanks I really appreciate it. We're totally on the same page. I've definitely had some trouble with those semantics. I probably should have refrained from saying pilot jet "screw" despite it being threaded. But great!! That answers my question
Larger pilot jet james250ninja 2008 - 2012 Ninja 250R Tech Talk 8 June 15th, 2017 03:15 PM
Pilot jet Ram Jet 1986 - 2007 Ninja 250R Tech Talk 6 May 6th, 2017 02:05 PM
#40 Pilot Jet mrscbw 2008 - 2012 Ninja 250R Tech Talk 1 April 11th, 2011 11:33 AM
Need jetting help - 40 Pilot Jet necessary? chokne 2008 - 2012 Ninja 250R Tech Talk 5 March 26th, 2011 01:06 PM
pilot jet drstimpy 1986 - 2007 Ninja 250R Tech Talk 7 April 26th, 2010 08:03 AM
