Old January 22nd, 2024, 06:53 PM   #1
JayStreetfighter04
Motorcycle(s): 04 ninja 250
Idles great until put under a load
I have an 04 that I have been chasing issues with and need some more help. I replaced the Chinese carb with an oem carb, then traded/bought for a ducatiman refurbed carb, added back a factory airbox, and replaced the spark plugs. The bike started when I put the new carb on and idled great I got excited tried to ride and the bike loses power and wants to die when you stop, you can restart the bike and it idles again and sounds good but does the same thing. I don’t know what to check next.
JayStreetfighter04 is offline   Reply With Quote
Old January 23rd, 2024, 06:06 AM   #2
ducatiman
ducatiman's Avatar
total, overall mileage on bike? Petcock is operational? Fresh fuel?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old January 23rd, 2024, 09:40 AM   #3
JayStreetfighter04
Just short of 10k, fresh fuel, petcock is allowing fuel to get to the carb as far as I can tell.
Old January 23rd, 2024, 09:53 AM   #4
ducatiman
ducatiman's Avatar
at 10k, def suggest a valve clearance check. You have screw and locknut type valves...no need to pull cams.
using a catch can, remove the fuel exit hose from the petcock, crank for a few seconds and if working, your can should fill up in a few moments with fuel exiting the petcock and should stop when you stop cranking.
Let me know results.
Custom Carb Service
Old January 23rd, 2024, 10:45 AM   #5
JayStreetfighter04
For sure will do, little update though today it’s much warmer than it has been and I was able to ride it while choked around the block just fine, still dies unchoked.
Old January 23rd, 2024, 11:00 AM   #6
JayStreetfighter04
Ok so the petcock doesnt seem to be functioning, when its in the on position nothing comes out fuel does come out when in the res position but free flows. Order a new petcock correct?
Old January 23rd, 2024, 11:07 AM   #7
ducatiman
ducatiman's Avatar
can rebuild, i've got the parts right here. $50 plus parts. Let me know, ok?
Custom Carb Service
Old January 23rd, 2024, 11:19 AM   #8
ducatiman
ducatiman's Avatar
to clarify.....if my wet testing (after rebuild) reveals any leakage, NO CHARGE to you (parts included)
An FYI.....my famous, softer than stock diaphragm o-ring is included, swapped automatically.
Custom Carb Service
[crash.net - MotoGP] - Stoner: ‘Ducati not great at handling riders, they put stress Ninjette Newsbot Motorcycling News 0 November 4th, 2023 11:49 PM
[crash.net - MotoGP] - Marc Marquez: ‘Put on a great show’ at home but ‘keep calm’ Ninjette Newsbot Motorcycling News 0 August 29th, 2023 03:30 AM
[motogp.com] - Rins: "We'll put on a great show once we can race again" Ninjette Newsbot Motorcycling News 0 April 3rd, 2020 01:40 AM
Idles too high I think?? NinjaRed General Motorcycling Discussion 5 July 9th, 2013 10:18 AM
Still Idles high :( M-Oorb 2008 - 2012 Ninja 250R Tech Talk 40 April 17th, 2009 07:28 PM
