Old October 15th, 2012, 04:39 PM   #121
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
I normally do keep the petcock closed.
I have not tested for spark, I am about to do this. You just crank the engine while looking at the spark gap correct?
I went WOT during cranking and the engine sound doesn't deviate any.
I backed out the idle mixture screws 2.5x
I just got some fresh 93 oct gas so I can eliminate water in the tank. I saw that water was heavier than fuel so I'm guessing it would enter the engine first, however it wasn't raining in between the time I had the bike running and the time it refused to start....
Old October 15th, 2012, 04:42 PM   #122
the spark plug body needs to be in contact with the bikes ground (unpainted engine side cover (not the valve cover), battery negative etc)
Old October 15th, 2012, 05:30 PM   #123
FvnnyL3tt3r1ng
Spark plugs both work (I felt how well too). I'm starting to think I have damaged something in the engine to cause the compression to drop. I've eliminated everything it seems. What makes the engines compression drop??
The bike ran fine after I adjusted the valves could they have messed up somehow afterwards???
I do have an excuse to buy an air compressor + leak tester now....
Bad engine timing? I'm not too familiar with this department...
Guess I'll be re-doing the valves...Was hoping to have the kawi tool by the next valve clearance.
Old October 15th, 2012, 06:26 PM   #124
The whole frame is grounded as well. Just touch the spark plug to the frame or engine while the back it connected to the boot like normal, and watch it spark.
Old October 15th, 2012, 07:36 PM   #125
Rollingmenace
Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480)
just something to keep in mind here is when running your leak down test it is best to use a bicycle pump a compressor may give you too much air pressure
Rollingmenace is offline   Reply With Quote
Old October 15th, 2012, 09:53 PM   #126
FvnnyL3tt3r1ng
That saves me loads. I'm thinking a nut came loose in the rockers though. Don't air compressors have a cut off setting? I'd still like to do it for xperience/fun/nerd in me.
Old October 15th, 2012, 09:53 PM   #127
FvnnyL3tt3r1ng
Yeah I did it arced a la Ghostbusters and the right one "bit" me so I felt the POWER!
Old October 16th, 2012, 06:20 AM   #128
Rollingmenace
Nothing wrong with having toys for the garage .. I'm actually working on my own powder coating setup in mine I'm building oven myself.. As far as leakdown testing these ninjette motors I haven't read up on it yet but on the single cylinder 2 stroke motors I build we only use about 10psi and there would be no way to do that with my compressor hence using the bicycle pump.... If you really want to geek it up google leak down tester and you can build your own from stuff u can pick up at local hardware store for a fraction of the cost. Last one I put together for around 13 dollars
Old October 16th, 2012, 07:09 AM   #129
Yes, 10 psi will force each piston down with a force of around 46 pounds, if big leaks wouldn't be present.
"Well, I think this is an interesting test that .......tells you where the leaks are and you don't even have to have the gauge to do it.
The test is simple. Apply air pressure to the spark plug hole and listen. You will probably have to take the exhaust pipe and carburetor off plus remove the oil fill cap. Other then that, just listen. You will need at least fifteen or twenty pounds of air pressure. Higher pressure will make the sound louder but too much and you will need to lock the crankshaft to keep the engine from turning. A hissing noise at the carburetor manifold indicated a leak at the intake valve(s). Hissing at the exhaust, leaking exhaust valve(s). Hissing at the oil fill or at the engine breather tube, leaking past the rings.
For air pressure you can use a fancy spark plug hole attachment or just a rubber tip on a blow gun. You might need an extension for these hard to reach plugs too."
Old October 16th, 2012, 03:05 PM   #130
FvnnyL3tt3r1ng
How would the valves affect compression? Would it leave a portion of the valve open in the cylinder making the leak? I was pretty sure all was well after I did the valve adjustment and ran the bike for a few min. afterwards....Hopefully nothing is broken
Old October 16th, 2012, 04:08 PM   #131
Yes, if valves don't close perfectly or if their guides are worn out, compression will leak out and raw air will leak in (sucking less from the carbs).
Intake valves are typically larger than exhaust valves because the piston is moving away from it, creating a vacuum to pull a mix of air and fuel into the cylinder, which is not as efficient as pushing combustion gases out of the cylinder through the exhaust valves.
When new, valves close perfectly, since the angles of the cones are matching and the surface is perfect.
With time, and especially when working long time and hard out of specs (too little clearance), the surfaces may get damaged from not enough cooling (valve and head not together enough time) and hot exhaust gases leaking out.
Did you use a torque wrench and the recommended torque during your valve service?
Too little may let the nuts get loose and too much may break the rocker arms.
Old October 16th, 2012, 06:21 PM   #132
FvnnyL3tt3r1ng
I did not use my torque wrench because I believe the reading was in newton-meters and I didn't know the conversion rate so I tightened sort of like the spark plugs, tight plus 1/8 turn or so
Old October 16th, 2012, 08:16 PM   #133
I see.
That may be the source of the problems; so, it is worth removing the tank and valve cover for an inspection.
Check the proper torque here:
http://www.ninjette.org/wiki/Fastene...Specifications
Old October 16th, 2012, 10:40 PM   #134
FvnnyL3tt3r1ng
Took valve cover off, checked clearances, all was well.
Torqued to spec.
Bike won't start.
How would I go about putting fresh gas in? I have some in a container but doesn't the petcock of the tank have to be hooked up?
Old October 17th, 2012, 12:32 AM   #135
FvnnyL3tt3r1ng
How hard will it be to replace the piston ring(s) if I have to?
Old October 17th, 2012, 01:08 AM   #136
FvnnyL3tt3r1ng
I mean do you simply swap them on the piston? No special tools or procedure? Can I get to them by pulling off the "cylinder head"
http://www.kneedraggers.com/oem-part...mmy_source=oem
Old October 17th, 2012, 01:28 AM   #137
Lychee
sail away
Lychee's Avatar
After reading this thread, it is very clear that you are introducing problems while trying to fix others. You need to apply fixes for the problem at hand without doing other work that muddles the situation. While you are clearly capable of wrenching, it does not appear that you have the knowledge necessary to repair the current set of problems on the bike. I highly recommend you take the bike to a qualified mechanic. If you cannot afford the mechanic, you should junk/sell this bike now and buy another.
Take a step back and ask yourself if you should really risk your life riding this bike.
Old October 17th, 2012, 01:54 AM   #138
FvnnyL3tt3r1ng
The thing is, I don't know WHAT the problem is.... If it's something as simple as a torn vacuum line in the carbs, I would feel extremely stupid having ditched this bike that I put so much time/money/effort into. Once I know what the problem is I can make a more informed decision. If I did in fact damage something in the engine I will def. consider ditching it but until I find out I have to keep trying.
Old October 17th, 2012, 05:46 AM   #139
Torqued to spec.
Bike won't start.
Great! Those are good news.
I couldn't understand your last question.
Old October 17th, 2012, 08:41 AM   #140
FvnnyL3tt3r1ng
Well I was asking how to put fresh gas in from an auxillary tank but I think i'll just drain the existing gas into a bucket.
Old October 17th, 2012, 09:57 AM   #141
A full hose with the end up to the height of the tank would be sufficient.
If we cannot even start yet, you don't really need a tank.
The fuel inside the hose will give you several minutes of idle.
Storing gas in an open container is potentially dangerous.
Old October 17th, 2012, 10:05 AM   #142
FvnnyL3tt3r1ng
I'm trying to rule out bad gas even though I doubt it's the issue.....
Old October 17th, 2012, 10:21 AM   #143
Yes, that is a good idea.
The low compression is a fact.
We know now that all the valves are closing all the way; however, you still need to determine if surgery will be necessary due to leaky valves, leaky head gasket or leaky rings.
Old October 17th, 2012, 12:26 PM   #144
coughing skunk
Motorcycle(s): 07 ninja250r 73 xs650 70 honda cl100
Leak down test is certainly in order next to find out where you are losing compression.
I may have missed something in these four pages, but has the timing been addressed?
coughing skunk is offline   Reply With Quote
Old October 17th, 2012, 12:32 PM   #145
FvnnyL3tt3r1ng
No it hasn't do you know how to check that?
Old October 17th, 2012, 12:39 PM   #146
Turn the engine to the 2T mark. There are white paint marks on the back of your cam gears. On one cam, this mark with be next to writing that says, "EX". On the other cam, this mark will be next to writing that says, "IN". The marks should be facing opposite ends of the bike, parallel to the cam cover.
If they're lined up right when the engine is at the 2T position, your cams are timed right.
Old October 17th, 2012, 04:49 PM   #147
FvnnyL3tt3r1ng
Before I start how did you guys manage to use a bike pump w/ the leak down gauge? Was it compatible with the gauge you were using or did you have to rig something up?
Old October 18th, 2012, 11:34 AM   #148
FvnnyL3tt3r1ng
Tried to do the air pump+leak gauges but I need my hands free to work plus the gauges don't seem too respond to the bike pump so I'm going to buy an air compressor (and run it at low psi).
When I blew air directly into the left cylinder the air came out of the vacuum line that goes to the petcock. I set the engine at TDC based on the readings ontop of the alternator.
I checked the timing by setting the alternator reading to the white line (2t?) and opened the valve cover. From the right of the bike the exhaust side points at 2 oclock and the left side points at 9 oclock...Not perfectly parallel.....
Old October 18th, 2012, 11:51 AM   #149
Triple check that!!!!
There should be a 1T marking and 2T marking in there. Make sure you're at the 2T marking.
I've got pictures of how the cams should look from the 1T marking from when I had my engine apart, but they're easier to time from the 2T marking.
Old October 18th, 2012, 11:52 AM   #150
FvnnyL3tt3r1ng
Timing cover on alternator:
Left side of bike:
Right Side of bike:
(If you can't see the left mark is facing left and cut in half by the valve cover gasket and the right side is pointing up and to the right.
Old October 18th, 2012, 11:58 AM   #151
FvnnyL3tt3r1ng
Could you post the pic(s) please? I'd really like to check mine against yours.
Old October 18th, 2012, 12:04 PM   #152
When I did mine, the "EX" and "IN" markings were on the inboard side of the cam gears IIRC.
Look across the engine from the left side of the bike, like this:
There should be white markings that will face opposite ends of the bike, parallel to the cam cover. This picture is at the 1T mark. Notice on the intake cam gear, there's a little white mark facing up? At 2T that should be facing the back of the bike. There's a matching one on the exhaust cam that faces the front at 2T.
I can't see any markings on your flywheel in the picture... Maybe it's just because it's a camera
Old October 18th, 2012, 12:29 PM   #153
The 2T mark means that the piston #2 is at the top dead position, position at which the four valves of that piston should be perfectly closed.
Old October 18th, 2012, 12:32 PM   #154
^^ Thanks Hernan!
That shows the "IN" and "EX" better than my picture, which only kinda shows the "IN" if you look at it. Not to mention, mine's at the wrong place in the cycle. Yours is better.
Old October 18th, 2012, 12:39 PM   #155
You are the one helping, Chris; I am just supporting.
Note that both gears have the IN and EX stamped on, since they are both the same part.
The marks should align with the flat metal surface, not with the gasket.
Of course, the EX only applies to the camshaft closer to the exhaust and the IN only applies to the camshaft closer to the carbs.
To be more precise, count the number of links between marks, as the schematic shows.
Old October 18th, 2012, 12:49 PM   #156
FvnnyL3tt3r1ng
Are those the chain pins?
Old October 18th, 2012, 01:38 PM   #157
FvnnyL3tt3r1ng
The intake side is pointing 12 oclock and the exhaust is level with the metal piece pointing inwards...
exhaust side at TDC:
Intake side at TDC:
I'm not sure if the sprockets were just installed weird or the timing is actually off? Lemme check chone's picture against it first.....
If they are off what causes them to do this??
Old October 18th, 2012, 01:41 PM   #158
FvnnyL3tt3r1ng
Ok the rockers are facing the same direction as choneofakind's picture( and on both cylinders)....
Edit: Ok I realize now the position of the markings on the sprockets don't matter at TDC. I counted 33 links as the diagram showed....I guess the next step is the air compressor/stethoscope to find out where the leak is!!!
Old October 18th, 2012, 03:26 PM   #159
FvnnyL3tt3r1ng
Results of leakdown test are as follows:
Cylinder 1 (left):
>80%+ @ 10 psi (compressor could hardly even get to 10psi)
Cylinder 2:
~37% @ 10 psi (gauge said this was ok but I'm not sure if I should believe it)
Is it safe to assume cylinder 1 may be jacked up while cylinder 2 is fine?
I couldn't hear where the air was coming from btw, I did hear it hissing from the spark plug hole obviously but I couldn't locate it exactly, even with a stethoscope.
I remember one of the first replies was "Happened to me when I blew a ring on my cbr"
Looks like I will be doing surgery. I really wish this could have happened at another time.
Old October 18th, 2012, 03:35 PM   #160
coughing skunk
Yup, its most likely bad rings or bent valves.
I was asking about the timing because I thought it could be bent valves, esp since I *think* you said you had it running momentarily. If the timing was off you could've smashed your piston into a valve, bending it.
08 has low power and will not rev past 10k Donnyd21 2008 - 2012 Ninja 250R Tech Talk 9 September 17th, 2014 06:11 PM
Bike wouldn't rev past 6k, then died 1994Ninja250F 1986 - 2007 Ninja 250R Tech Talk 9 May 9th, 2014 04:17 PM
Won't rev past 5k :( hoodadooda 2008 - 2012 Ninja 250R Tech Talk 7 December 24th, 2012 08:56 PM
Engine Won't Rev Past 12k fujimumu 2008 - 2012 Ninja 250R Tech Talk 8 May 19th, 2010 03:35 PM
Driving a cage after driving a bike brian997 General Motorcycling Discussion 23 December 21st, 2008 01:01 AM
