Old March 22nd, 2019, 06:24 PM   #1
minimatt
minimatt's Avatar
How to unstuck a rusted clutch cable adjuster?
Clutch is a bit loose. Need to adjust it, however previous owner neglected the bike and the twisty cable adjusters located next to the clutch lever on the handlebars is stuck and won't twist. I've tried WD40 penetrating fluid and let it sit for a couple hours to no success. My hands alone probably can't get a good amount of torque. Is there a tool I could use specifically for this? I assume the notch in the circular nut is for something?
minimatt is offline   Reply With Quote
Old March 22nd, 2019, 06:31 PM   #2
Undo locknut first. Spin it away from lever. Right-hand rule.
Use some pliers or channel-locs if necessary.
Old March 22nd, 2019, 06:35 PM   #3
ducatiman
ducatiman's Avatar
its there for cable removal/install process
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Clutch cable adjuster nut sparky80 Items Wanted 1 January 25th, 2015 12:34 PM
Need Clutch cable adjuster JasonJ Items Wanted 0 June 20th, 2014 09:53 AM
