April 16th, 2011, 05:20 PM | #1 |
Join Date: Mar 2011 Motorcycle(s): 2008 Green Ninja 250r Posts: 58
Left turn signals not working properly
I brought my bike in for a proper cleaning of the carbs and when I got home later after picking it up when it was ready I noticed the left turn signlas (back and front) were't working properly. the front one won't even turn on, and the rear one doesn't blink. Also, the light on the 'dashboard' won't blink either, just stays on.
The right signals work fine and the one on the dashboard as well for the right. Before I open her up, I'm wondering what I should be looking for.. I'm a big noob with bikes. I don't want to have to bring it back in at the shop, I want to do it myself. Thanks |
April 16th, 2011, 05:26 PM | #2 |
did you forget to reconnect the connector for the blinker when you put the fairing back on?
April 16th, 2011, 05:40 PM | #3 |
Like I said I had the shop do the work so manybe they forgot ill take a look inside after I eat
Posted via Mobile Device |
April 16th, 2011, 05:46 PM | #4 |
it's happened to me more than once... I'm a slow learner.
take the side panel off and usually the connector is sitting right there. http://www.ninjette.org/forums/showthread.php?t=9933 |
April 16th, 2011, 05:50 PM | #5 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
While I was doing some carb tuning, I road around without front signals. The rear signal lights did the same as you described. The connection might be accessible without taking off the fairing. Look right where the black side panel(below the seat) meets the fairing.
April 16th, 2011, 07:07 PM | #6 |
Signal is either blown, disconnected, or shorted.
April 16th, 2011, 07:27 PM | #7 |
haha I feel stupid for posting a thread about this in the first place. The wires weren't even connected. works fine now after the 15 seconds it took to take the side panel off.
my ego took a small hit though |
April 16th, 2011, 07:38 PM | #8 |
glad it was something simple.
no turn signals working | kaosyin | 2008 - 2012 Ninja 250R Tech Talk | 3 | January 29th, 2015 04:53 PM |
Turn signals stopped working. | Insan3guy | General Motorcycling Discussion | 1 | October 15th, 2013 10:17 PM |
Turn Signals not working correctly | aspenratt07 | 1986 - 2007 Ninja 250R Tech Talk | 5 | April 1st, 2013 08:46 PM |
cluster not working properly after rain | Oaklandish | 1986 - 2007 Ninja 250R Tech Talk | 6 | October 8th, 2011 07:21 AM |
LED brake/tail lights not working properly... | sktrs_kpr | 1986 - 2007 Ninja 250R Farkles | 1 | April 8th, 2010 09:59 AM |
