Old March 18th, 2022, 10:54 AM   #1
Ducremus
Motorcycle(s): 1994 EX500, 2006EX250
No Vacuum Petcock
Does anyone have source for a non-vacuum actuated petcock that'll fit my '06 EX250? Thought I could mod the standard new petcock I got on Ebay to remove the vacuum portion, but that didn't work and now there's gas all over the bike....
Ducremus is offline   Reply With Quote
Old March 18th, 2022, 11:33 AM   #2
/moved to pre-gen tech
Old March 18th, 2022, 11:53 AM   #3
What was wrong with ebay petcock?
If it functions properly, it should open and close by vacuum from carbs.
The sealing done by main flow section is independent of vacuum diaphragm.
https://faq.ninja250.org/wiki/Rebuil...tcock/fuel_tap
Old March 18th, 2022, 03:17 PM   #4
Ducremus
I'm using Keihin CR carbs that don't have a vacuum line.
Old March 19th, 2022, 02:54 AM   #5
try manual petcock like this.
https://www.ebay.com/itm/154396070531
I would confirm measurements with them as many of these are too short. The lever ends up hitting inside of tank and it can't be installed.
Old March 19th, 2022, 04:59 AM   #6
Ducremus
Thanks!
Old March 19th, 2022, 06:35 AM   #7
ducatiman
ducatiman's Avatar
properly
modded, via blocking/elimination of the vacuum portion, it should work fine manually. Send 'er on up here.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 19th, 2022, 08:43 AM   #8
Ducremus
Hey Gordon,
Thanks for chiming in! I did find one from Ebay that says it'll fit, but who knows. If it doesn't fit I'll send it along.
BTW, any interest in the stock carbs?
Rich
Old March 19th, 2022, 08:56 AM   #9
ducatiman
ducatiman's Avatar
PM a comin'
Custom Carb Service
Old April 5th, 2022, 03:38 PM   #10
ducatiman
ducatiman's Avatar
@Ducremus some feedback/status on the newly modded petcock?
Custom Carb Service
Old April 5th, 2022, 04:19 PM   #11
Ducremus
Petcock repair (after I mangled it!) came out great! Put it on the bike, added fresh gas, no leaks, and fired up the bike up. Thanks again, Ducatiman!!
Old April 5th, 2022, 04:57 PM   #12
ducatiman
ducatiman's Avatar
just for you, @Ducremus
Custom Carb Service
Old April 5th, 2022, 07:26 PM   #13
punishum808
punishum808's Avatar
Motorcycle(s): Suzuki JPN Katana 750 , 1994 Suzuki Pro Stock Motorcycle , 2001 Ninja 250
I used a racing pingel one.
punishum808 is offline   Reply With Quote
Vacuum-Less Petcock ninjunk 1986 - 2007 Ninja 250R Tech Talk 14 August 24th, 2023 11:30 AM
Is pregen petcock operated only on a vacuum like the newgen? daverdfw 1986 - 2007 Ninja 250R Tech Talk 5 April 19th, 2017 07:05 AM
Guess I Had a Vacuum Leak in the Petcock VaFish 1986 - 2007 Ninja 250R Tech Talk 18 November 16th, 2015 01:55 PM
Removing the vacuum spring from the petcock. berserk81 General Motorcycling Discussion 5 November 5th, 2013 08:07 PM
Vacuum nipple came off petcock - fix or replace petcock? fierostetz 1986 - 2007 Ninja 250R Tech Talk 3 November 24th, 2012 11:03 AM
