Old November 5th, 2012, 08:50 PM   #1
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
Incredibly tight factory bolt. Halp
So i decided id do my oil change today, i know there are a million DIY threads and a few videos, so i found jiggles DIY here.
http://www.youtube.com/watch?v=Xc7l2A3pOsg
following the DIY to the T, already had the fairings off, was on the left side of the bike, drained the oil, while the oil was draining i attempted to take off the oil filter bolt and after 4 attempts its almost completely rounded off on the left side. This damn bolt isnt moving an inch...but now its slightly rounded off where the wrench fits into the bolt and before i fck it up anymore i was wondering if anyone here might have any ideas. I'll take a few pics in a min. cam battery is charging.
Aggrotech is offline   Reply With Quote
Old November 5th, 2012, 08:53 PM   #2
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Are you the first owner? Somebody tightened it wayyyyyyyyyyy too tight last time. Maybe a torque wrench? Get more leverage somehow? Buy a 300?
Trailerboy531 is offline   Reply With Quote
Old November 5th, 2012, 08:54 PM   #3
Imma ask a really dumb question.
Was you turning it the right way? Ask me how I know.... It should be nowhere near tight enough to round off.
Old November 5th, 2012, 09:12 PM   #4
Aggrotech
Aggrotech's Avatar
yup turning it the right way. I'm the first owner, bought it brand new...it is my DD so it needs to get fixed one way or another. How screwed would i be if i put my brand new oil in with the old oil filter?
Heres the oil filter bolt. remember, this is what it looks like now after just 4 slow turns and 1 little tug with 2 hands.
and heres the Oil drain bolt.
Huuuuge difference.
Old November 5th, 2012, 09:23 PM   #5
Well, the sky is not gunna fall but..... just means your gunna need to change the oil again as soon as you can get the bolt loose.
Is this the first oil change? Because if it is, I would say it's even more important to do an oil change ASAP.
Old November 5th, 2012, 09:29 PM   #6
Aggrotech
Aggrotech's Avatar
yup first oil change. Even though its late i'll go out and finish it if i can manage to get this fcking thing off. its really pissing me off lol. I tried 3 different 17mm length wrenches and of course the stock wrench that comes with the bike + added attachment for extra leverage. It just isnt movin. Would heating it up slightly make any difference?
Old November 5th, 2012, 09:36 PM   #7
You have a 6 point 17mm socket? See if you can get that on the bolt, a hammer may help. 12 points (common) have a tendency to round off really tight bolts.
Old November 5th, 2012, 09:39 PM   #8
Aggrotech
Aggrotech's Avatar
Not completely sure. I know i got some 12point sockets lyin around in the garage. I didnt find any 6point sockets when i looked though
Old November 5th, 2012, 10:33 PM   #9
Trailerboy531
6-point are the way to go and you really should make sure you're going the right way. I screw that up often I just don't go too far and I've seen many others screw up. As Chris said using a hammer to get a socket on isn't a bad idea.
Old November 5th, 2012, 10:40 PM   #10
Were you using a crescent wrench to get that loose? Get a set of 6 point metric sockets. Round heads are bad.
In the mean time, you might want to look into replacing that thing once you're able to get it off.
Old November 5th, 2012, 10:40 PM   #11
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Mine is rounded off like that from the wrench slipping. Socket wrench is the way to go if a normal wrench is causing that
AFM #676
Supersports are for n00bs
Old November 5th, 2012, 10:53 PM   #12
Aggrotech
Aggrotech's Avatar
hmmm yeah i'll look around for some 6 point attachments. How would i go about getting it off if i end up making it worse than the pic i already posted? Also, how likely would it be that its just a bad/defected/low quality bolt? I didnt yank on it all that hard at all any of the times and it managed to do all of that damage. Is there any place id be able to buy a replacement? Cyclegear? dealership?
Old November 5th, 2012, 11:03 PM   #13
Jono
Jono's Avatar
Since it's so rounded off already I doubt you"ll get it off with a socket. Try some vice grips. Really lock them on there tight and see if you can get it to turn. I am surprised it was that tight from the factory.
Old November 5th, 2012, 11:04 PM   #14
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Kawi tightens the **** out of all oil bolts. Dey crazy, no forrow torque structions
AFM #676
Old November 5th, 2012, 11:11 PM   #15
Eh, I was thinking that you could use a file and flatten the sides out enough to get it to sit in a socket. Idk how well that would work though.
Old November 5th, 2012, 11:21 PM   #16
Bassman
Bassman's Avatar
Motorcycle(s): 1986 Goldwing, 1996 CR500, 2011 Ninja 250, 2009 Harley Heritage Softail, 1941 Suzuki Gerbil 250
I'm think'n all Ninja's were assembled with a 1000 ft/lbs impact wrench. You either need a welding torch or an impact wrench to take it apart. See Harley has got it figured out already... you just run the bike till the parts fall off naturally, rofl... I so crack myself up!
I know there's a 7th gear here somewhere...
Changing to 15T/41T, now I'll get that 7th gear, lol.
Bassman is offline   Reply With Quote
Old November 5th, 2012, 11:22 PM   #17
Bassman
Bassman's Avatar
Yikes! Clone! no dunce cap? I don't know you anymore!
Old November 5th, 2012, 11:30 PM   #18
Aggrotech
Aggrotech's Avatar
well i found a torque wrench, with a tonnn of 12 sided attachments, found 1 6sided 17mm attachment but it wont fit due to the 1/2 size main attachment. Think i might be screwed.
/RAGE
Old November 5th, 2012, 11:36 PM   #19
haha, I thought I'd mix it up a little!
Old November 5th, 2012, 11:37 PM   #20
Bassman
Bassman's Avatar
I know it's one more thing to buy, but just get the 3/8 to 1/2 and get it done. I feel for ya though. It seems like I've bought every tool known to man. All I need now is a CNC machine to manufacture all the parts myself, lol.
Old November 5th, 2012, 11:39 PM   #21
Aggrotech
Aggrotech's Avatar
ugh i hate driving teh car. ithe 17mm i found still manages to fit perfectly over the oil filter bolt lol, just cant find a torque wrench to fit the 17mm attachment
damn! i want go to riding nowwwwww
Old November 5th, 2012, 11:44 PM   #22
Bassman
Bassman's Avatar
I wish I was closer; I'd drive over and just give you my tool box so you could get it done. Hang in there, we've all felt the frustration.
Old November 5th, 2012, 11:52 PM   #23
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Get a vice grip and attach it with a kung-fu grip, order a OEM replacement bolt and a 6-point 17MM socket for the future.
menikmati is offline   Reply With Quote
Old November 6th, 2012, 12:04 AM   #24
Aggrotech
Aggrotech's Avatar
SUCCESS!
Managed to finally find the right sized torque wrench under a bag of bullet casings and black widows and what not. put on the 17mm, hammered it in just in case, positioned the torque wrench properly...pulled out our mini sledge hammer and hulksmashed that bitch (yes, it took 3HITS with a ****ing sledgehammer to unscrew it.) Yay, now i just need to find a replacement.
How safe would it be for me to half ass put it back on so i can ride around, find a replacement then swap out the bad one for the good one?
Old November 6th, 2012, 12:07 AM   #25
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Originally Posted by Aggrotech View Post
SUCCESS!
Worst case scenario your oil filter falls out at high rpms destroying your engine and dumping oil all over your back tire causing you to lowside into a ditch where you are promptly buttraped by a bobcat.
Best case scenario, you get it on film
AFM #676
Old November 6th, 2012, 12:08 AM   #26
menikmati
SUCCESS!
...did you mean you found the right socket wrench? A torque wrench is for...torquing things to spec.
I wouldn't half-ass it if you can't get the bolt snugly back in to create a good seal with the large o-ring so that it doesn't leak oil. You're going to have to change the oil again anyway when you want to replace that bolt since it goes through the entire oil filter assembly.
Old November 6th, 2012, 12:09 AM   #27
menikmati
At least he already has an R6.
Old November 6th, 2012, 12:10 AM   #28
You hit a torque wrench with a hammer?? dude, that's not good on the torque wrench. I hope that was just a ratchet, not a torque wrench.
Old November 6th, 2012, 12:10 AM   #29
Aggrotech
Aggrotech's Avatar
Yes, Socket wrench . and jiggles, I dont ride around with any gopros or cameras. i plan on getting 2 gopro hero 3's though. If i would have filmed my very first crash everyone would just laugh. THE CATS...THEY WERE EVERYWHERE Still have nightmares from it.
and no R6 btw, its what i want and wanted to upgrade to though. seat height is incredibly high and it just feels...weird. I ended up hitting the very edge of the socket wrench to get that bolt to finally MOVE, regardless id say its a success. socket wrench has no damage due to the rubber padding on the sledge hammer.
Old November 6th, 2012, 12:16 AM   #30
Jiggles
Jiggles's Avatar
MOTM - Apr '13
bitch if he had an r6 then why would he be complaining about not being able to ride?
Y U NO BRAIN?
AFM #676
Old November 6th, 2012, 12:18 AM   #31
menikmati
Y U NO BRAIN?
wait, wut? Oh, he eventually wants an R6. I thought he had an R6 that he named Endgame or some ****.
I can read, Supernintendo Chalmers.
Old November 6th, 2012, 01:15 AM   #32
Hopefully one would tap the socket on and then put on the ratchet/torque wrench.
Old November 6th, 2012, 01:21 AM   #33
The damage to the wrench would be in the head. To the little gears and such inside. I was hard pressed to remove 16 head bolts, all torqued to 95lbs. It broke my wrench. Craftsman replaced it for free.
Glad you got it off and hope you have lifetime replacement on your tools.
Old November 6th, 2012, 01:28 AM   #34
Aggrotech
Aggrotech's Avatar
welllll i didnt really HIT IT i guess you could say..i just lifted the hammer up and let gravity do its thing. Its an extremely old socket wrench, nothing new or fancy, or even expensive and of course i tried on my own using brute strength with no luck at all..so what else was i to do?
Old November 6th, 2012, 01:34 AM   #35
It's all good yo, I am sure plenty of everyone's tools "take one for the team" every now and then.
Old November 6th, 2012, 07:12 AM   #36
Holy superhuman strength batman!
I love Craftsman's warranty.
Old November 6th, 2012, 11:38 AM   #37
Trailerboy531
bahahahahahahahh
Old November 6th, 2012, 11:42 AM   #38
sorry guys, but the correct answer is "use a closed loop 6side wrench with a small persuader or the double wrench torque trick" or if the thing is already rounded "use an extractor bit, hammer it on if it wont fit immediately"
Old November 6th, 2012, 12:02 PM   #39
...........How safe would it be for me to half ass put it back on so i can ride around, find a replacement then swap out the bad one for the good one?
Now that the bolt is out and you have found the correct tool, fix that hex head with a file as perfectly as you can, lubricate both o-rings well, torque the bolt as recommended and add some safety wire if you want to be extra careful.
Don't half-ass anything: ride away and order a new bolt for the next change, when you won't have any problem to destroy the current one if needed (I bet you will not need doing so).
Be more gentle in the future, Justin, your bike is a sophisticated lady and a noble machine.
Old November 6th, 2012, 12:29 PM   #40
Jiggles
Jiggles's Avatar
MOTM - Apr '13
For real aggro, you ripped her nipple off, be more careful.
AFM #676
Bolt to shift lever on too tight antiant General Motorcycling Discussion 12 July 12th, 2014 09:23 PM
Incredibly Lucky Skullz Videos 11 February 8th, 2014 06:59 PM
Factory Bolt On's (from Kawi UK) HKr1 2008 - 2012 Ninja 250R Farkles 5 January 8th, 2009 04:38 PM
