Old August 27th, 2013, 09:58 PM   #1
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Rear seat lock not working anymore
Yesterday in the middle of the day after I had accessed the trunk a few times, I found that the key would no longer unlatch the rear seat. The key would turn all the way but nothing would happen. I ended up using an allen wrench to pull the cable and unlatch the thing. Upon further inspection, turning the key will make it start to unlatch but it never fully unlatches. It stops halfway and actually goes back a little bit. Any idea how to fix this? Opening it with an allen wrench isn't hard, but it looks a little ghetto
Old August 28th, 2013, 06:13 AM   #2
Have you tried to lube it? (the cable as well as the lock unit)
Old September 3rd, 2013, 01:57 PM   #3
tfkrocks
tfkrocks's Avatar
I did. No effect. If anything, the mechanism at the lock seems too loose.
Old September 3rd, 2013, 10:11 PM   #4
atomic
Motorcycle(s): 2017 Ninja 300
Look at part number 27016 in the below diagram. The little plastic part that keeps the cable end from moving likes to break.
http://www.kawasakipartshouse.com/oe...cks-reflectors
atomic is offline   Reply With Quote
Old September 3rd, 2013, 10:16 PM   #5
tfkrocks
tfkrocks's Avatar
Hah, that's it. The plastic looked broken but I wasn't entirely sure. Got any quick fixes for it or will I be forced to replace it/continue using an allen wrench as a key?
Old September 3rd, 2013, 10:45 PM   #6
atomic
If there is anything left of the plastic bracket, you can use safety wire or something to bind the cable end to the bracket. That was my fix until the whole thing broke off. I was hoping this thread would give me some more time before I needed to order the part, but I think I'm going to cough up for a new one.
EDIT: So I found a way to wire it up without any part of the original plastic bracket. First i secured a length of wire around the collar of the cable then I positioned the cable so that it is not pulling on the lock and ran the wire back to the helmet hook, wrapped it a couple of times around the helmet hook. Then I ran the wire up to the cable and secured it - again making sure not to put tension on the lock. I took a picture if that makes it easier to understand.
Old September 3rd, 2013, 11:38 PM   #7
tfkrocks
tfkrocks's Avatar
I'll go **** around with it later when I have time and see if I can make something work haha. I really don't care to pay for a new part.
Old September 23rd, 2013, 09:10 AM   #8
tfkrocks
tfkrocks's Avatar
Oh yeah I never updated this. Seat lock works again after I safety wired things in place. I noticed the seat doesn't make a solid click into the lock anymore, but it still locks all the way so it shouldn't be a problem.
Old September 23rd, 2013, 09:39 AM   #9
Panda
not an actual panda
What did you use to secure the wire?
Old September 23rd, 2013, 09:46 AM   #10
tfkrocks
tfkrocks's Avatar
It's twisted tightly to itself.
Old October 20th, 2013, 10:53 AM   #11
tfkrocks
tfkrocks's Avatar
@ninja820
Here I took a picture. Ignore the extra straps and things. I circled the cable you're supposed to hook the allen key onto. Slide it under the seat flat first until you're over the cable and then turn it so it can catch onto the cable. Then pull in the direction of the arrow and lift the seat at the same time.
Old October 20th, 2013, 11:40 AM   #12
ninja820
Motorcycle(s): Ninja 250r
@ninja820
@tfkrocks
I was trying on the other side lol (thinking from the left side when facing the lock)
I tried an allen wrench but had no pull capability so I got a bungee cord and was able to get it latched onto the cable but no luck unlocking it
It seems like the cable is stuck on something. Any suggestions?
ninja820 is offline   Reply With Quote
Old October 20th, 2013, 11:49 AM   #13
tfkrocks
tfkrocks's Avatar
Originally Posted by ninja820 View Post
@tfkrocks
Well the reason this worked for me was because part of the plastic that holds the cable tight broke and so the cable wasn't pulling all the way anymore. It might not work if you don't have the same problem.
You don't have to both quote and mention me lol. Either one of them will get my attention
Old October 20th, 2013, 12:08 PM   #14
ninja820
@tfkrocks
I asked my brother in law for help and he got the seat off!
For anyone who might run into this problem take a long flat screw driver and on the opposite side of the cable push the latch in with the flat screw driver and it will unlock the seat. If anyone needs a picture for demonstration I can take one.
Lock that Fits Under the Passenger Seat Ralgha General Motorcycling Discussion 4 February 1st, 2014 05:08 PM
Passenger seat lock jammed ninja820 2008 - 2012 Ninja 250R Tech Talk 2 October 20th, 2013 12:25 PM
seat lock bypass kslane 2008 - 2012 Ninja 250R Farkles 2 August 18th, 2013 06:03 PM
seat won't lock focus101 1986 - 2007 Ninja 250R Tech Talk 10 May 30th, 2013 06:24 PM
any way around the seat lock? rabies 1986 - 2007 Ninja 250R Tech Talk 6 September 9th, 2012 07:16 PM
