Old April 9th, 2015, 07:23 AM   #1
Jason5885
Jason5885's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r FI
Question Are newgen front/back pass the same?
I want to get EBC Kawasaki Ninja 250R (2008 to 2012) EBC Front Brake Pads and Rear Brake Pads (FA197HH)
I've called my local dealer and they have sets, but they don't state weather they are for front or rear. Are the pads on the front identical to the pads on the rear?
Thanks guys
Jason5885 is offline   Reply With Quote
Old April 9th, 2015, 07:36 AM   #2
cuong-nutz
cuong-nutz's Avatar
Yep, they are the same. Just be aware that the rear will lock up easy.
HalfFast Racing Team
Old April 9th, 2015, 08:53 AM   #3
Jason5885
Jason5885's Avatar
Great, thanks buddy. Why is that? Do they grip the rotors much harder than stock? I'm guessing I will have to alter my breaking style ?
Is it common to go sintered on both front and back ?
Old April 9th, 2015, 11:19 AM   #4
cuong-nutz
cuong-nutz's Avatar
I say that as a precautionary measure for newish riders who are not quite seasoned or familiar with the braking capabilities of their bikes.
Old April 9th, 2015, 11:24 AM   #5
Ghostt
Ghostt's Avatar
The rear always does, due to the weight distribution of the bike, one must remember that the front does most if not all the stopping in a panic stop especially. The front does about 90% of the stopping power.
Something else to keep in mind is the calipers, they need to be serviced with every pad change, to ensure optimal performance, I personally recommend it.
Here is my how-to guide.
For those of you whom are scratching their heads, here you go,*
Front Caliper Service (also rear as well)
Many folks have posted here with a Varity of front brake problems.*
*Many of which are attributable to the lack of proper maintenance.
*Here’s how you can always have a brake like when your bike was new.
A short list of the problems and the causes.
Soft lever or lever goes to the bar.
The usual cause is the pistons are pushed too far back into the caliper by a flexing a warped, coned, disc.*
*Using up too much piston travel before the disc is pinched.
Juddering in sync with wheel rotation.
The disc is worn, and its thickness varies. *This causes the caliper to “sink” into the thin part and when the thick part comes around, it gets wedged into a smaller space causing a tightening of the brake. Then the tight spot passes through and it like the brake is released. Then repeat, repeat.
Cupped, coned, or warped disc.
Unfortunately this is a common problem with EX’s the cause is the disc is stretched in the center due to being rigidly bolted to the wheel. *The huge force of braking is transmitted to the wheel through the webbed center of the disc which gets stretched and becomes larger than the space it occupies in the center of the disc. This causes the center to push to the side trying to find room for itself.*
*Resulting is a cone shaped disc.
Soft lever 2
The caliper has pistons only on one side, so as the pads wear the caliper must shift sideways apply even pressure on both sides of the disc.*
*To allow this the caliper floats on two pins. *If these pins get dry (no grease) dirty or bent. The caliper won’t center itself and bends the disc to wherever it is.
*This take up lever travel and when released pushes the pistons further back than necessary.
**If not fixed will eventually destroy the disc (warp it).
Ok how to prevent all of the above.
When new pad time comes around, resist the temptation to just pop in new one and go.
*Every time you must do these things.
Remove caliper disassemble and clean it.
Clean and re grease the sliding pins.
Polish the caliper pistons to remove dirt. If you just push the pistons back into the caliper leaks will result. Or binding.
Tools required:*
12 mm socket
8mm open end wrench
3” or bigger C clamp
a supply of new bake fluid.*
wire brush and or steel wool.
Remove the caliper from the fork leg but leave the brake line on.
Remove the old pads and the mounting frame (the sliding pins)
Remove the cover from the Master Cylinder on the Handel bar.
Attach the C clamp to one of the pistons but don’t squeeze it. *Pump the lever on the bar slowly to push out the other piston almost all the way. *Put the C clamp on that piston and push out the other one.
Remove both pistons by hand.
Remove all the rubber part from the caliper, the seals are in the grooves in the caliper and dull pointed thingy will get them out easy.
Disconnect the caliper from the brake line.
Soak all the rubber parts in new clean brake fluid * ONLY!!!!! * Rub them with you fingers till as clean as new.
The caliper can be cleaned with a wire brush or even a Moto tool for the internal grooves, NOW’s the time to paint it if you wish.
Polish the pistons till they are smooth and shinny. They are chrome plated. If any of the plating is chipped or damaged below the dust cap groove. *Replace it.
The master cylinder is the subject of another write up and we’ll assume it in good working order here.
If you suspect your disc is bad, your bets bet is to replace it with an after market one fro EBC or Galpher.
*Don’t remove the disc unless you intend to replace it. *It will assume a new shape if it is * stressed and will not be flat again. You can try to check its condition by placing a straight edge across the face of the pad swept area looking for any distortion.
Re assembly
Take the nice clean rubber seals and install them into the caliper then the Dust covers.
Wet all the rubber with new clean brake fluid and partially fill the caliper with new fluid.
Push the pistons though the dust seals and into the caliper body until the dust covers snap into the grooves.
Fill the MC with new fluid and pump the lever while holding the Line above the MC till clean fluid flows.
Connect the line to the caliper while holding it above the MC.
Pump the lever with the bleeder valve open till fluid flow from the bleeder.
**Hold the caliper so that the bleeder is the highest point.
Close the bleeder and pump more fluid into the caliper but don’t push the pistons all the way out.
Then squeeze the pistons all the way back in and install the new pads.
Re grease the slider pins and assemble the dust seals and re mount the caliper on the forks but leave the bolts loose.
Now clamp the caliper to the disc with the brake lever.
Look at the space between the fork lugs and the caliper, clamp and release a few times as you tighten the bolts by hand. If one lug touches much before the other the odds are you mounting bracket is bent. You can straighten it.*
*After you get it the best you can. Some shim washers made from alum can stock can be fitted to the loose side.*
** *What we are doing here is trying to minimize the bedd in time and gets the best pad life.
Ok with everything tight you should be through, Notice we don’t need to bleed the brakes, but if you screwed up in any of the above steps, you might do that here.
Be careful to Bedd in the new pads gently.
**Too much pressure too soon will burn the pad material as only a small area will be gripping at first. You also won’t have full braking power till the pads are fully familiar with the disc
violente et ignorantia
ZX-2R BLOG
Old April 9th, 2015, 11:27 AM   #6
The sintered pads have a better initial bite and some additional increased stopping capabilities vs the stock pads. Depending on the rider, it make take some time to get used to the differences in feel. And since the rear is fairly easy enough to lock with the stock pads..... well you know.
Is it common?
Old April 9th, 2015, 03:14 PM   #7
cuong-nutz
cuong-nutz's Avatar
I get both sintered since I usually get decent deals buying as a set. Plus being the cheap bastard that I am, I just swap the rears to front and the fronts to rear. I usually advise riders to go organic in the rear since it takes more effort to get it to bite but at the loss of life span due to softer compounds. Why?
Riders who have not developed the muscle memory for emergency braking or proper braking techniques subconsciously mash or grab too much brake without even knowing, thus, making a preventable incident occur.
Replaced a NewGen front wheel? I need your bearing spacer! InvisiBill Items Wanted 10 February 20th, 2014 01:04 PM
Newgen Front Fender EMSRacer07 Items Wanted 1 August 27th, 2013 08:46 PM
WTB newgen front tubes MrSavvy Items Wanted 0 September 28th, 2012 06:37 AM
WTB: Newgen Front Wheel KChatham Items Wanted 1 June 3rd, 2012 05:44 AM
Largest front tire on a newgen? demp 2008 - 2012 Ninja 250R Tech Talk 18 August 20th, 2010 01:10 AM
