Old June 10th, 2016, 07:06 PM   #1
Bob2010
Bob2010's Avatar
What's the deal with the adjustable levers?
The stock lever feels great. Bought these from a member a year or two ago. Started to install the brake and it doesn't feel or function correctly.
First off. The lever itself has 2 bolts and both are right. The OEM bolt is tight
The lever at the furthest setting works but feels loose.
The closer I move it to the hand grip the worse it feels
Also the closer I move it to the grip it doesn't keep contact with the brake light switch. You can't hear click off unless you hold the lever at a certain angle
Are these junk or am I overlooking something ?
Didn't bother with the clutch lever yet
Thanks
2010 Red Ninja 250
2009 Black Ninja 250
Last futzed with by Bob2010; June 10th, 2016 at 07:35 PM. Reason: iPhone spelling
Old June 10th, 2016, 07:10 PM   #2
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Possibly the answer is if the stock feel great then something different won't!
I love my adjustable shorty' sand they let anyone else that rides my bikes adjust to suit their preferences. But; if you're happy with stock then don't change them! Sell them and get the farkles you really want! Like a track day!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old June 10th, 2016, 07:28 PM   #3
I have these same levers Bob. Not sure what is going on with your install but mine feel great for both street, track and race usages. Would you like further help with installing these or will you be reverting back to stock?
I can tell you for sure, the feel is 100% lighter and yes... it will seem loose. But the non functioning brake light switch and the lack of "click" sounds concerns me.
At this point I have witnessed 2 crashes due to faulty front brake lever installs. Do yourself a favor and take caution that everything is right before riding.
Let us know if you need anything.
Old June 10th, 2016, 07:38 PM   #4
Bob2010
Bob2010's Avatar
Interesting...
Took 2 minutes to swap out. I put the stock levers on until I can sit down and figure it out.
I know how it's supposed to feel as I have also used these before on another bike.
No way am I going to use these until I feel comfortable with them.
Also found my box of steel braided brake lines from that group buy a while back.
Guess I have some catching up to do
2010 Red Ninja 250
Old June 10th, 2016, 07:41 PM   #5
verboten1
verboten1's Avatar
MOTM - June '15
I have the cheap eBay levers (looks just like these as well) on all the bikes and haven't had any issues. Make sure it has full travel, make sure it hits the MC the right way....etc etc
Ride more, worry less.
Old June 10th, 2016, 07:52 PM   #6
Bob2010
Bob2010's Avatar
Well if you guys are sure these are not junk I will take a second look at it tomorrow.
Honestly I only spent about 15 minutes messing around with the brake lever. I brought the bikes out for the first time , changed the oil and found my levers in a part of my book bag I never check.
2010 Red Ninja 250
Old June 10th, 2016, 11:16 PM   #7
redsnapper
redsnapper's Avatar
Name: Red Snapper XXX
I had the same problem. I ended using the stock lever for front Brake.
It's a hit or miss when ordering from two wheels.
Friends with identical bikes, ordering from the same place, all seem to have them too tight, loose, or something funny.
redsnapper is offline   Reply With Quote
Old June 11th, 2016, 04:14 AM   #8
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
I've been using levers from Pazzo on almost all my bikes for years. They're not the cheap levers. I've NEVER had an issue with any of them. They have always fit and functioned perfectly.
http://www.pazzoracing.com/index.html
Old July 1st, 2016, 09:34 PM   #9
Did these get sorted out?
Old July 11th, 2016, 05:31 AM   #10
DaBlue1
DaBlue1's Avatar
Originally Posted by Bob2010 View Post
......The stock lever feels great. Bought these from a member a year or two ago. Started to install the brake and it doesn't feel or function correctly.
How are these working out for you now? A long while back there was a couple if incidences where the adjustables were shorter than the OEMS where they contacted switches.
https://www.ninjette.org/forums/show...9&postcount=55
https://www.ninjette.org/forums/show...385#post251385
Old July 20th, 2016, 09:23 PM   #11
Bob2010
Bob2010's Avatar
Nope. Haven't used them. I don't feel safe with them installed and I feel as if the previous owner here knew that and passed the buck to me.
I could re sell them IF someone thinks they can make them work.
So I guess I just have to suck it up and consider it a loss.
2010 Red Ninja 250
Old July 20th, 2016, 09:31 PM   #12
Bob2010
Bob2010's Avatar
I see the post 103/104 and hell I even posted in that thread too
Ill have to take a look at both OEM and aftermarket levers and do a comparison.
2010 Red Ninja 250
Old July 20th, 2016, 09:32 PM   #13
Bob2010
Bob2010's Avatar
Whoops
Tried to respond to you via quote and it posted without the quote. I screwed it up
2010 Red Ninja 250
Old September 8th, 2016, 05:24 PM   #14
Bob2010
Bob2010's Avatar
Update. As stated above - I have a junk lever. Why would someone here sell me these ? How can it work for one bike but not another ?
Looking at the ends of the levers, the OEM one has a longer "head" on it allowing full contact of the switch
The aftermarket one is shorter
Now both levers are not solid / tight. You can wiggle them up and down (probably so they don't bind up)
So the aftermarket one barely catches the switch at the tip of the "head". But as soon as the lever is wiggled it slips off leaving the brake light on
All I can do is keep the clutch lever - I thought about shimming the brake lever with a washer but it's too tight
Any ideas?
2010 Red Ninja 250
Old September 8th, 2016, 05:27 PM   #15
Bob2010
Bob2010's Avatar
Also I tried to tighten the tiny Allen bolts on the lever but the bottom nut is recessed so far into the lever you can't get anything on it ? Wtf
2010 Red Ninja 250
Old September 8th, 2016, 06:58 PM   #16
CrazyCanuckGoat
Motorcycle(s): 2003 ZX12R (sold), 2012 250R, 1975 Honda XL250, 1980 XJ650
My levers did the same thing on the brake switch. I just took my switch off and ground it down. I guess you could also sand where it mounts. No issues now for me.
That's the roll of the dice with Ebay/Chinese levers.
CrazyCanuckGoat is offline   Reply With Quote
Old September 8th, 2016, 07:25 PM   #17
Bob2010
Bob2010's Avatar
Hmm I guess I can play around see what I can do
Yea I know it's cheap and right now I don't want to buy another set - I just wanted to make this work. If I can't , well off to the trash they go
2010 Red Ninja 250
Old September 8th, 2016, 08:12 PM   #18
CrazyCanuckGoat
If you take your brake switch off, the plastic should be raised slightly (ridge) around the screw holes. You can just sand those off.....that might be all you need.
I prefer short levers on my bike, so that is the route I went.
Old September 8th, 2016, 08:21 PM   #19
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
I love my shorties! Everything I own has them.
Goin' fast on slow bikes!
Old September 8th, 2016, 08:57 PM   #20
Bob2010
Bob2010's Avatar
Hey thanks for the suggestion. Hopefully soon I can start saying that I like them too
2010 Red Ninja 250
Old September 8th, 2016, 09:49 PM   #21
Hasersys
Hasersys's Avatar
Motorcycle(s): Have owned Ninja250,EX500,Xj650,RD250,XV750
I've had some similar to these and they worked fine after some moding. After taking a hair more material off they are good now. I like them alot, but I have noticed a big difference in tolerances between like levers on some of my other bikes. I had two sets of like adjustable levers on my xj and found one was more of a loose fit while the other was tight, and I would assume the same could be said about this style also. I do not think where ever they are made has a stict quality control.
Hasersys is offline   Reply With Quote
Old September 9th, 2016, 10:27 AM   #22
Bob2010
Bob2010's Avatar
So sanding down the brake switch didn't help. I had to file down the actual contact points on the brake assembly where the switch rests on it.
So far so good. Maybe I'll toss those braided brake lines on that I have from a group buy from like 3 years ago lmao
2010 Red Ninja 250
Old September 9th, 2016, 01:07 PM   #23
Hasersys
Hasersys's Avatar
I took off material on the lever side, also check to see if the lever is pushing in the mc at all while it is not being pulled in. I had an issue with mine pushing the mc in just enough to not notice until the pads heated up the caliper enough to expand the fluid. Go out and ride, and check the lever now and then being sure it is n t getting to tight.
Old September 9th, 2016, 02:21 PM   #24
Bob2010
Bob2010's Avatar
Yeah I checked it out. The MC side seems correct. The part that touches the light switch was the only issue
2010 Red Ninja 250
Old September 9th, 2016, 04:07 PM   #25
CrazyCanuckGoat
IIRC, I may have also ground the part where the switch screws to as well.....it's been a while. At least it is functioning correctly at the moment.
Old September 10th, 2016, 08:16 AM   #26
Bob2010
Bob2010's Avatar
After a test ride - my foot was killing me. Unless it's unrelated but shifting requires a lot more effort. It's almost impossible to up shift
I tested the clutch adjustment in first gear front brake on. Tested the friction zone. Pull the clutch in about halfway and I'm free.
Test riding though- for whatever reason , it's really hard to shift.
I'm going to try to lube the cable and the shifter see what thst does. I wonder how that can help if when I pull in the clutch I'm already out if the "friction zone"
2010 Red Ninja 250
Old September 12th, 2016, 09:15 AM   #27
Bob2010
Bob2010's Avatar
Fixed it , again. The new shifter decided to act up same day I did the levers. The bolt needed to be removed , cleaned and greased. All is good.
2010 Red Ninja 250
Old September 20th, 2016, 03:51 PM   #28
Mbene
Motorcycle(s): Triumph Daytona 675
thats strange, I have adjustbles on my ninja and my triumph and I haven't come across and issue like this. I am sorry
Mbene is offline   Reply With Quote
Old September 20th, 2016, 08:12 PM   #29
Bob2010
Bob2010's Avatar
Don't be / just luck of the draw I guess
Hell who would have thought my shifter would have gummed up right after the install haha
2010 Red Ninja 250
Adjustable Levers Tyler9904 1986 - 2007 Ninja 250R Tech Talk 4 September 24th, 2015 03:51 AM
Adjustable Levers wardie 2008 - 2012 Ninja 250R Farkles 3 July 4th, 2015 05:33 PM
$42 adjustable levers spooph Motorcycle-related 15 January 11th, 2011 09:57 AM
What adjustable OEM adjustable levers fit? ChaosFromAbove 2008 - 2012 Ninja 250R Tech Talk 6 July 29th, 2010 11:49 AM
Adjustable levers for 86'-07' models jpnfrk 1986 - 2007 Ninja 250R Farkles 3 March 31st, 2009 02:11 PM
