November 3rd, 2012, 07:59 PM | #1 |
InfoWhore
Join Date: Oct 2012 Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC Posts: 628
replacing oil in forks help
Ok so i am wanting to replace the oil in my forks. I dont want to take the forks down, so im going to drain it and add oil from the top.
my 2 questions are: 1. Do i need a new seal or can i go without it? 2. were is the drain plug on the forks? Id appreciate an answer with "no i don't need to replace seals" lol But if you absolutely do then let me know haha
Everyone, go buy a dirtbike hurry |
November 6th, 2012, 04:20 PM | #2 |
Maybe this will help? http://www.ninjette.org/forums/showthread.php?t=23200
November 6th, 2012, 04:29 PM | #3 |
InfoWhore
ya i saw that but i didnt really help in anyway lol. He drains it by taking the whole fork out, im wondering if there is a drain plug where you can keep the forks attached. And no help with the seal questions either.
BUT THANKS!
November 6th, 2012, 04:31 PM | #4 | |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
You can drain from the bottom by removing the screw that holds the damper rod in place. If the damper rod shifts while the screw is out, it can be a pain in the ass to put back together. Either way the front wheel has to come off. Edit: no you don't have to remove the seals to change the oil.
CVMA #55 |
November 6th, 2012, 04:59 PM | #5 |
InfoWhore
Are you sure? i saw this video: http://www.youtube.com/watch?v=38yXx64liCM
i know its not a ninja but does the ninja have the same kind of plug? where it can be still attached to the wheel
November 6th, 2012, 05:33 PM | #6 |
the damper screw dean is talking about is on the bottom of the fork but if i remember right the axle has to come out in order to gain access to the drain.
if its nasty old oil you probably want to do a full drain. if its new oil (changing thickness or something) you can probably get away with pumping it out from the top
November 6th, 2012, 06:41 PM | #7 |
InfoWhore
Hmmm ok well then i probably will be taking the front forks off after all, i don't know why im so OCD with maintenance, but im doing like every little thing lol
Getting around to replacing my forks this weekend. What should I know? Tips? | Insane Pie | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 17th, 2014 12:48 AM |
Replacing Forks | TheOneCleanHippy | 1986 - 2007 Ninja 250R Tech Talk | 6 | August 11th, 2013 06:51 PM |
Changing Oil Without Replacing Filter | dustytoasters | 1986 - 2007 Ninja 250R Tech Talk | 5 | August 5th, 2013 09:20 AM |
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and | Ninjette Newsbot | Motorcycling News | 0 | October 26th, 2008 05:10 PM |
