Old April 4th, 2014, 12:33 AM   #1
possession
Motorcycle(s): ninja 250
ninja 250 won't run video included
please help me out. It's my first bike. it ran fine when I bought it a couple weeks ago. I just bought a brand new battery but that did not solve the problem. last time it ran i released the clutch to start riding and then it died. ever since then the bike has not started.
possession is offline   Reply With Quote
Old April 4th, 2014, 01:20 AM   #2
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
sounds like it might be the starter
try to push start the bike and get back to us, if it works then it's the starter and if it doesn't then the problem needs further diagnosis. I'd also check the spark plugs.
Old April 4th, 2014, 03:16 AM   #3
NinjaZX6R123
Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R
I agree. It's probably the spark plugs or starter. I'm leaning more towards spark plugs. Get the NGK Iridium and replace the plugs.
NinjaZX6R123 is offline   Reply With Quote
Old April 4th, 2014, 06:21 AM   #4
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Oh god that sound is killing my soul
It doesn't sound like your piston is moving any air through you exhaust, you know that slight thumping sound before a bike cores up. Your starter motor seems to be spinning but it sounds like solenoid that fires the gear for engament is not firing or your gears are striped. Or maybe your audio is just crap.
Try this
Put your hand over the exhaust outlet and try starting the bike, you should feel puffs of air. If you don't your starter isn't turning your motor.
Old April 4th, 2014, 06:51 AM   #5
kennetht
kennetht's Avatar
i was just thinking the same thing when i watched the video. when he tried for a second time to start it i was like, noooooooooooo
kennetht is offline   Reply With Quote
Old April 4th, 2014, 07:10 AM   #6
Vad18
Vad18's Avatar
Motorcycle(s): 2012 Ninja 250
Sounds like a similar problem to my jetski.
Definitely not the battery because gauges light up, and when you want to start it is "spinning" the starter.
I don't know if all is the same with my jetski, but had a starter solenoid on my jetski and that went out. So power goes from battery, to starter solenoid, to starter, and that's "cranks" your engine. Just something you could check out if all the other possible problems don't seem to work.
Vad18 is offline   Reply With Quote
Old April 4th, 2014, 07:17 AM   #7
Sounds like somebody needs a starter clutch/chain. A 2nd/3rd gear push start will tell the tale.
Old April 5th, 2014, 09:25 AM   #8
What's the werd? Will the bike push start?
Old April 5th, 2014, 09:28 AM   #9
i listened to the video. one of two things happened; either the bike is making literally no compression, maybe no spark plugs. but it seems too fast for that. more likely, the starter paw gear that slides forward and back had cracked or is stuck slid out and is not engaging the starter so the starter is just spinning and spinning. should be able to tell by push starting it like chris said
Old April 5th, 2014, 09:36 AM   #10
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
open oil fill cover and watch the clutch basket when you hit the starter, if it turns - no compression, if it does not - starter is fubar.
Old April 5th, 2014, 09:30 PM   #11
risingsun
risingsun's Avatar
Motorcycle(s): 09 GSXR600 and 08 Ninja 250R
starter is not engaging at all. I have a similar problem but it is due to a bad battery, when I throw it on the charger it works fine. I would try that if it only starts after a full charge I would check the plugs next.
Last futzed with by risingsun; April 8th, 2014 at 05:55 AM.
risingsun is offline   Reply With Quote
Old April 8th, 2014, 07:52 PM   #12
possession
Im taking it to the shop tmmrw we shall see
Old April 9th, 2014, 09:03 AM   #13
cuong-nutz
cuong-nutz's Avatar
Starter gear is not engaging.
$75 diagnosing fee. I take, cash, check, money order, paypal, cashier's check.
https://www.ninjette.org/forums/showthread.php?t=126333
HalfFast Racing Team
Old April 9th, 2014, 09:06 AM   #14
So... up for grabs is $75
Jason beat us booth (although worded in a strange way)
I was second on this, naming it explicitly
Comes now, Elan
Cuong is 3rd in line and included supporting link
Old April 9th, 2014, 09:13 AM   #15
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Comes now, Elan
Well if I just tell someone the answer strait up they end up wondering why it is so or how I know. So I normally just answer with the reason instead of the answer, alas that still confuses people
You can go ahead and sent the $75 via paypal or a rear IRC 300 tire in great condition.
Old April 13th, 2014, 05:07 PM   #16
possession
its the starting gear. Its gonna cost me 567$... plus something else they said was wrong with the petcock so that will be fixed as well. oh well. Thanks though guys.
Old April 14th, 2014, 06:04 AM   #17
Dang! Dealer not cutting you any slack I see.
Old April 14th, 2014, 06:50 AM   #18
cuong-nutz
cuong-nutz's Avatar
Ouch. Best of luck to you and I hope they do an awesome job!
2009 Ninja 250 won't run Matto55 2008 - 2012 Ninja 250R Tech Talk 6 October 3rd, 2014 03:05 PM
2007 ninja won't run? what to do. Racer x 1986 - 2007 Ninja 250R Tech Talk 4 December 23rd, 2013 12:26 PM
2010 Ninja 250 motor FREE SHIPPING included PartsNinja Motorcycle-related 2 November 27th, 2013 03:21 PM
250 Won't Run for @$%T badblown572 2008 - 2012 Ninja 250R Tech Talk 12 May 9th, 2012 03:38 PM
Mini Fest (Ninja 250 included) in Texas - June 13th/14th Broom Ninjettes At Speed 1 June 5th, 2009 05:50 PM
