Old October 22nd, 2014, 08:51 AM   #1
Justanothermp5
Justanothermp5's Avatar
09 Diaphram issue, pics inside. HELP
So I upgraded to a 2011 zx6r 2 years ago, and dropped my 09 Ninja 250r off with my parents. Long story short, they didnt keep it started on a regular basis so I ended up having to tow it back to my place and tear it apart to clean out the carbs. Now, while cleaning the carbs, I found that when I did the needle shim mod a long time ago (like a noob) I didnt seat the diaphragm properly before tightening the screws. Heres what it looks like.
Now Ive done some research on what to use to fix the small tear, but my question is, do I need to spend $144 for a new diaphragm or is there some way to fix the deformity? IE: soak it in hot water, heat gun, something like that.
Any help would be awesome, THANKS!
Woodcraft~Area P~Zero Gravity~Dynojet~DDM
Custom Paint by- ME
Justanothermp5 is offline   Reply With Quote
Old October 22nd, 2014, 09:34 AM   #2
There is no fixing that with any sort of real reliability, ebay used set of carbs $50-$100
Sorry brah
Old October 22nd, 2014, 09:41 AM   #3
Dude - it's not their fault! They did you a favor. You don't want to start an engine and run it for a short time to "warm it up".
If it's going to sit you need to add a fuel stabilizer and fill the tank - then drain the floatbowls. Changing the oil, and running for a very short time, before extended storage gives the engine the best protection from corrosion.
As far as the diaphragms go, they are expensive new. As Chris noted, most people get a complete set of used carbs instead - but that's no guarantee the diaphragms will be good either.
Old October 22nd, 2014, 09:52 AM   #4
MrAtom
MOTM - July '15
Why are the diaphragms so expensive, anyway?
Old October 22nd, 2014, 03:59 PM   #5
Justanothermp5
Damit, thats not exactly what I wanted to hear lol I guess Ill check ebay and see what I can find, thanks guys.
And as to why they are so expensive? No clue, its made out of a special nitrile rubber, but I wouldnt assume they cost anywhere close to $140 to make. Just another way for people to make money
Custom Paint by- ME
Old October 22nd, 2014, 04:13 PM   #6
Flying
Motorcycle(s): 2010 Ninja 250
Supply and Demand! Kawasaki doesn't have much incentive to order parts that are supposed to last the lifetime of the bike.
Old October 22nd, 2014, 05:11 PM   #7
MrAtom
MOTM - July '15
Hmmm... How crazy is it to consider putting a more generic set of carbs on the engine for the sake of easier repair?
New Rider from Ceres, Ca!! Pics inside! Klint New Members 17 September 13th, 2013 05:30 PM
New to the forum, pics inside. TEGGSRB18C1 Pictures 15 May 16th, 2013 12:40 PM
[topix.net] - See what's inside this week's issue Ninjette Newsbot Motorcycling News 0 December 18th, 2012 10:20 AM
[topix.net] - See what's inside this week's issue Ninjette Newsbot Motorcycling News 0 January 3rd, 2012 10:20 AM
Are my tires okay? Pics inside.. seanski41 1986 - 2007 Ninja 250R Tech Talk 24 June 16th, 2011 09:00 AM
