April 19th, 2015, 03:31 PM | #1 |
Join Date: Apr 2015 Motorcycle(s): 2009 ninja 250r 2015 ninja 636 Posts: 4
Need help with new rear-set installation
Ok so i bought a used 2009 Ninja 250r for my wife it was sitting outside for about a year i cleaned out the carbs and the gas tank, finally got it running it needs rear sets... I order the rear sets CNC brand and it said it would fit the bike. well i tred to install them and I guess I have to try and modify something to make them work anyone have a how to install guide?????? would love to know how to do this.....
ANYONE KNOW HOW TO INSTALL THESE ON A 2009 NINJA 250R http://g02.a.alicdn.com/kf/HTB19TPwG...6bde4b7bc31887 http://www.aliexpress.com/item/KELI-...047302954.html the Rear Brake side piece cracked in half the owner said it was hit with a metal baseball bat does anyone know if it can be welded or anything in that since I dont think J.B WELD will hold it either?????? if not i have to find a way to install the new CNC Brand rearsets Last futzed with by lostinmymind; April 19th, 2015 at 05:13 PM. Reason: spaced out post |
April 19th, 2015, 03:34 PM | #2 |
Welcome Richard!
Can you take a pic please? I am not following what you have going on. JB weld on rearsets... naw man. lol And that says alot, I am from KY.
April 19th, 2015, 03:48 PM | #3 |
I can have pics up by Wednesday but i fixed my post the old rear set on the rear brake side got hit with a bat and cracked in half if i can just fix that i would save money and return the new product i bought before
April 19th, 2015, 03:57 PM | #4 |
sammich maker
MOTM - Apr '15
Welcome, is the piece cast? Good luck!
https://www.brocksperformance.com/VZ...0035+C450.aspx |
April 19th, 2015, 04:00 PM | #5 |
Im not sure i was thinking it was cast iron but the one that is split in half is factory so is there anything i can do with the old broken part
What Do I Need To Do? Installation Help | ilovejesus | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 7th, 2018 09:08 AM |
Rear shock set to high (rear wheel slipping)? | passive101 | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 10th, 2014 08:45 PM |
08+ rear wheel, right rear set, rear brake system, seat | cuong-nutz | Items Wanted | 2 | October 6th, 2013 05:37 PM |
front/rear sprocket installation info | jus4fun | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 26th, 2012 01:05 PM |
