July 13th, 2015, 07:49 PM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2011 250R Black Posts: 72
Rad Cap - Same as Honda Civic?
I took my rad to get cleaned out today, while at the rad shop I was asking about rad caps. I know we use a 1.1, so the guy said I could use a Honda Civic cap since its the same one. Size looks like it is the exact same.
Anyone know? Shop wanted $40 for the OEM or $10 at Canadian Tire for the civic, and much easier to find. |
July 14th, 2015, 08:21 AM | #2 | |
Fighting Texas Aggie '05
July 14th, 2015, 08:34 AM | #3 |
If you got the $$$ to try it out, then I see no problem as long as it holds a seal and vents as needed.
Try it and let us know if it works.
July 14th, 2015, 10:05 AM | #4 |
EX500 full of EX250 parts
Doesn't sound like the exact same part number, but we found that there are common, cheap automotive radiator caps and thermostats that fit the 500. http://www.ex-500.com/wiki/index.php...=Non-OEM_Parts There could definitely be similar options for the 250. Just make sure the specs are the same and you should be fine.
July 14th, 2015, 01:30 PM | #5 |
found this when looking into replacing my thermostat...
"The new gen and pre gens share the same cap. The stock 1.1 BAR / 16 PSI (SAE range 14-18 PSI) radiator cap # 49085-1066 can be replaced by; Stant's 10233 Prestone's RR-33 CARQUEST 33044 Gates 31336 Gates Canada 31336 NAPA 703-1406 Stant (Carded) 11233 Stant (Carded) 70233BL Stant (Carded) 70233RD CST 7516(@ AutoZone)" Link |
[hell for leather] - Honda NC700S: the Civic of motorcycles | Ninjette Newsbot | Motorcycling News | 0 | November 7th, 2011 05:50 PM |
Ninja250r Vs Honda civic type R | Brittas | General Motorcycling Discussion | 48 | September 7th, 2011 02:11 AM |
[topix.net] - Honda Civic a " Archived Road Test | Ninjette Newsbot | Motorcycling News | 0 | September 16th, 2010 04:21 AM |
[topix.net] - Honda Begins Mass Production of Civic Sedans in Indiana | Ninjette Newsbot | Motorcycling News | 0 | October 9th, 2008 12:57 PM |
[topix.net] - Honda Releases Civic Type S Fireblade Replica | Ninjette Newsbot | Motorcycling News | 0 | July 20th, 2008 10:16 PM |
