Old March 6th, 2018, 09:17 AM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
bike won't go past 55mph
09 ninja valve job done carb cleaned now bike won't go past 55mph any ideas what could be wrong
skip is offline   Reply With Quote
Old March 6th, 2018, 09:29 AM   #2
Well, with that information, all I can suggest is that either the valves are set wrong, or the carbs are not truly clean.
Old March 6th, 2018, 09:37 AM   #3
When 2 things are done at once it complicates the troubleshooting process.
Check that there isn't any blockage of the intake. Confirm that the slides rise and fall freely. Damaged or incorrectly installed diaphragms might do it as well.
Any chance the cam timing could be off? It is a bit more involved than the Pre Gen engine.
Here's a link with some photos and info - https://www.ninjette.org/forums/showthread.php?t=9924
Old March 6th, 2018, 09:49 AM   #4
skip
skip's Avatar
Carb cleaned 3xs
Old March 6th, 2018, 09:51 AM   #5
skip
skip's Avatar
Any chance the cam timing could be off? It is a bit more involved than the Pre Gen engine. Took filter out nothing blocking the slides sliding well diaphragms in good shape
Old March 6th, 2018, 09:52 AM   #6
skip
skip's Avatar
Any chance the cam timing could be off? It is a bit more involved than the Pre Gen engine. Syncd carbs as well
Old March 6th, 2018, 09:53 AM   #7
skip
skip's Avatar
Carb cleaned 3xs and sync
Old March 6th, 2018, 10:43 AM   #8
Forgive us, but we've seen multiple cases of someone cleaning the carbs several times, and still missing some small passage or some other hidden problem.
Old March 6th, 2018, 11:24 AM   #9
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Did you reinstall the air box? All carb boots properly installed and no air leaks?
Old March 6th, 2018, 11:28 AM   #10
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
vacuum lines? cam phasing correct?
"trying not to get old"
Old March 6th, 2018, 11:47 AM   #11
skip
skip's Avatar
Boots installed sir box installed no air leaks
Old March 6th, 2018, 12:04 PM   #12
And the rest of it?
Trying to help, but limited feedback isn't helping.
EDIT: I see you did add comments at the end of each of my sentences. Hard to follow when added in the quote box.
Last futzed with by jkv45; March 6th, 2018 at 03:12 PM.
Old March 6th, 2018, 02:10 PM   #13
Are both cylinders firing? What does it sound like? Capped at 55 mph means it is *way* down on power, approaching only 1 cylinder's worth.
Old March 6th, 2018, 03:08 PM   #14
Due to exponential increase in wind-resistance, it's not linear. Aero-drag increases to square-power of velocity. Going 55mph requires about 9bhp, less than 1-cylinder. Because going from 55 to 100mph would require:
[(100mph/55mph)^2]*9bhp = 29.8bhp (crank)
Or over 3x the power to go 1.8x faster. So it's actually down by -70% of peak-power.
Old March 6th, 2018, 03:13 PM   #15
skip
skip's Avatar
Not sure if both cylinders are firing
Old March 6th, 2018, 03:29 PM   #16
It's easy enough to (carefully) feel the exhaust pipes to find out.
Old March 6th, 2018, 04:20 PM   #17
Yep, or use an infrared pyrometer to measure amount of imbalance: https://www.amazon.com/dp/B013Z8NHCG
Pull the plugs and make sure you have strong white/blue spark on both. It's not uncommon to have wiring or coil issues that results in weak spark on one side or both.
When was last time you changed plugs? In good shape with correct gap?
Old March 6th, 2018, 04:21 PM   #18
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
First up is it American ? Or is it scared ? ������
Just kidding. Sounds like it’s running on one cylinder check both exhaust headers are hot where it connects to the engine, a few seconds after start up.
If OK, check carbs ar3 corr3ctly assembled & that the slides lift all the way.
Old March 6th, 2018, 04:51 PM   #19
skip
skip's Avatar
Plugs changed 2 months ago
Old March 6th, 2018, 04:52 PM   #20
skip
skip's Avatar
Also the exhaust sounds muffled
Old March 6th, 2018, 06:22 PM   #21
Cam timing.
Old March 6th, 2018, 07:26 PM   #22
teafour
Corner Chaser
teafour's Avatar
Motorcycle(s): 2006 GSXR1000, 1986 VFR750, 2004 Ninja 250
Make sure the gas line and petcock are flowing cleanly... I just had this situation where the bike had the screen break off in the tank and rusted crud had blocked flow going to the carbs.
teafour is offline   Reply With Quote
Old March 6th, 2018, 07:30 PM   #23
skip
skip's Avatar
Will drain tank and see
Old March 6th, 2018, 09:15 PM   #24
Z1R rider
Z1R rider's Avatar
Assuming it was running properly before stated work was done, I would start by double and triple checking if stated work was performed properly. Making sure any wiring unhooked is hooked up properly also.
Old March 6th, 2018, 11:03 PM   #25
skip
skip's Avatar
Bike was bogging backfiring then did valve job cleaned carbs now no bogging or backfiring just not going past 55mph at a complete loss
Old March 8th, 2018, 04:56 AM   #26
arnvc
Motorcycle(s): ex250
valves clearance not to spec? cam timing ?
maybe carb clean 4xs is require? winter blend gasoline caused me extra intermittent stumbles
arnvc is offline   Reply With Quote
Won't go past 4000 RPM - Help for a non-mechanic? CBeth88 2008 - 2012 Ninja 250R Tech Talk 21 October 21st, 2018 12:28 PM
Bike won’t rev past 4-5k rpm TrickyTriggs General Motorcycling Discussion 82 March 19th, 2018 06:24 AM
Bike won't Rev past 11k in 4th Dragger_2656 2008 - 2012 Ninja 250R Tech Talk 9 May 31st, 2015 08:30 AM
bike won't past 9k vmax 2008 - 2012 Ninja 250R Tech Talk 2 January 2nd, 2013 01:19 AM
Won't rev past 5k :( hoodadooda 2008 - 2012 Ninja 250R Tech Talk 7 December 24th, 2012 08:56 PM
