Old March 14th, 2021, 06:00 PM   #1
Based12
Motorcycle(s): 2010 Kawasaki Ninja 250R,
Hello from Spain!
Hi! I´m a newcomer to the two wheel world, I´m still waiting to take my final driving test (average waiting time for it here is around 3-4 months, it´s already been 3 so can´t be much longer!).
In the meantime, i bought some cheap bikes which need fixing, and between them there´s the 2010 Ninja 250R Fuel Injected, which is the one i´m planning to keep for quite a long time. The most mechanically inclined thing I had done was changing my car´s oil and filters by myself, and now I´ve been able to tear down a yamaha SR 250, change the brake line, carburate it, adjust the valves, etc etc etc.
So I´m pretty hyped about working on the ninja and fixing the issues I´ve found(FI light comes on at high RPM, codes 24 and 25,ticking noise at idle starting after 15 seconds and a slight oil leak on the head cover gasket).
TBH it´s definitely scarier seeing all those cables and stuff compared to the yamaha :S
Anyway, thank you all for being such a supportive community, see you around!
Based12 is offline   Reply With Quote
Old March 14th, 2021, 06:33 PM   #2
lizardywizard
green stig
lizardywizard's Avatar
Motorcycle(s): '15 Ninja 300 ABS (Hurricane)
MOTM - May '16
Based12! Glad you found us...
You treat her like a lady. And she'll always bring you home. --Admiral Leonard H. "Bones" McCoy
lizardywizard is offline   Reply With Quote
Old March 14th, 2021, 07:59 PM   #3
Hi Erik, welcome to the board! We'll help you with your project all we can, and good luck with your licensing test.
Old March 15th, 2021, 03:09 AM   #4
Based12
thanks!
Thank you guys! I´m going step by step, diving in the forum trying to find the info I need before making any post, it´s huge!
Also, I know it´s usually discouraged to buy a repair needing bike as a first, but having no license and having to unavoidably wait for my test, I´d much rather go through the process of learning to work on bikes myself and getting the accomplishment feeling of having fixed them than having a ready to ride bike and not being able to drive it cuz no license
Last futzed with by Based12; March 15th, 2021 at 03:12 AM. Reason: Adding info and not having to double post
Old March 15th, 2021, 08:13 AM   #5
Welcome and good luck!
Old March 15th, 2021, 02:21 PM   #6
Ceeloo Yello
Motorcycle(s): 250
Welcome
Old March 16th, 2021, 04:58 PM   #7
Snake
Snake's Avatar
Hello and welcome! Ola y bien venido!
Old April 11th, 2021, 12:49 PM   #8
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old June 13th, 2021, 05:10 PM   #9
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
hello from spain baqueiro New Members 10 November 3rd, 2018 02:06 PM
Greetings from Teruel...Spain chaus-11 New Members 14 June 13th, 2016 09:19 PM
Greetings from Spain! Christofini New Members 7 May 3rd, 2013 12:43 PM
[superbikeplanet.com] - Rain. Spain? Ninjette Newsbot Motorcycling News 0 April 26th, 2012 09:20 AM
Hello from Spain! gdelasheras New Members 18 July 27th, 2009 01:55 PM
