Old May 26th, 2021, 06:45 PM   #1
billiboi
Motorcycle(s): 2004 Kawasaki Ninja 250R
Coming in from Provo, UT
Hey guys! Just got a 2004 Ninja 250 and am loving it! I'm curious to know what maintenance I can do on it myself and what I need to take to a mechanic/specialist. Bike is ~ 14K miles and still rides well (so far as I know). Additionally, the frame was cut by the previous owner to install the cowl that it has now. Any suggestions on installing a flat seat so I can take 2?
billiboi is offline   Reply With Quote
Old May 26th, 2021, 07:03 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
billiboi! Glad to have you aboard...
Goin' fast on slow bikes!
Old May 27th, 2021, 09:13 AM   #3
Welcome!
Old May 27th, 2021, 12:15 PM   #4
Ceeloo Yello
Motorcycle(s): 250
Welcome, that looks like the now discontinued blue collar bobber kit.
Old May 27th, 2021, 02:02 PM   #5
You can do all maintenance yourself if you want to, and if you don't mind reading the shop manual. If the valves haven't been adjusted at the specified intervals, or if you don't know the history of the valve adjustments, it's definitely time to check them and adjust if needed. Information about it is at this how-to, under "engine" https://faq.ninja250.org/wiki/Ninja250_Howto
Sorry, I can't help with your seat question.
Old May 28th, 2021, 11:57 AM   #6
Ceeloo Yello
Motorcycle(s): 250
Since most of that kit is bolted on, I would think you would have to lose the rear cowl and then mount a new tail light under your new flat seat.
Old June 13th, 2021, 02:14 PM   #7
Snake
Snake's Avatar
Hello and welcome!
Old June 13th, 2021, 05:10 PM   #8
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Old June 14th, 2021, 04:01 PM   #9
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
[roadracingworld.com] - MotoGP: Michelin Describes Motorland Aragon As "Thought-Provo Ninjette Newsbot Motorcycling News 0 September 20th, 2016 09:50 AM
New User from Provo Utah jeremystallard New Members 8 September 13th, 2015 11:13 AM
New Rider from PROVO, UT cmbeebe New Members 15 April 28th, 2014 06:15 AM
[superbikeplanet.com] - The British Are Coming. THE BRITISH ARE COMING! Ninjette Newsbot Motorcycling News 0 October 16th, 2013 12:20 PM
Coming to the Maritimes lockie Group Rides and Local Events 3 June 23rd, 2009 07:04 PM
