Old June 26th, 2010, 11:19 PM   #321
omnivore
omnivore's Avatar
Motorcycle(s): CBR Fireblade, KTM 950SM, YZF750 (x2), R6, ZZR250, XR200, KTM 50SX Sr.Pro, Honda Spree
Signed up here solely to get in on this thread.
Today I bought my wife her 1st bike.
Its an 01 ZZr 250 (CDN model with alloy frame)
Will the Area-P exhaust fit on her bike? The stock mufflers are both marked up and she'd like to clean up the bike'sappearance. The weight loss would be a bonus. As for noise she'd like it quiet so the long muffler is in order.
KTM 950 SM,YZF 750 Street, CBR929 EnduranceBike,YZF 750 vintage racer, R6 racebike , SOAR #22
omnivore is offline   Reply With Quote
Old June 27th, 2010, 07:51 AM   #322
Snake
Snake's Avatar
I'm not sure if it will fit the ZZR250 but if you send Kerry Bryant an email he will promptly give you an answer.
http://www.ninjette.org/forums/sendm...ilmember&u=143
Good luck and welcome to the forum.
Old May 15th, 2011, 04:16 PM   #323
ms. bee
Motorcycle(s): 2006 Ninja 250r
full exhaust melting plastic
Hi,
I bought an '06 ninja 250 used. The previous owner installed the area p full exhaust system and used heat tape around the pipes. The pipes are close to the lower fairing and have started to melt it. Has anyone experienced this problem and have any recommendations for fixing it?
Pics are attached. #2 shows the inside of the lower fairing and how the pipe rests on it. #3 shows how the tubes were damaged when they came in contact with the pipe (this happened before I bought the bike)
I believe the fairing melting just happened yesterday when I was out riding for about an hour non-stop. The tube melting was there when I bought it (I didn't notice this until they delivered the bike after I bought it) so I think it may have happened before the heat tape was applied. Perhaps the heat tape is old and I should replace it along with the heat shield on the fairing? Or should the pipe not even be this close to the fairing?
Thanks!
Jessica
ms. bee is offline   Reply With Quote
Old May 15th, 2011, 05:16 PM   #324
kbryant
Area P
kbryant's Avatar
Jessica,
The system was not installed correctly and should not touch the fairing or hoses. It is very clearly noted in the installation instructions on how to adjust it and/or to check clearances before running. It should never be run and/or operated if touching any fairing parts or hoses. Simply loosen everything up and re-adjust it to gain the clearance needed. Same goes for the hoses you have pictured, simply move and/or secure them out-of-the-way.
Also, please note that we highly recommend that you do not use heat wrap tape on the system. These wraps retain both heat and mositure that will shorten the lifespan of the system by not allowing it to cool down and externally dry out properly. Stainless steel may become brittle over time with header wrap.
Old May 15th, 2011, 07:27 PM   #325
ms. bee
Thanks for the quick response. I'll grab a friend and see if I can adjust the position of the exhaust system. Is there a way I can get the instructions for the exhaust since they didn't come with the bike?
-Jessica
Originally Posted by kbryant View Post
Jessica,
Old May 15th, 2011, 07:39 PM   #326
kbryant
Area P
kbryant's Avatar
My pleasure Jessica. Send me a PM with your e-mail address.
Old July 8th, 2011, 02:27 PM   #327
Joseph L. Hudson
Motorcycle(s): 07 Ninja 250r
How do I get on the group buy for an Area P exhaust , jet kit , and battery box for a pre-08 Ninja 250? Joseph L.
Husdon
Joseph L. Hudson is offline   Reply With Quote
Old July 8th, 2011, 02:29 PM   #328
Hi Joseph,
go to this thread...
http://www.ninjette.org/forums/showthread.php?t=71794
Old July 20th, 2011, 09:13 AM   #329
bob138
Motorcycle(s): 1991 EX500 , 2009 250r
Sorry if I missed this info somewhere else but;
How much of a drop in MPG have people seen with the Area-P system?
Can it be installed without re-jetting?
In the planning stages of a high MPG bike and 17lbs worth of weight drop is alluring.
Thanks
Bob
My EX500 Build
My 09 250R Build
bob138 is offline   Reply With Quote
Old July 20th, 2011, 09:32 AM   #330
Bosgarage57
Bosgarage57's Avatar
Motorcycle(s): 06 Buell Uly, 05 VStar 1100
Thanks
Bob
Hey bob, I'm not sure about the mpg drop, but thats what I was thinking as well, if its going to increase fuel consumption then the 17lbs weight reduction should couteract that. I went ahead and ordered an exhaust when the group buy was going on. Hopefully It wont drop much, maybe 2-3 mpg. I'm averaging 65 right now and hate to see that drop.
Bosgarage57 is offline   Reply With Quote
Old July 20th, 2011, 01:25 PM   #331
greg737
Motorcycle(s): -
I thought it was more than a 17 pound weight loss.
The stock exhaust is really heavy so you save some there when you replace it with the Area P. Then you have to remove the center stand which weighs a pretty good bit. I didn't bother to weigh the old exhaust + center stand against the new Area P when I installed it but I'm thinking the total is much more than 17 pounds.
Is your 17 pound weight savings only taking the exhaust swap into account?
Old July 20th, 2011, 11:59 PM   #332
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Stock exhaust weighs about 19lbs. Center stand weighs 3 or 4 lbs in my estimation.
Old September 15th, 2012, 10:29 PM   #333
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
soooo after a few hours of searching. this purespeed died it sounds like. to buy or not to buy this "non muzzy" 2 to 1 exhuast for pregen?
http://areapnolimits.com/products/Sl...Ninja-1988.php
muzzy or area peepee? hmm.. i hav 3 days to decide
The King
rabies is offline   Reply With Quote
Old September 16th, 2012, 12:56 AM   #334
Monkeytofu
I told you bro
Monkeytofu's Avatar
*This system is currently discontinued*
Your only choice is a new/used muzzy or a used area p, which I haven't seen anywhere online.
Old September 16th, 2012, 04:04 AM   #335
tapdiggy
Humble Observer
tapdiggy's Avatar
Motorcycle(s): 2009 Yamaha XT250
I have a used pregen area p full system for sale
Everything I post is "IN MY HONEST OPINION".
Why is "Parking Lot Enduro" not a thing?
tapdiggy is offline   Reply With Quote
Old September 18th, 2012, 07:40 PM   #336
iplante
I ride like a granny
iplante's Avatar
Motorcycle(s): 2003 Ninja 250R - EX250F
how much?
iplante is offline   Reply With Quote
Old September 19th, 2012, 06:01 AM   #337
rabies
rabies's Avatar
Originally Posted by iplante View Post
how much?
too late sirdude i already bought his
The King
Official 2013 Ninja 300 (and 250) Thread 2009zx6rider 2013 - 2017 Ninja 300 General Discussion 1795 January 2nd, 2013 01:07 AM
WTB: Pre-Gen Area P Exhaust Magz Items Wanted 0 October 17th, 2011 03:01 PM
*New* Yoshimura GP270SSC Full Exhaust for Pre-Gen Ninja 250 Neema12 Motorcycle-related 6 July 23rd, 2009 09:44 AM
WTB: Stock exhaust (chrome preferred) pre-08 Ninja 250 Grn99Kawi Items Wanted 1 June 1st, 2009 01:05 PM
Pre 08, First Gen Owners- How would you like a FREE Area P exhaust???? kkim General Motorcycling Discussion 15 February 18th, 2009 08:52 PM
