Old April 11th, 2012, 07:28 AM   #81
WOOOOOOOOOOOOOOOOOOO!!!!! !!!
get out and ride it. get it warm, ride it hard for a solid half hour or so after it's warmed up. The whole not liking the gas and having to fight it with choke thing sounds just like mine after starting it the first time out of storage. It's just a little cranky. For me, that always goes away after the first day riding
with a completely stock intake/exhaust, you should be just fine with 2 washers on the needles. That's what I was running with stock intake/two brothers slip-ons with silencers for the longest time (same diameter outlet as the stock can). Ran great!
take it for a ride and see how it goes!!!
after you know how it rides and runs, some carb tuning might be in order, but that will be easy compared to what you've done so far
Old April 11th, 2012, 07:40 AM   #82
greg737
Motorcycle(s): -
Yes, he's right, there is the possibility that an "Italian tune-up" might help the carbs to work out their issues. Worth a try if the bike is rideable.
Old April 11th, 2012, 07:47 AM   #83
Originally Posted by greg737 View Post
"Italian tune-up"
Old April 11th, 2012, 07:49 AM   #84
azwillnj
I will try to ride it around today.. I have my motorcycle saftey course today, tomorrow, sat and sun so not much time to mess with it till Friday.
I'll take it out sometime this week and give her hell haha.
I have aftermarket single exhaust.. I wish I had the stock system. Should I leave the shims?
Alex.
azwillnj is offline   Reply With Quote
Old April 11th, 2012, 07:51 AM   #85
Yeah leave the shims. Congrats on the 2-1 system btw. I just bought one. Can't wait to get it installed and running.
...in a month when I get done at school
Old April 11th, 2012, 08:45 AM   #86
azwillnj
How much do you want for your stock exhaust and center stand?
Old April 11th, 2012, 01:00 PM   #87
Well, the stock exhaust was sold a while ago to a friend who had a fixer-upper, and the centerstand is not going up for sale. I'm keeping that for servicing the bike.
Are you just not a fan of the 2-1 or is it in rough shape?
Old April 12th, 2012, 07:32 AM   #88
azwillnj
Spoke too soon, tried to ride it yesterday and it was too temperamental to get moving. The way it moves past 4000rpm it was too dangerous to try to ride it. As a beginner rider, with 0 miles accumulated I was scared to floor it and play with the choke in first gear, I didn't want to pop the front wheel up.. I have to make it more reliable before trying to ride it.
Old April 12th, 2012, 08:03 AM   #89
that is a good and cautious idea.
Will it idle at like 3k? What is the absolute lowest you can get it to idle at? Once you have it idling at 4k with choke, try lowering the choke a little bit at a time until it's idling at 2500-3000 and let it idle until it accepts some throttle.
It might get better as it warms up. The other option is to find someone you trust to ride it around the neighborhood as long as possible.
I guess I would make a great Italian mechanic
Old April 12th, 2012, 08:18 AM   #90
n4mwd
n4mwd's Avatar
Based on this and your previous posts, its time to take the bike to a qualified mechanic.
My Ninja Blog
Old April 12th, 2012, 08:31 AM   #91
azwillnj
I will not give up.
Old April 12th, 2012, 08:39 AM   #92
n4mwd
n4mwd's Avatar
I will not give up.
When you wired out the carb passages, did you get much gunk out?
My Ninja Blog
Old April 12th, 2012, 08:42 AM   #93
azwillnj
Won't have time to wire it out till Friday afternoon, but I'm telling you, nothing is in there.
Old April 12th, 2012, 08:51 AM   #94
greg737
Motorcycle(s): -
Well, maybe so, but I can tell you there are several of us that have been patiently (or not so patiently) waiting for you to finally get around to doing this.
Please be thorough about it: http://faq.ninja250.org/wiki/Cleaning_the_carbs_1 and http://faq.ninja250.org/wiki/Cleaning_the_carbs_2.
As I've said before in a post about your problem, the way it runs suggests that one or both of the carbs are missing the usefulness of a particular passageway (blocked or partially blocked) and that's why it will only run in certain parts of its operating envelope, idle or really high RPM, and is the reason that you have to pull that weird "work-around" method of full throttle and varying the choke to get from idle to high RPMs.
Old April 12th, 2012, 10:18 AM   #95
azwillnj
Just to be clear, get some copper wire, any copper wire will do, and then just shove it into every hole on the thing and move it around right?
Old April 12th, 2012, 10:20 AM   #96
I've never been a fan of shoving anything metal into my carbs, but yes that appears to be the instructions they give.
Blast every passage with compressed air after you do the wire method
Old April 12th, 2012, 10:24 AM   #97
azwillnj
What is the forum favorite carb cleaner?
Old April 12th, 2012, 10:43 AM   #98
Sea Foam
Old April 12th, 2012, 10:44 AM   #99
azwillnj
Sea Foam
That comes in a spray can?
Old April 12th, 2012, 10:45 AM   #100
it sounds like your pilot system is jacked dude.
Old April 12th, 2012, 10:46 AM   #101
I believe it can be found in a spray can...?
Old April 12th, 2012, 10:51 AM   #102
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
yes.
http://www.seafoamsales.com/sea-foam-spray.html
Old April 12th, 2012, 12:24 PM   #103
greg737
Motorcycle(s): -
Follow the cleaning FAQ tutorials I linked to in my last post, they will guide you through everything: what to use, how to do it all and they will make sure you don't miss a single item.
and there's nothing to be concerned about with the copper wire. pure copper is much softer than the aluminum alloy and brass that the carb parts are made out of, so there's no way the copper wire can scratch/damage them.
Old April 12th, 2012, 12:51 PM   #104
n4mwd
n4mwd's Avatar
Remember to also remove the diaphragms and put them a safe distance away. The cleaning fluids will mess them up.
Use a copper wire that is smaller than the hole and will move freely. You don't want to break it off in there. If you have a really bad blockage, you can switch to steel wire like mig wire or fishing leader wire. Piano wire is a bit too much. Once you have it clear, use some kind of carb cleaning spray with a tube on it. Seafoam spray is good if it has the tube. The purpose is to wash out any particles that are left inside due to the wiring process and to make sure the cleaner is coming out the hole on the other end.
Once its all back together, you still need to adjust the mixture and sync the carbs.
For the record, I have seen numerous carbs that were all shiny and clean on both the inside and outside that had passages stopped up to where they didn't work right. Soaking the carbs in "part cleaner dip" does not clean the passages.
My Ninja Blog
Old April 13th, 2012, 07:32 PM   #105
azwillnj
Just wired out the carbs, every.. single.. last.. passageway, sprayed about a half a can of carb cleaner and compressed air through everything.................. and..................... drum roll...................... IT DOES THE SAME THING!!!
ITS NOT THE CARBS!! Can we put this to bed please, I'm tired of the broken record, I am not taking them apart again, it HAS to be something else.
Now, does anyone have any other suggestions?
Old April 13th, 2012, 08:12 PM   #106
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Old April 13th, 2012, 08:48 PM   #107
greg737
Motorcycle(s): -
I'm speechless.
Old April 14th, 2012, 05:14 AM   #108
n4mwd
n4mwd's Avatar
Based on your description of the symptoms, its a fuel delivery problem. Since you seem unwilling to accept that, its time to take it to the dealer or other qualified mechanic and let them fix the carbs for you.
Its possible that when you adjusted the float levels that you adjusted them incorrectly causing the bike to be starved for fuel. Also, you might not have the carb mixture and sync right either. Did you adjust the mixture and sync the carbs yet?
Anyhow, the mechanic will take care of all that for you.
My Ninja Blog
Old April 14th, 2012, 05:20 AM   #109
TnNinjaGirl
Ms. Personality
Fwiw I have had a carb before that was damaged. The entire body was warped. It never really ran right. Maybe the entire carb is jacked?
Posted via Mobile Device
Old April 14th, 2012, 07:06 AM   #110
n4mwd
n4mwd's Avatar
I was concerned about the ultrasonic cleaning for 4 hours that he did. Ultrasonic cleaning and aluminum alloys don't always get along. I'm not sure if that damaged it, but its not something I would have done.
He can always buy a new carb off ebay or get an ecotrons kit. He's supposed to come out with a new throttle body the first week in May.
My Ninja Blog
Old April 14th, 2012, 07:47 AM   #111
Let's assume your carbs are in perfect working order and valves adjusted properly.
Now lets get back to basics and a bit of red-neck tech.
Air + Fuel + Spark
Let's start with air
1. Open the air box - nothing in there right? red-neck tip* Throw an old t-shirt in there and try to start it. (less air) Next, try taking the air filter off completely and empty air box (much more air)
2. Check every vacuum line/carb boots visually for any cracks, holes and generally a good seal. red-neck tip* My guess you already have a can of spray carb cleaner, if not get one. The mist the areas of the vacuum lines with the bike idling. If the engine picks up rpm you got a leak.
3. Inspect exhaust - not clogged up anywhere is it?
Fuel
1. Pull some gas out and try it in a lawn mower, if the mower will run so will the bike
2. Check petcock and fuel to carbs. red-neck tip* Have a beer, then put empty beer can under petcock and pull hose. Move petcock control to all 3 positions to ensure they work as expected. Reconnect.
3. Take the same beer can and put it under each carb bowl and loosen drain screw to ensure float bowls are filling. At this point if the bike will run, then start it and run it for a bit. Try to rev it alittle too. If it dies STOP and check float bowls again. Empty? Fuel filter clogged? Full?
4. Now pull both plug wires and turn it over about 10 or so times and remove plug. Wet from gas = good, dry = bad (vacuum or valves)
Spark
1. Take spark plug out and connect to wire and wiggle it around where you can see it while standing up Turn bike on and turn it over a few times. See or hear a spark? What color is the end of the plug? Reconnect everything
2. You have a fresh battery from your earlier posts right? red-neck tip* Try to jumpstart from car (without the car running)
3. Check batter terminal connections and clean them if needed
4. Follow grounding wire all the way to termination. In good shape?
5. Get a manual if you don't already have one
6. red-neck tip* Pull every fuse that is not required for the bike to run and try again
All in all it should only take about an hour to do those tests and don't require you to take the carbs apart again.
Let us know how it goes and the best of luck to your sir.
Old April 14th, 2012, 10:04 AM   #112
EMSRacer07
EMSRacer07's Avatar
i think its a fuel problem. its possible its shimmed too much and its running rich. check ur plugs they black or white? hell if its really rich they might be wet and that wouldnt help either.
Old April 14th, 2012, 03:08 PM   #113
Hmmmm
I'm still of the opinion of if it starts and just has some issues with throttle, it might get better after ridden for a while because it's grouchy, but Chris has some good suggestions as well that sound do-able.
Old April 15th, 2012, 07:16 AM   #114
TnNinjaGirl
Ms. Personality
@csmith12 @Alex Sticky that wonderful informtation! Excellent tips for hard starting after winter and general no start troubleshooting!
Old April 15th, 2012, 07:45 AM   #115
I linked it from the Troubleshooting area of the wiki:
http://www.ninjette.org/wiki/My_Bike_Won%27t_Start
Old April 15th, 2012, 06:45 PM   #116
azwillnj
It appears you are unwilling to accept any problem other than the carbs, furthermore, the solvent was designed to be used on aluminium, and I think shoving wires into a specially sized hole is more of a risk than sound waves.
</flame>
This weekend I worked on it a little more with my Dad this time, thought a fresh pair of eyes were in order. I tried to go out and start it to see what would happen and it wouldn't start. Cranked it for a while and it started backfiring again. We clipped an inductive timing light onto the coils for the hell of it.. spark was not firing at all. We pulled the plugs and looked at them, they were damp with gas so the carbs are feeding fuel. We grounded the plugs to the engine and the spark was firing VERY intermittently with the majority of time, at least 80% with no spark on both sides with both the old and eBay CDI boxes. I switched the coils back to the stock coils that came on the bike and the same thing was happening with the new and old CDI. We took the tank off, put the plugs back in, drained the bowls, and sprayed ether directly into the carb intakes while varying the throttle opening and amount of ether and nothing happened... nothing. Lending more evidence to a problem with the spark.
He decided to go through the service manual and test every part of the electrical system with the tests outlined in the manual. Everything checked out ok but the spark pickup was at the very low end of the impedance range.
While the plugs were out we checked the compression again after the most recent valve adjustment this time cyl 1 was 190psi and cyl 2 was 195psi, so the valve adjustment fixed the issue and increased the compression quite a bit.
We pulled the side cover to expose the stator and pickup in preparation for the 'new' one from eBay that's expected this week. I'll come back and post after installing the new stator, pickup, and refilling the oil and coolant... cross your fingers everyone, haha.
Thanks for the checklist csmith12, if the new pickup doesnt work I'll give that list a try.
Thanks for all the help,
Alex.
Old April 15th, 2012, 07:18 PM   #117
Lol! If I would have known it was going to be linked to the wiki, I would have written it a lot differently. But it's cool and thanks.
Old April 17th, 2012, 12:15 PM   #118
azwillnj
Quick Update:
Sent the pickup and stator to the wrong address, I am picking it up this weekend so I'm going to try it Monday after work.
Yesterday I took the pickup off and moved it as close to the alternator as possible, put everything back together and I was getting a spark.. but still no ignition... even with ether.
What is the spark suppose to look like? Mine is kinda dull blue/purple and jumps around quite a bit. Could someone post a video of one of their plugs firing? That would be awesome.. I'll post one when I get home too.
Old April 17th, 2012, 09:12 PM   #119
kevlar250
kevlar250's Avatar
Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1
The spark needs to be able to jump at least 3/8" in free air or it won't be hot enough to jump under compression. It should be a blue/purple color not yellow/orange. I'll bet you could pull those carbs blindfolded at this point, but let's hope you never have to do it again!
kevlar250 is offline   Reply With Quote
Old April 25th, 2012, 07:10 AM   #120
azwillnj
I replaced the entire side cover with the one from eBay Monday, stator, pickup coil and cover.. The spark is much brighter and seems to be more regular, I wish I had taken before and after videos but I didn't even think about it. It's worth noting that the original side cover took the impact exactly where the pickup coil was mounted, so maybe it got out of alignment somehow.
But alas.. it still won't start...
I put the front wheels up on a ramp and leveled the carbs X and Y axis put some clear tubing on the drains and checked the fuel level in the bowls. They were exactly in spec 0.5mm above the seam (according to the service manual).
I have been thinking about it and I am going to mess with the mixing screws tonight as a last resort but after that doesn't work I'm not really sure what else to do.
I am really angry I caved and wired out the carbs, before I did that the bike would at least idle, now it wont even start... and before someone says it, yes, I followed the instructions EXACTLY, both 1 & 2 & the video someone posted earlier in this thread.
Also, before someone else says it again.. I don't want to take it to a mechanic that charges $85/hr that will do all the same things I have already done 3x and tell me he needs more time to figure it out. At this point it almost might be worth it to cut my losses, sell the bike as is and try to find one that runs rather than bringing it to a mechanic.
Thoroughly frustrated,
Alex.
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Bike won't start, cleaned carbs, new gas, backfires whats next? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 7 July 26th, 2013 09:53 PM
What acceleration? carbs cleaned MrSavvy 2008 - 2012 Ninja 250R Tech Talk 25 April 12th, 2013 01:47 AM
Gas leaking, carbs out, what to look for? CmichRider 1986 - 2007 Ninja 250R Tech Talk 7 August 12th, 2011 12:45 PM
HELP! Cleaned carbs, fixed ninja, now broken again!! synapsekiller17 2008 - 2012 Ninja 250R Tech Talk 19 November 18th, 2010 11:22 AM
