Old December 4th, 2013, 06:42 PM   #1
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded)
Handlebars wobble
So I noticed today coming back from getting my food on my lunch break, that after around 40mph, if I took my hands off the handlebars they would wobble. As soon as I put a light grip they would stop. Now, I know the simple response would be "Don't take your hands off the bars, duh."
Is this something I should be taking a look at when I get my bike back? My bike is being inspected about 16 miles away from home. And won't be ready until tomorrow.
Only thing I could come up with through google was tire pressure or tire wear (but both tires should have around 3k left). Anything else I should look into? Or is this normal? Like I said it doesn't happen below 40mph.
Sykes92 is offline   Reply With Quote
Old December 4th, 2013, 06:47 PM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I won't mention tapered bearings.
I don't think I've ever took both hands off... I ride one handed a lot though.
There is at least one thread around on the subject, somewhere.
Old December 4th, 2013, 07:02 PM   #3
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
More often than not it's from the "simple things" like tire pressure, but one maintenance item that will cause that is loose steering head bearings. My 250's been doing that for a little while now I just haven't gotten around to tightening it. Maybe I'll do a write-up on it seeing as it is relevant to all 250's.
Last futzed with by VeX; December 4th, 2013 at 07:10 PM. Reason: misspelling
VeX is offline   Reply With Quote
Old December 4th, 2013, 07:08 PM   #4
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Oh okay, well as long it wasn't anything too serious.
The bike I have was babied by the OG owner and well-taken care of by it's 2nd owner. But I still had a laundry list of stuff I wanted to do, regardless.
I'm hoping to:
- Clean the carbs
- Clean the airfilter/box
- Fresh Brake Pads
- Rejet (not sure if was done to account for aftermaket slip-on)
- Adjust valves
- Change oil & filter
- Change tires in the spring.
So if there was anything else, I figured I'd add it to the list. Ill write down to check the bearings too.
I usually keep both hands on there haha, I only did it out of curiosity.
Old December 4th, 2013, 07:19 PM   #5
JohnnyBravo
Now I'm curios ( why doesn't that look right? ) curious?
When checking out your bike always start with the simplest thing like saves ya time and money
I've heard tires out of balance, and something about the bar end weights as well... That's about the only 5 answers I can think of
Tire pressure
Tire wear
Tire balance
Bar weights
Head bearings
Old December 4th, 2013, 07:38 PM   #6
..........Or is this normal?.........
http://www.ninjette.org/wiki/Front_End_Wobbles
http://www.ninjette.org/forums/showthread.php?t=121404
Old December 4th, 2013, 09:12 PM   #7
old3
If you want to fix it, and your tire isn't cupped causing this wobble, read here;
http://www.ninjette.org/forums/showthread.php?t=119551
The stock steering bearings on these bikes are a joke. It seems a matter of pride to deny that in this forum for some reason. I don't get it.
Add "All Balls" steering bearing to your list IMO. My kids 2012 250 had steering bearing failure at around 800 miles as I recall. I fought to find my wobble for several hundred miles if not 1000.
Tightening them won't fix it. They are super cheapo and the races will probably be badly scarred if they were loose. There are pics at the Ninja 300 sight of bearings at 1000 miles with trashed races. They can't function correctly like that, no matter how tight you turn the collar.
Even at their best, they don't give good control and location of the steering stem. Inferior loose ball bearings as opposed to the proper caged balls or the tapered roller bearings. Garbage.
old3 is offline   Reply With Quote
Old December 4th, 2013, 09:25 PM   #8
JohnnyBravo
We really do have crappy head bearings
Old December 4th, 2013, 11:13 PM   #9
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Tire pressure
Tire wear
Tire balance
Bar weights
Head bearings
Oh alright wow, thanks for clearing that up for me guys . Ill add that to my list and also probably just keep my hands on my bars too haha. I was just curious of how the bike reacts. I used to ride without using my handlebars on my bicycle all the time (not that I would even dream of trying on a motorcycle) so just curious as to the physics lol.
Old December 5th, 2013, 06:00 AM   #10
JohnnyBravo
Old December 5th, 2013, 07:42 AM   #11
Oh alright wow, thanks for clearing that up for me guys ................I used to ride without using my handlebars on my bicycle all the time...........so just curious as to the physics lol.
You are welcome
The lesser mass of the front wheel-steering system of a bicycle makes it less likely to happen, but is still possible, like for any oscillating system (the steering system and the contact patch of the tire act like a pendulum).
It happens to airplanes too, a rapid oscillation being called flutter of the lifting and control surfaces.
These oscillations of the handlebars are the reaction to an off-center disturbance.
They can die out by themselves or they can grow stronger (resonance = tank slapper), depending on the natural frequency of the system.
If still interested, check these out:
https://en.wikipedia.org/wiki/Resonance
http://www.ninjette.org/forums/showt...t=tank+slapper
Old December 5th, 2013, 12:10 PM   #12
old3
Expanding on that previous post, if the steering bearings don't securely locate the stem, those oscillations are amplified. The "loose" balls don't cover the area equally, rather they randomly fall where they may around the race, and independently of what the top or bottom ones are doing.
It is as if they designed this bike to wobble. It is the perfect storm. Tiny fork tubes, poor bearing choice and a good amount of vehicle weight. Flex away!
Old December 5th, 2013, 02:10 PM   #13
That's what she said! Lol too easy!
Old December 5th, 2013, 05:22 PM   #14
JohnnyBravo
Old December 5th, 2013, 05:26 PM   #15
old3
Loose balls = a wobbly stem!
Old December 5th, 2013, 05:30 PM   #16
Old December 5th, 2013, 05:54 PM   #17
notsofast
Motorcycle(s): 2005 Ninja 250
I got sucked into this thread at work and lost about an hour. The breakroom is cold...
notsofast is offline   Reply With Quote
Old December 5th, 2013, 06:00 PM   #18
JohnnyBravo
it wasn't lost, was spent researching
Old December 5th, 2013, 06:05 PM   #19
JohnnyBravo
I don't want no wobbly stem, an mine hasn't wobbled yet thankfully!
Old December 5th, 2013, 06:26 PM   #20
old3
You have much stem stabilizing experience?
Old December 5th, 2013, 08:51 PM   #21
Very true !!!
I had a 150 cc motorcycle that was a nightmare regarding steering wobbling.
At times, I couldn't control the thing even with both hands on the handlebar.
I tried everything that I knew back then, all resulting in no improvement.
I finally found out that the balls of the steering bearings had made little craters on the tracks.
The weight of the bike made the balls try staying in those craters, fighting the normal steering adjusting oscillation.
It was funny to see how the whole steering tried to adopt those fixed positions when left alone (it looked like something magnetic), while the bike was on the center-stand with the front wheel in the air.
Once I replaced those bearings by new ones, the whole problem disappeared.
Handlebars Wobble when no hands :confused: Jason5885 2008 - 2012 Ninja 250R Tech Talk 8 November 6th, 2014 05:00 PM
wobble at different speeds wardie 2008 - 2012 Ninja 250R Tech Talk 3 September 14th, 2014 11:11 PM
Steering Wobble Around 50mph 255 2008 - 2012 Ninja 250R Tech Talk 10 May 21st, 2014 04:00 AM
rear wheel wobble focus101 1986 - 2007 Ninja 250R Tech Talk 9 July 11th, 2013 05:29 PM
[nytimes.com] - Wobble and Weave Ninjette Newsbot Motorcycling News 0 August 27th, 2010 12:40 AM
