Old June 4th, 2014, 04:01 AM   #1
jmk420
Motorcycle(s): Diavel Carbon / Ninja 250R / 696
Need help with Track build
I recently purchased a 696 for my girlfriend and I inherited her Ninja 250.
I searched a lot of threads and it seemed to be very messy and lots of choices.
The bike is a 2009, with under 10,000KM
I am a very big guy and planning to do a track build on the 250.
I have purchased a suit and gear ready for track but now it comes to building it for the track.
I have just ordered these parts :
HEL SS brake line (front)
EBC HH Brake Pads (front and back)
Woodcraft Clip On
Woodcraft rear set
Renthal Medium Grips
I have also bought dot 5.1 brake fluid and oil for getting all up and ready
Now I need help, since those were the easy stuff for me to purchase...
I am looking for what to do with suspension, I am a big guy and I weight 260, I don't know what to do with the suspension, should I just respring to my weight? Or buy either ohlins / penkse or something else?
Also will respringing the front needed or what is needed for me to get it ready?
Anything else I need that anyone would suggest to start off tracking?
Thanks!
PS: for tires I was reccomended Super Corsa SC2 anyone got any other suggestions?
jmk420 is offline   Reply With Quote
Old June 4th, 2014, 05:50 AM   #2
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Options include - front - springs/emulators/fluid/preload, cartridge inserts, newly developed GSXR based cartridge swap. Correct spring rates and dampening setup is going to be necessary regardless of which you choose.
rear - pick any shock you want from the group of options GSXR shock, JRI, Nitron, Penske, Ohlins, Elka, prices will vary from $350 to $1500. Again regardless of choice with your weight its going to have to be (re)sprung and refreshed if (used)new
Old June 4th, 2014, 05:55 AM   #3
sharky nrk
sharky nrk's Avatar
ok as a step back you can get on the track with a bone stock bike but will quickly overwhelm the stock bits at your weight. Wanted to throw that out there as none of the is "required" to just get out and turn some laps.
Also, find out who your local suspension tuner is for your local track and see what they are best at/recommend for refreshing and adjusting because price will be ball park for all shocks.
SC1/2 with rosso II rear, or SC1/2 F/R, or R10/BT003RS, or GPA/unbeatean rear all seem to be enjoyed combos. I run 003R F/003RS rear currently.
Old June 4th, 2014, 02:08 PM   #4
Worldtraveller
Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F
I agree with this. I'd almost suggest not worrying about brake upgrades yet, either, unless you run on a really tight track.
I run stock suspension, and it will be my next upgrade, but I'm running on a really tight track budget this year. I'm only 3-4 seconds off the really fast guys, and the only real mods I have on my '09 right now are the VH exhaust and bodywork! I can tell I'm about outriding the suspension. I really need that and rearsets for more lean angle, but that is probably all I'll do this season.
The tracks I ride only have 2 hard braking sections/lap, and on the little 250, I don't find the brakes fading at all, even on hot days (just lapping around on the 600 gets the stock brakes to fade after ~5 laps, though). I'm much lighter than you, and I would think that would make the suspension a higher priority for you on a track.
Worldtraveller is offline   Reply With Quote
Old June 4th, 2014, 04:18 PM   #5
how fast are you? if you're a beginner, chances are pretty good that your pace won't really be quick enough to overwhelm the stocker bike setup if you try to be smooth with it so just go have fun and be safe. upgrade bits when you feel you need it. if however you're a bit quicker, go for upgrades now since you know you'll need them with your quicker pace.
how handy are you? if you know the difference between a bench grinder and an angle grinder then you're handy enough to do your own suspension stuff. if not maybe find someone to help you.
as far as suspension... get sonic springs and redo the oil in your forks. and throw on a resprung gsxr shock on the rear with adjustable dogbones. if you want to get extra fancy you can get emulators or if you want to be "that guy", you can spend about 500-800 on some cartridge drop-ins
Old June 4th, 2014, 04:57 PM   #6
I feel like some blunt honesty right now...
Respring it for you fully geared weight with some good front brake pads and ride on. Maybe a stainless line if you can't get the feel from the front brake you like. You can get near lap record pace on the stock bits, been there, done that. I race a gent on nearly 100% stock bits, he is 245lbs and is in the mix just fine. It's all up to your tolerance of what feedback you get from the bike.
Old June 4th, 2014, 05:00 PM   #7
Depending on your riding style and habits, the next thing(s) you will need is;
side stand removed
side stand mount tab removed
full exhaust system
Old June 4th, 2014, 05:49 PM   #8
jmk420
Thanks for the reply guys
Seems like I don't have to do that much and just ride, but I was recommended by many many people that I need to at least get re-sprung but I found out getting resprung is still a couple hundred dollars so some suggested if price aint that high might as well get a Penkse rear shock or something.
I am still looking for options, seems like somewhere like the ridge I will bottom out the forks due to elevation.
Also the bike is already jetted and have a full exhaust system!
http://youtu.be/u7Vqm6OX9SM
Old June 4th, 2014, 07:05 PM   #9
sharky nrk
sharky nrk's Avatar
I would respring and oil at least in the front. The OP at 260 has about twice as much weight as the stock bike is sprung for and it doesn't take much to bottom the forks. Less than $100 for springs and oil and very minimum effort to do. Outside of that, I stand by my previous posts.
Old June 4th, 2014, 10:14 PM   #10
Worldtraveller
Another PNW rider? Sweet. I'm hoping to be out for WMRRA rnd 3, but I'm waiting on some financial news to get it sorted out. If not, I'm always there corner working. Good luck.
I found a link once with some good, inexpensive suggestions for tracking a 250. I'll see if I can dig it up again.
Old June 5th, 2014, 09:08 PM   #11
jmk420
See if you got any links thanks!
I'm talking to some people and it ain't cheap to re-spring so I might as well get either Penske, Ohlins or Elka.
Trying to find a good deal now and finding some emulators as well.
Old June 6th, 2014, 02:43 AM   #12
jmk420
Just came across a very decent deal on SharkSkinz and bought them!
Old June 6th, 2014, 03:52 AM   #13
psych0hans
psych0hans's Avatar
Don't forget the zip-tie mod to reduce your throttle throw... It's a small mod, that will take you very far. I've actually gotten rid off my stock throttle and housing and replaced it with the R6 throttle + housing and switchgear. Needed custom throttle cables to get it to work.
Old June 6th, 2014, 05:36 AM   #14
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
ok, i'l bite where is the link to this "Zip Tie" throttle mod?
TEAM ALFALFA
www.apexassassins.com
Old June 6th, 2014, 06:53 AM   #15
psych0hans
psych0hans's Avatar
https://www.ninjette.org/forums/showthread.php?t=26270
Old June 8th, 2014, 02:31 AM   #16
jmk420
Bump.
I am planning to get these tires and seems like warmers are needed....
DIABLO SUPERCORSA DOT V2
110/70 & 140/70 Ninja 250 Set
Anyone know which warmers to buy?
Old June 9th, 2014, 07:40 AM   #17
Worldtraveller
I like my Chickenhawks. They aren't adjustable, but adjustable warmers are rarely needed.
If there's a racing club in your area, go look through their for sale section for a set of used warmers.
Old June 9th, 2014, 01:37 PM   #18
jmk420
Which Chickenhawk do you have?
Seems like the size made is for all the bigger 600+ bikes
Old June 9th, 2014, 01:41 PM   #19
You can successfully use warmers for rears up to 180. It may be tight if you have a hugger, but just take that off for your track/race time.
I only have one set of warmers, I use them both for my r6 and 250. There is a pic floating around somewhere of fitment. I can find it if you need me too.
EDIT: Don't forget to TURN THEM OFF for your session.
Old June 9th, 2014, 08:22 PM   #20
Knolly
Motorcycle(s): Daytona 675
They make them specifically for the Ninja 250, they're just not listed on their site. Either call Chicken Hawk or order through a vendor for a better price (shoot me a PM if you don't know one and I'll forward you along).
Knolly is offline   Reply With Quote
Old June 11th, 2014, 02:40 AM   #21
jmk420
Thanks guys!
I found that chicken hawk has the smaller ones and now deciding which version to go with.
I just purchased Pirelli Diablo SuperCorsa SC2 110 fronts and Rosso II 140 rear for the Ninja
Suspension wise I ended up with this :
SSRBillet CNC for cap preload adjust
Gold Valve Cartridge Emulator Kit
Ohlins rear shock (KA840)
and just some fork service and everything else
Super excited!
Now I need to buy some tire-warmers, stands and I should be good to go!
Old June 11th, 2014, 06:28 AM   #22
sharky nrk
sharky nrk's Avatar
^^ FYI unless your racing and need the first lap first corner banzi move, the SC front can get away without warmers just fine with an out lap
Old June 11th, 2014, 07:14 AM   #23
DCMoney
DCMoney's Avatar
+1 I don't run warmers during the track day only before the race.
The tires are more capable cold than most give them credit for.
MCRA.com
Old June 13th, 2014, 12:36 AM   #24
jmk420
For sure, but too many of my friends crashed on cold tires, so at this point perhaps $300-400 wont hurt... I'm so deeply in already.... hahaha
Old June 13th, 2014, 07:16 AM   #25
Same here, cept I don't even run the warmers for races depending on conditions and feedback I am getting from the bike.
But having them when you want/need them is nice. And like I say.... GO BIG OR GO HOME! So might as well pick some up.
Old June 16th, 2014, 02:11 AM   #26
jmk420
Hmmm, some goodies came in the mail
Old June 16th, 2014, 03:13 AM   #27
psych0hans
psych0hans's Avatar
Are you going to use HH brake pads in the rear? Might be a bad idea... The rear brakes are too strong for the bike anyways and are prone to locking. I've heard of people switching to organic brakes to avoid this.
Old June 16th, 2014, 10:03 AM   #28
When installing those rearsets, make sure you don't pinch your rear brake line. And get LOCTITE!
Old June 16th, 2014, 03:19 PM   #29
warmers will make those slicks last like twice as long according to some people
Old June 16th, 2014, 09:40 PM   #30
psych0hans
psych0hans's Avatar
also, make sure you use a lock nut with the gear shift rod. Mine came lose with the vibrations...
Old June 17th, 2014, 08:51 PM   #31
jmk420
Anyone got more info on this????
I can't find anything on this....
I am planning to use that on the rear
Old June 17th, 2014, 09:13 PM   #32
Well, this is a very personal question. If you fear that you may hit the rear brakes hard during an off track even, then yea... maybe some weaker rear pads may help. Imho, it don't really matter, organic or not, if ya gunna lock em up, it's gunna happen. So put what you want on there, the extra confidence goes a long way.
The takeaway is to progressively apply the rear brake when needed when your off track, and not just hammer it. The pads have an effect on the amount of pressure yes, your skills, however are not so black and white.
Old June 20th, 2014, 03:05 AM   #33
jmk420
I am not worried, as I am not a normal rear brake user :P
Also since I am bumping this.... anyone know of something to save my exhaust incase of a lowside?
I have a LeoVince full system.
Old June 20th, 2014, 06:14 AM   #34
sharky nrk
sharky nrk's Avatar
They make exhaust sliders .....
Old June 23rd, 2014, 02:48 PM   #35
jmk420
Any good brands you would recommend?
Old June 24th, 2014, 05:59 PM   #36
mgentz
Board Member
You can adapt a frame slider for this purpose.
Track Day - Budget Build Artie 1986 - 2007 Ninja 250R Tech Talk 19 September 3rd, 2015 01:28 PM
Ninja 250 track build Braden07 Ninjettes At Speed 56 July 15th, 2015 12:44 PM
08 r6 Track/Race Build csmith12 Pictures 48 May 3rd, 2015 08:34 PM
2008 250r Track bike build Ritter Ninjettes At Speed 31 July 15th, 2012 03:52 PM
My track/race 250 'build' switch Ninjettes At Speed 14 April 22nd, 2010 04:45 PM
