May 29th, 2009, 01:13 AM | #1 |
Lowering a bike further with 16' rims???
So far I have looked at/research lowering the 250r for my girlfriend.
So far -lowering links 1.25/1.5' (side stand inc.) -seat cut -platform shoes/boots Now if that extra little bit is needed I was thinking the 16' rims would be the last step. Any cheaper ideas before this? Or if it is the last step any ideas on cost, brands of 16' rims, maybe low-pro tyres on 17' rims? Last futzed with by snowlife; May 29th, 2009 at 08:32 PM. |
May 29th, 2009, 01:34 AM | #2 |
what is your gf's inseam measurement?
May 29th, 2009, 07:12 AM | #3 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
Ask one of the riders of the Pre-08 bikes that ash 16" wheels what the overall diameter of their wheels and tires are front and rear. Then measure the overal diameter of your wheel and tire to see what the difference is. Take that difference and cut it in half, and that will tell you how much lower the bike will sit.
May 29th, 2009, 08:19 AM | #4 |
Join Date: May 2009 Motorcycle(s): 09 Ninja 250R Special Ed Posts: 99
My wife if 5ft nothing and with lowering links she can ride the 09 just fine!
May 29th, 2009, 11:09 AM | #5 |
Join Date: Apr 2009 Motorcycle(s): 08 Ninja 250r Posts: 156
My inseam is 28" and I have no probs shock on lowest setting and with seat cut down slightly.. my pregen 250 was lower though (with seat cutdown also) so maybe that would be a better option?
Bristol, UK - R&G Tail Tidy, Exhaust Hanger, Bar ends & Crash Protectors, Skidmarx Hugger & Double Bubble, SW motech mirror extenders, Scorpion Exhaust, Cycle Control levers & Rearset Adjusters |
May 29th, 2009, 03:53 PM | #6 |
IC2(SW)
Isnt the belly pretty much on the ground after lowering links & them bar adapters to lower the front forks to match???
May 29th, 2009, 08:32 PM | #7 |
May 29th, 2009, 09:56 PM | #8 |
buy them used... they are about $500 each for each wheel alone, new.
I'd see how the bike fits her first before deciding to go the wheel route.... even then, I don't know how much that will really buy you. |
May 29th, 2009, 10:06 PM | #9 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250 Candy Plasma Blue Posts: 67
I am 4'10'' and i lowered mine and cut the seat. i used the RT lowering links and they lowered me like 2-3 inches.
May 29th, 2009, 10:09 PM | #10 |
didn't you have a problem with the tire eating through the subfender when it was lowered that much?
May 30th, 2009, 12:23 AM | #11 |
i had 2 problems with lowering it all the way down... 1 you can not ride with a passenger because mine ate through the back subfender. and 2 it bottomed out when i went over speed bumps so i raised it up one notch. it was a little higher and i didnt like it at first but i got used to it and now speed bumps are fine and me and my boyfriend ride together all the time. saves money on gas.
May 30th, 2009, 02:37 AM | #12 |
Join Date: Oct 2008 Motorcycle(s): 08 250 R Posts: A lot.
I think the lowering links will work fine. on the 08-09's.
My inseam is 25.5-26" and lowering worked great. My pregen I did not have to lower, but it was close.... I also lowered the front to keep the geometry closer to stock.
"Don't let adverse facts stand in the way of a good decision" Colin Powell Last futzed with by zartan; May 30th, 2009 at 10:09 AM. |
May 30th, 2009, 06:00 AM | #14 |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
I undersand your problem. There were two women in my MSF class that were well under 5foot tall who both found the stock seat height on the supplied Rebel 250s to be too tall for them to reliably place both feet on the ground!
Please be aware that lowering the rear alone will alter the steering performance of the bike. The more radical the departure from stock, the more performance will suffer. The best approach is to balance front and rear lowering to maintain predictable and safe performance, and alter seat foam from there.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
May 30th, 2009, 11:38 PM | #15 |
Your speedo will read even faster.....
June 1st, 2009, 03:46 PM | #16 |
any idea on 2nd hand wheel price?
June 1st, 2009, 03:51 PM | #17 |
have you actually figured out how much the 16" wheels will lower the bike? if you are thinking 1", you're mistaken.
June 1st, 2009, 05:40 PM | #18 |
Psychic war veteran
OK, let's run the theoretical numbers (keeping this one in has been killing me for days, and I'm surprised that no one has done it this way to compare yet):
First off, tire size is read like this=tread width in mm/aspect ratio in % of tread width-rim size. Thus, a 110/90-16 tire is 110mm wide at the tread, and the sidewall is 90% the height of the tread (in this case 90% of 110mm is 99mm) on a 16 inch rim. Remember, to get overall theoretical tire height, we have to DOUBLE the sidewall, because you measure the top and bottom of the wheel. Sources vary on the 07 and lower bikes. Some references show 100/90-16, some show 100/80-16 for stock front tires. Let's run both, as well as a performance tire known to be taller (have to raise the front fender): Front 16 inch 07 and lower 250s performance 110/90-16 tires. This is a very popular performance tire size chosen for the 07 and lower 250s, but is a little taller than dealer stock. Let's convert the rim size to metric. 16 inches x 25.4mm per inch = 406.4mm. The tire has a 99mm tall sidewall x 2 = 198mm. Rim height 406.4mm + tire sidewalls 198mm = 604.4mm tall tire/rim combo. Divide 604.4mm by a constant of 25.4mm per inch = 23.795 inches. * Roughly put, the 07 and lower rims with performance rubber has a tire height of 23 3/4 inches without load. For the 100/80-16, let's reuse some of those numbers. Near as I can tell, this tire size is dealer stock. Tire sidewall = 100mm x 80% = 80mm x 2 sidewalls = 160mm. Rim height 406.4mm + tire sidewalls 160mm = 566.4mm. Divide 566.4mm by a constant of 25.4mm per inch = 22.299 inches. * Roughly put, the 07 and lower rims with stock rubber has a tire height of 22 1/4 inches without load. For the 100/90-16, let's reuse some of those numbers again. Near as I can tell, this is an alternate front tire size that's also popular. Tire sidewall = 100mm x 90% = 90mm x 2 sidewalls = 180mm. Rim height 406.4mm + tire sidewalls 180mm = 586.4mm. Divide 586.4mm by a constant of 25.4mm per inch = 23.086 inches. * Roughly put, the 07 and lower rims with alternate stock rubber has a tire height of 23 inches without load. Stock front tires on the 08+ is 110/70-17. Let's convert rim size to metric. 17 inches x 25.4mm per inch = 431.8mm. Tire sidewall is 110mm tall x 70% = 77mm x 2 sidewalls = 154mm. Rim height 431.8mm + tire sidewalls 154mm = 585.8mm tall tire/rim combo. Divide 585.8mm by a constant of 25.4mm per inch = 23.062 inches. * Roughly put, the 08+ rims with stock rubber has a tire height of 23 inches without load. Thus, through the wonder of math we can see that using performance rubber, a 16 inch 07 and lower ninja 250 FRONT wheel/tire is about 3/4 inch TALLER than an 08+ wheel/tire combo with performance rubber. At best, with the smallest stock rubber, it's a 3/4 inch overall difference, which translates to an overall drop of 3/8 inch at the axle, and you lose the handling and ride comfort benefit of the lower profile tires to which the other parts of the suspension are spec'd!!!!!!!!!!!!!!! Wanna know what the numbers are for the rears? Yeah, after comparing the fronts, I'm not interested, either. Someone else do the math, I'm spent.....
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction Last futzed with by Banzai; June 1st, 2009 at 06:57 PM. Reason: updated to change the numbers for the smallest 100/80-16s |
June 1st, 2009, 05:44 PM | #19 |
My head is spinning.... I wasn't expecting that result!
As soon as my eyes recover from being in front of my computer all day, I'm going to read that more closely. Wow - TALLER! (and to think I was guessing 1/2" shorter) |
June 1st, 2009, 06:16 PM | #20 | |
Psychic war veteran
Yes, with the performance rubber. After some more searches, I augmented my post above. You can achieve a 3/8 inch drop overall with the 3/4 inch overall difference, but it'll take sacrafices. Your initial guess of 1/2 was pretty close. Sorry for the confusion, but after re reading my original post and found some alternate sources, I had to go back and fix things! Mea Maxima Culpa, I missed some things the first time! Now THAT'S a post for the lowering section of the Wiki!!!
June 1st, 2009, 06:38 PM | #21 |
Psychic war veteran
$50-250+ depending on condition + shipping on ebay right now.
June 3rd, 2009, 11:40 AM | #22 | |
very well done.
I intended to explore more, wheel cost rather than the rubber cost before I bought. So does enyone know what wheels/ hub specs suit the 250r??? |
June 3rd, 2009, 12:27 PM | #23 | |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
Check out the information for lowering the front. It's much more effective than lowering the rear by itself.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
June 3rd, 2009, 03:48 PM | #24 | |
Banzai has been great at doing the actual measurments on rims and rubber combined. Huge thanks. (was planning on doing this myself, but you did it before me, and MUCH BETTER) But any help on the wheels price/specs would be great. |
Raising the bike, removing lowering links! [HELP] | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 8th, 2014 07:59 PM |
lowering my bike | lowdown112 | 1986 - 2007 Ninja 250R Tech Talk | 2 | May 25th, 2013 08:18 PM |
lowering the bike question...but i have an EX500 spring | rabies | 1986 - 2007 Ninja 250R Tech Talk | 5 | September 8th, 2012 06:42 PM |
using 'lowering' links to RAISE the rear of the bike? | tommycruising | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 12th, 2012 03:51 PM |
Is lowering a bike safe? | PinkNinja81 | General Motorcycling Discussion | 11 | May 7th, 2009 05:55 AM |
